GT1T-M7 CONFIGURATION DIAGRAM NEEDED - Computers & Internet
  • Computers & ... Master
  • 5,660 Answers
Http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=897&CategoryID=1&MenuID=16
It is my belief sir that you are referring to the ECS G31T-M7 (Version 1.0) motherboard. If I am incorrect please post back in a Comment.
Scroll down, and click on the Download tab.
(Features / Specification / Download / Support / FAQ / etc)
Now click on Manual.
(Driver / BIOS / Manual)
Scroll down, and click on the NAME of the country nearest yours.
There is the Motherboard User Manual in PDF file form.
For example;
The front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the main wires from the Front Panel go to; is the Front Panel header.
Motherboard installed in computer case, with Processor to the Top, and Ram Memory slots to the Right; the Front Panel header is located at the Bottom/Right corner, to the left of the motherboard mounting hole.
F_PANEL
The Front Panel header pinout is on Page 29, of the PDF file.
There are 4 pins across the Top row, and 5 pins across the Bottom row.
The pins on Top are numbered EVEN.
The pins on Bottom are numbered ODD.
Starting on the LEFT side coming across to the Right side, Top row:
Pins 2, 4, 6, and 8. There is NO Pin 10.
Starting on the LEFT side coming across to the Right side, Bottom row;
Pins 1, 3, 5, 7, and 9.
A) Pins 1 and 3 are for the HarDDrive activity LED. (Light)
Pin 1 is for the Positive ( + ) wire.
If the HDD LED is dim when the harddrive is active, switch the wires around.
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
C) Pin 9 is N/C. Not Connected.
This is probably a 5 Volt + point, reserved for factory testing.
D) Pins 2 and 4 are for the Power On LED.
(Light. It is a Light Emitting Diode)
Pin 2 is for the Positive ( + ) wire.
If the PWR LED is dim when the computer is on, switch the wires around.
E) Pins 6 and 8 are for the Power On switch.
Jumper settings are shown, Front Panel port header's pinouts are shown, etc.
Do you have a specific question? Please post back in a Comment.
Regards,
joecoolvette
Posted on Dec 10, 2012
Setting wrong values in below malfunction northbridge
to reset bios configuration:
1 unplug PSU from the wall plug
2 remove motherboard battery
3 wait 5 mins
4 put the battery in place
5 plug the PSU
Nov 21, 2012 | Biostar G31-M7 TE Motherboard
I have a ECS P4M800-M7 (V3.1) motherboard , does this motherboard supports Intel Dual Core E5700 ?
this motherboard supports the following
LGA775 socket for Intel Pentium 4/ Celeron D/ Pentium D processor
FSB 800/533 MHz
so anything above that might not work or just simply be a waste of money
the e5700 will fit as it's the same socket configuration as the motherboard but here's the rub, the 5700 is only compatible with motherboards that have intel chipsets and, according to the website, your motherboard doesn't have an intel cjipset, but a via chipset.
so the simple answer is no!
http://ark.intel.com/Product.aspx?id=42801
http://www.ecs.com.tw/ECSWebSite_2007/Products/ProductsDetail.aspx?detailid=548&CategoryID=1&DetailName=Specification&MenuID=52&LanID=0
Apr 17, 2011 | EliteGroup P4M800-M7 Motherboard
P4M80-M7 front panel connectors how to install them
your motherboard manual will show you the correct configuration for installing these. If you don't have a manual download it from the motherboard manufacture
Jan 30, 2011 | Computers & Internet
Drivers needed
check u r mother model number. go to run and type
cmd and next type cd\.
then type systeminfo you will get system model: XXXXX and then type this system model in google for down load the drivers.
Apr 30, 2010 | Biostar P4M800 Pro-M7 Socket 775 mATX MB...
Problem
Hi CompSeller, there are three versions of the Biostar P4M890-M7. They are;
P4M890-M7 TE
http://www.biostar-usa.com/mbdetails.asp?model=P4M890-M7%20TE
CPU support for the TE;
http://www.biostar-usa.com/cpusupport775.asp#P4M890-M7%20TE
P4M890-M7 SE
http://www.biostar-usa.com/mbdetails.asp?model=P4M890-M7%20SE
CPU support for the SE;
http://www.biostar-usa.com/cpusupport775.asp#P4M890-M7%20SE
P4M890-M7 PCI-E
http://www.biostar-usa.com/mbdetails.asp?model=P4M890-M7%20PCI-E
CPU support for the PCI-E;
http://www.biostar-usa.com/cpusupport775.asp#P4M890-M7%20PCI-E
Everything you need is listed above including bios updates.
Enjoy!
If I can be of more service, just ask.
Mike
Apr 05, 2008 | Biostar P4M890-M7 Motherboard
After Bios Upgrade P4M800-M7 V1.0 dont Boot
Try and go back to an earlier upgrade as this sounds like it might have hurt your original MASTER BOOT RECORD. If you find one that works quickly copy your MASTER BOOT RECORD and save it.
Mar 17, 2008 | EliteGroup P4M800-M7 Motherboard
Help!!
go to this site and download the manual,it will show you what you need to do.
http://www.nodevice.com/driver/P4M800-M7/get34672.html
good luck
Terry
Cable configuration
More info is needed: type of car? what you are trying to do needs to be explained in more detail. Are you trying to replace the head unit?
Jul 27, 2007 | Power Acoustik - PACD506
Computers & Internet Logo
125 people viewed this question
David Payne
David Payne
