Question about Dell 2100MP Multimedia Projector
Where can I purchase a replacement fan for a dell 2100mp projector?
I need a new fan to replace one that is broken where can I get it
4 Suggested Answers
SOURCE: Dell 3200MP DLP Projector Fan Problem
i would take it a part and look, I would be it is a 60mm or 80mm case fan....
newegg, xoxide, performance-pcs or any other PC shop will have 60mm and 80mm case fans.
just chop off the connector from the old case fan and crimp, solder (sp?) or twist with tape the connector back on......
Posted on Aug 27, 2008
  • 3 Answers
SOURCE: Broken Color Wheel Dell 2400MP
Please contact at
It gear. In
Shop no 14, Sakhai plaza,
Nr. Kothrud Tel. Exchange,
Kothrud, Pune, India. Land mark- Shree Shivaji Statue. Telephone -020-66021475, Hand Phone - 9850557001.
Contact person- Ketan
www.itgear.in
Posted on Jun 01, 2009
SOURCE: Dell 1100mp projector
need to buy the right projector lamp for dell 1100mp
Posted on Jan 02, 2010
When I tried to switch on my projector Acer H5360 it makes some noise then it beeps 3 times, blue led light flash 2 times and then red is steady by returns... Its brand new.. Any idea? Pls help
Ordinarily my first thought would be that the lamp is needing replacement. But if it's brand new, the lamp should be OK. Can you open the lamp compartment to see if it was broken during transit, or perhaps it's not fully seated properly. If it's a broken lamp, then I would contact the dealer you purchased it from, or contact the manufacturer directly to have it replaced. Also, is the noise loud and unusual, or just the normal sound of a projector coming on? If it's very loud, it could be the fan motor. Check that the fan is blowing. If the fan is the problem, the projector will shut down to protect itself from overheating. That, too, should be covered under the waranty.
Jan 13, 2011 | Acer H5360 3D Video Projector 3D
Dell 1100MP turns off randomly. Replaced bulb but same fault ocurrs? Will stay on for 20mins then turn off, re-boot will stay on for 3 hours then turn off. Now has just turned itself off 3 times in 30mins?...
Sounds like a broken fan. There is two fans fitted, if one stops working the it activates a thermal cut out. I purchased a fan from ebay for £5.00 incl postage size is 70x70x20.
Jun 11, 2010 | Dell 1100MP Multimedia Projector
The Temp indicator is on. what does that mean?
Your owners manual has the answer. If you can't find it in paper, it can be downloaded from Dell here: Dell 2100MP Documentation
From what I read if the indicator is solid, it means the projector is overheated. If it is blinking, it means the fan has failed and needs to be replaced.
Good Luck!
Feb 05, 2010 | Dell 2100MP Multimedia Projector
Searching for signal
The problem is with the computer, not the projector.
There are special function keys, generally with blue lettering along the top row of your keyboard. Find the one that looks like a double screen or says "CRT". Also locate the blue function key [FN], probably on the lower left on the keyboard.
Press, and hold, the [FN] key and press the [CRT] key to change to dual screen.... and wait for several seconds for the projector to detect it. If it still doesn't work after you have waited, press the key sequence again (there are 3 different screen settings).
1. Computer Screen only (normal)
2. Projector Screen only
3. Both Computer AND Projector screens
Sep 24, 2009 | Dell 2100MP Multimedia Projector
Need replacement color wheel for 3300MP, where can I purchase one?
I had the same issue and it is impossible to find a new one and Dell is extremely expensive on repairs. You need to find a used Dell on Ebay or an Infocus X2. The X2 has the same color the only catch is that there is black timing marker on the motor that is the wrong position for the Dell projectors. I was able to compare the broken one to the new one and moved it to the proper position and everything worked fine. There are a lot more X2 projectors out there on Ebay.
Aug 03, 2009 | Dell 3300MP Multimedia Projector
Problem with my dell 1200mp projector
if you haven't already try cleaninig the filters
Aug 22, 2008 | Dell 1100MP Multimedia Projector
May 28, 2008 | Dell 1100MP Multimedia Projector
Faulty projector
Before a modern projector will strike the lamp it will check if the lamp is good either by remembering how many hours the lamp has been used or by measuring it with its own internal circuitry. if the test fails it will not strike the lamp because starting a bad lamp can potentially damage the projector and surrounding property.  Is the lamp old? Does it need to be replaced? if not then it may be a logic board and now requires service from a trained repair technician that has access to the parts it may need.
May 17, 2008 | Dell 2100MP Multimedia Projector
Dell 1100mp data projector
check fan filters.
sounds like you have an airflow problem.
open up and clean out dust.
or fan failure.
check fans are spinning when pj is switched on.
Feb 26, 2008 | Dell 1100MP DLP Projector Multimedia...
Dell 2100MP Multimedia Projector Logo
18 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
