TOP LOADED STACKED Washer/Dryer
Washer not working
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
What is the complete model number of your unit?
Posted on Dec 10, 2012
  • 13 Answers
SOURCE: Whirlpool Duet Front Loading Washer Won't Turn On
mains filter blown door lock fail main pcd fail appliance doctor
Posted on Feb 02, 2007
docjohn174
  • 943 Answers
SOURCE: kenmore stacked washer / dryer 2002
hi thanks for the question so your saying your tub is full of water ,did it stop in the middle of the wash cycle or at the end of the wash if its at the end of wash and it doesn, drain then you have a lid switch problem . if thats the case reset your timer as if you want to start a new wash load if it starts to wash your timer is ok replace the lid switch
Posted on Sep 15, 2008
SOURCE: Dryer won't spin on my kenmore stacked model 417.90812991
This is the 2nd time I have this problem.
IF you look thry the drum to the back you should see 3 screw heads. Mine has one screw still in the hole and 2 empty holes.
This requires the drum to be removed (like take the drier apart). Behind the drum is Asmbly-shaft (ball hitch) (item 32 in the parts list). This what the 3 screws screw into.
I spent 2 days trying to put the screws in without removing the drum not possible (no way to hold the drum in place)
The first time I had to replace the drum because it wore the rim through.
I have to get 3 new screws and some thread locker.
I recommend that you check the screws every month, Use a long phillips screw drive
Posted on Mar 05, 2009
  • 89 Answers
SOURCE: Kenmore Washer/Dryer Stack -- Need to replace Washer
first of all. comming from a Sears Technician.. (don't yell) -- the delivery drivers only know about delivering stuff. they dont know too much,
if the two are the same size they can be stacked.
sometimes have to rig something up
and yes, for that model the top is removed, clips go on the rear and screwed at the front.
in some areas it is sold seperatly as a stacking kit
Posted on May 28, 2009
livewire874
  • 618 Answers
SOURCE: Top Load Stacked Washer /
I believe there is a fuse on the left side front under the front panel about a foot from the top of the washer.
Posted on Nov 20, 2010
My kenmore 98702 stacked washer/dryer washer lid does not stay open
Underneath the top unit (the dryer) there should be a spring loaded catch that holds the door open. See if it is gummed up and stuck or possibly broken off.
May 29, 2014 | Kenmore 98702 Stacked Washer/Dryer
Can an frigidaire X091307954 dryer be stacked on a Amana NFW7200TW 3.5 Cu. Ft. Front Load Washer?
this is possible, youll need a kit that sets on top of the washer,check back where you bought the washer and dryer, they make a washer and dryer combo thats one peice, they are smaller however
Jul 13, 2013 | Amana NFW7200TW 3.5 Cu. Ft. Front Load...
My LTE5243D top load stacked washer is about 10 years old. How do you take the front panel off to access the washer's motor coupling?
To gain access to the washer components, the front panel between washer and dryer must be removed first.
Remove the two top screws securing thethis panel to the unit.Tilt the transition panel down and pull itstraight out.Remove the two screws located behind the washer top.Pull the washer top forward to disengage the top locks. Disconnect the washer lid switch harness. Lift the washer top off the unit.Remove the two screws from inside the top of the washer front panel.Lift up on the front panel to release the catches near the bottom of the panel andremove the front panel.
Apr 24, 2012 | Whirlpool LTE5243D Top Load Stacked...
Top Load Stacked Washer / Dryer Maytag lse7806ace -- washer will not run, except in spin cycle
Nov 20, 2010 | Maytag LSE7806A Top Load Stacked...
Dryer works- washer doesn't
Check the outlet to which you connect your washer; check the plug of your washer, wires, fuse.
May 31, 2008 | GE WSM2420T Top Load Stacked Washer /...
Washer stopped working??
change the pressure switch its the switch that you select the water level with
Mar 18, 2008 | Maytag LSE7806A Top Load Stacked...
How do i get to the components?
working on either since stacked the washer top should be off, if working on the dryer remove the top the top is held in place with 3 screws washer likewise
Nov 29, 2007 | Whirlpool LTE5243D Top Load Stacked...
Whirlpool LTE6234D Top Load Stacked Washer / Dryer
Is your drain hose above the washer tub.. its got to be higher or will syphone out
Dec 01, 2006 | Whirlpool LTE6234D Top Load Stacked...
Washing Machines Logo
11 people viewed this question
Top Washing Machines Experts
