Question about HP Compaq Presario C500t Notebook
My Compaq Presario C500T lap top won't start
I don't think it's the battery, because there is an orange light that flashes when I press the power button indicating some kind of power, although I don't know if there's enough power to turn it on, but I'm just guessing, I know little about computers. Before this happened I noticed that without the charger plugged in to the lap top, a fully charged lap top would lose power pretty fast, some times like in 10 minutes. So i'm thinking mabe it could just need a new battery, but with that orange light flashing when I try to turn it on, I'm not sure. I don't want to buy something I don't need. So my question is, besides the battery what else could be the problem?
  • njoldja81 Jan 15, 2009
    I tried taking out the battery and plugging in the charger, it still won't start up. What else could be the problem.
  • rpro Jan 20, 2009
    I got ripped off... A German Student at USU sold me his computer. He said it worked fine... But he was in a hurry and since it turned on I thought it was ok (what a waste of $330). I got home and the battery still had a little charge in it so I plugged it into the wall, but after like 20 min it turned off on me, then I turned it on again. This time it only lased like 5 minutes and turned off.
    I took the battery totally out and with the AC Adaptor plugged in, light on the front comes on, so it’s getting juice, but as I push the power button it comes on, then starts to flicker (flash). The computer will not turn on. I think if I can find a way to charge up the batteries I think it will turn on... I have used a new power AC Adaptor but the same thing happens and it will not turn on...
    Please Can anyone help
    rpro11@yahoo.com
    Novelist:
  • 180 Answers
Generally speaking, an orange power light indicates problems with the power. You also described to a "T" how a bad battery behaves. To test this theory, take out the battery and plug in the laptop. It should power up and run. If so, it's time to invest in a new battery.
To be doubly sure, if you have anyone with the same laptop as yourself, plug in their battery to your laptop. It should work if their battery is good.
Thanks for using fixya.com. Please rate this tip accordingly if it provides the information you needed.
Posted on Jan 13, 2009
  • Bill Speer
    Bill Speer Jan 15, 2009
    How secure does the connection feel when you plug in the power adapter? Remember when you first got it and it was secure and tight? Is it still that way? A big problem with laptop is the constant plugging and unplugging loosens the connection so you end up having to jiggle it to make a connection.
Compaq Presario V5000 does not come on
The solution to your problem lies in one of the following three areas:
1.) Your charger is faulty and is therefore not able to pass power to your laptops battery.
2.) The charging connector on the laptop has come loose from the contacts. Therefore a bad connection.
3.) Your battery is faulty.
I think possibility 2 is the most likely, although you will have to test possibility 3 by removing the battery and plugging in your charger and seeing if the laptop powers on.If it does power on then that rules out possibility 1 and 2 leaving a faulty battery.
http://www.chargerbuy.com/replacement-compaq-presario-v5000-ac-adapter-65w-18-5v-3-5a.html
Nov 20, 2012 | Compaq Computers & Internet
I change the battery on my lap top. The Lap Top don't recognize the new battery I have a compaq presario x 1000.
If your Hp Utility program have already installed, run a battery maximizer. but if it doesnt, download it from http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=321852&prodTypeId=321957&prodSeriesId=321850&swLang=8&taskId=135&swEnvOID=1093
Choose your Operating sytem and download.
NOTE: Using Depleted battery for long period time may freeze power management console, so in order to use a new battery you should calibrate the battery. or try Charge it for 8 hours staright.
Cheers
Aug 23, 2011 | Compaq Presario X1000 Notebook
I am opening my pc and after 2 second it went off i have a blinking light like a orange flash light
I imagine the orange flashing light is over the battery? The compaq laptops have a little blue light that will typically light up when it's plugged into the wall. If it is plugged in ensure that the little blue light is on. If it isnt you may have a n issue with your power supply unit, or there may be an issue with the port where the plug is plugged in. Thus causing the battery to be dead and the computer not power on. If you have any other compaq computers you can also try plugging in that power adapter, or try picking up a universal or another hp/compaq charger from somewhere such as best buy to test it out.
Mar 07, 2011 | HP Compaq Presario C500t Notebook
My lap top has no display but with power, can anyone help me solve this problem
go ahead n do a power drain. take out the charger and battery (and other external device, if any)
press and hold down the power button for about 20-30 seconds. see if that helps, if not, u can mail me at L2support.hp@gmail.com
May 06, 2010 | HP Compaq Presario C500t Notebook
Compaq Presario laptop C300 - issues (orange light)
Sometimes when a PC gets stuck in hibernation mode, the only way to reset it is to remove the CMOS battery for 10 minutes and replacing it. It resembles a large watch battery and is usually located near the center of the motherboard.
Dec 16, 2009 | HP 435768-001 - Compaq Presario C300...
Presario C500 Wont turn on
sounds like the d/c adapter was either installed backward or the wrong part was installed, also check the connector on the new power cord to the laptop, you may have gotton an incorrect power cord. because what you describe is the internal power system is shorting out. take battery out and check it with a volt meter , if the is no volts/or negative volts on the battery ,it has gotten internaly reversed , and needs replacement.
Mar 25, 2009 | HP Compaq Presario C500t Notebook
Compaq c500 blank screen, can heard hard drive running
You should replace the power supply, and clan out dust, and tighten connectors
Mar 11, 2009 | HP Compaq Presario C500t Notebook
Flashing lightning bolt on Compaq C300
This sounds like a battery problem. The best way to test this is to remove the battery and then power the laptop up with just the power cord plugged in but no battery. If the computer boots then the battery is bad you will need a replacement. Also try letting the battery charge for a day. Be sure that the charging light is coming on when you have it plugged in.
Dec 09, 2008 | Compaq Presario Notebook
Computers & Internet Logo
650 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
