Question about Leviton 1755 Triple Rocker Switch Decora
How do i hook up 3 function switch - Leviton 1755 Triple Rocker Switch Decora
  • Leviton Master
  • 5,089 Answers
1) Copy following link to see wiring diagrams:
http://waterheatertimer.org/How-to-wire-switches.html#triple
2) There are two basic wiring type, depending if power wire and neutral arrive in switch box first, or power wire and neutral arrive in ceiling box.
3) Most homes, the power wire is in ceiling box.
In this case, a minimum of 4 wires are needed between ceiling box and switch.
Posted on Dec 09, 2012
Can you have just 2 channel by hooking up to right & left front speaker posts on 5.1 surround
short answer.....no. If you hook more than one speaker up to a single channel, it will lower the impedence and will damage the amp. You can hook up multiple speakers by using a speaker switch box between the speakers and the amp. This will match the impedence and should keep the amp from blowing.
Dec 21, 2014 | Panasonic Technics SA-G76 AV Control...
Both headlights quit working simotaneously
There are just (3) possible reasons for this:
(a) your headlight switch has failed, or
(b) your headlight relay has failed.
(c) Fuse 1 (25 Amps) has blown
The headlight relay and fuse 1 are located (I think) in a fuse/relay block under the hood.
The headlight switch is part of the "Multi-function Switch" on the steering column.
Here's how to replace the 2001 PT Cruiser multi-function switch:
Multi-Function Switch Removal & Installation
1. Open the hood.
2. Disconnect and isolate the battery negative cable.
3. Remove both upper and lower steering column shrouds.
4. Disconnect both posi-lock harness connectors at the rear of the multi-function switch.
5. Remove multi-function switch mounting screws and remove switch from vehicle.
To Install the new multi-function switch:
Note:
If replacing the multi-function switch, the combination flasher and windshield wiper/washer switch
must be transferred to the new multi-function switch.
1. Remove the two Torx(R) screws retaining the wiper/washer switch, place next to the new
multi-function switch and install two screws.
2. Place switch into place and install mounting screws. Torque multi-function switch to column
retaining screws to 27 inch-lbs. (3 Nm).
3. Connect both posi-lock harness connectors at the rear of the multi-function switch.
4. Install both upper and lower steering column shrouds.
5. Connect the battery negative cable.
6. Close hood.
7. Verify vehicle and system operation.
Mar 15, 2011 | 2001 Chrysler PT Cruiser
I am wiring a 7 day timer and I found that I have 3 way switches. How do I hook these up?
Open following link to identify timers that work with 3-way.
http://waterheatertimer.org/GE-timers-and-manuals.html#15071
If you have ST01C timer and are connecting to three-way, then open following link:
http://waterheatertimer.org/ST01C-program.html#ST01C
ALL timers that work with 3-way switching will replace 1 of the two 3-way switches.
The remaining 3-way switch wiring must be altered so the timer works.
The reason is this:
The 3-way timer has extra wire, and when electricity flows to that wire, it reverses program status of timer, so ON becomes OFF for example, or OFF becomes ON..
The remaining 3-way switch is wired so it will send power back to the extra timer wire that reverses the timer program.
So the remaining 3-way switch performs a different function when 3-way timer is installed.
Jun 03, 2010 | Intermatic Inc. ST01C Digital In-Wall...
How to hook up heater motor to fan switch
The 3 resistor post should be the first 3 lower speeds on the switch. The high speed should be direct. Hope this helps.
Oct 25, 2009 | Chevrolet Camaro Cars & Trucks
My Hunter fan will only switch from high to low speed and won't
if the three speed switch is functioning the middle speed winding is bad.  Either replace the fan or hook up a wall speed control and keep the fan on high.
Mar 26, 2009 | Hunter 23852 Classic Original Ceiling Fan
Need switch for colman a/c unit
jason, if you are willing to to a little wire tracing, you can do this! We're going to create a new switch function. Chances are that two of the wires are probably for the fan motor (high and low). I'm not sure about max and normal. This uses a two position switch. Figure out which wires go where...then...get a '3 way' switch from the hardware store (they contain a common and two 'poles') along with a plastic box to contain them, a double switch cover and some 'heavy duty zip cord'. This is lamp cord but a heavier grade called number 16 or number 14 (14 preferred). Extend each of the wires and tape the connections. Now, threading the wires into the power box, hook the two fan wires that come to the switch to the new switch. Now, the common terminals and the power supply wire (probably the black) should be hooked together. It should all work...ugly but functional. If you need an on/off switch, you can make that a three gang box and include a standard on/off switch. If you can figure out the max/normal function, you can either switch it on or off or either/or...depending on the switch function. Hope this helps.
Dec 12, 2007 | Coleman 805D712T
Nothing happens when you press "Start"
PLEASE CHECK IF DOOR IS CLOSED PROPERLY THOSE HOOKS ON THE DOOR ACTIVATE SWITCHES ON THE INSIDE OF MWAVE OPEN COVER AND CHECK IF HOOKS ARE MAKING CONTACT WITH SWITCHES .COULD ALSO BE TOUCHPAD FAULT YOU WILNEED A TECH
May 09, 2007 | GE JE1540 Microwave Oven
AUX inputs
Turn the ignition key to on or accessory position, turn the stereo off, then hold the function key for a couple seconds, the stereo will turn on and you scroll through the menu with the left and right arrow buttons and change settings with the up and down buttons
Feb 25, 2007 | Pioneer DEH-P6800MP CD Player
My Emerson MW8115FS 1450 Watts
hi your door has hooks which activate switches.one of the switches is called the monitor switch .the purpose of this switch is to close the mwave circuit[complete the circuit] indicating your mwave is safe for use.at present your mwave circuit is open therefore your functions arenot working .check if door hooks are making contact with the switch ,check if the swith is testing continuity.ihope ihave been of assistance let me know cheers
Feb 05, 2007 | Emerson MW8102SS 1100 Watts Microwave Oven
Leviton 1755 Triple Rocker Switch Decora Logo
460 people viewed this question
Top Leviton Electrical Supplies Experts
 Kenneth
Kenneth
Steve
Hippy_dd
Are you a Leviton Electrical Supply Expert? Answer questions, earn points and help others
