Question about Refrigerators
Installing inverter box part W10133449
Replacing part that was removed by technician, need scematic to ensure all wires accounted for
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Dec 10, 2012
Where can I get the scematic for the Veco 21 STC voltage control circuit board?
try mailing the manufacturer
hot transistors are usually shorted out, or driving a short!!
a multimeter across the 3 transistor legs (TO-3 transistors have 2 legs & the case which is the 3rd leg) will reveal if they're dead (remove the transistors first as the circuit may give a false reading) - if you get a zero ohms reading between any of the legs it's dead - don't forget to check the smaller driver transistors too,, as a dead main transistor will kill its smaller driver transistor
speakers are marked,, usually 4 ohms or 8, though sometimes 16 ohms - use a multimeter to ensure you have something very close to these values according to the label on the speaker box & measure from the wires at the point where they connect to the amp
power the unit without any speakers or speaker wires connected,, if the transistors still get hot, you're very likely looking at bad transistors
Feb 21, 2015 | Audio Players & Recorders
Front window switch came apart
that really sucks the clips that hold the pins on the wires are probably brocken if thats the case you can get a pig tai or even a new conector from the diealer or junk yard youl need the wireing scematics to replace the pins in the proper order most chevys have similar conectors with diferent wireing colors if you get it at the junk yard you can get the scematics for that rig and match them with yours hop this helped
Jul 22, 2012 | 1995 Chevrolet G20
Lights come on and stay on, screen stays black and no bios
Hi.
First try resetting the laptop by removing battery with computer off and power not connected. Ensure that there is no disk inside the laptop and no connected USB device.
Test the laptop using an external display. There should be a video port at the back or at one side of the laptop. You may need to use a function key or to restart the laptop with the external monitor connected to switch to the external monitor.
If the laptop has picture in the external monitor, then the problem is either the back-light inverter or the LCD display. The inverter is the board that supplies power to the display and it is often located at the base of the display. Inverter is tested disassembling the computer and reading DC in from main board to inverter and AC high voltage out from inverter to back light.
If there is no picture on the external monitor, then the main board is probably faulty. The main board is tested disassembling the laptop and starting with no disks or internal devices connected (apart CPU fan, adapter and display) and replacing the memory sticks with known good ones. If the computer has two memory sticks, it can be tested removing them one at the time.
Testing must be done by a technician.
Regards.
Ginko
Apr 30, 2011 | Computers & Internet
Hi, I have a LXW18JEZRW-1 model regridgerator and the relay got burned. I called the technician and told me that the relay and the protector needs to be replaced. He took the damaged parts off and left. He...
there should be a scematic located on compressor terminal cover. one wire will be for common designated c the other two are for start winding s and run winding r . Do not cross up wires to start winding and run winding as this will burn out compressor. follow scematic and all should be well.
Dec 25, 2010 | Refrigerators
My parrot CK3100 flickers when i turn on the contact...when I turn of the contact it stays flickering and my cars battery dies...
First, you will have to ensure that the install may taking account of the specificities for some vehicles.
(Ex: in some cars, the 12dc red and the 12 ignition orange are inverted.
You can see it when you switch off the ignition key, it should appear good bye).
In that case, the product is still on and then this may explain the trouble.
But it may be also in relation with wires trouble between the box and the screen.
Feb 07, 2010 | Parrot Ck3200 Ls - Color Cell Interface...
NEED TO INSTALL SARTER ON 1997 EXPLORER ALL WHEEL DRIVE
  1. Disconnect the negative battery cable.
  2. Raise the front of the vehicle and install jackstands beneath the frame. Firmly apply the parking brake and place blocks in back of the rear wheels.
  1. Tag and disconnect the wiring at the starter.
WARNING When detaching the hardshell connector at the S-terminal, grasp the plastic shell to pull it off. Do not pull on the wire itself. Ensure to pull the connector straight off to prevent damage to the connector and S-terminal. If any part of the connector is damaged, replace the damaged component.
  1. Remove the starter mounting bolts and remove the starter.
To install:
  1. Position the starter motor against the engine and install the mounting bolts. Tighten the mounting bolts to 15-19 ft. lbs. (21-27 Nm).
  2. Install the starter solenoid connector by pushing it straight on. Ensure that the connector locks in position with a notable click.
Install the starter cable nut to the starter solenoid B-terminal. Tighten the nut to 80-123 inch lbs. (9-14 Nm).
  1. Connect any remaining wiring to the starter motor.
  2. Lower the front of the vehicle and remove the wheel blocks.
  3. Connect the negative battery cable.
RELAY REPLACEMENT
See Figures 7 through 13
  1. Disconnect the negative battery cable from the battery.
  2. If necessary, remove the power distribution box cover.
  1. Disconnect the positive battery cable from the battery terminal.
  2. Remove the nut securing the positive battery cable to the relay.
0900c1528018eb9b.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Fig. 10: Remove the cable securing nuts ...
  1. Remove the positive cable and any other wiring under that cable.
Fig. Fig. 11: ... then remove all of the cables from the relay
  1. Label and remove the push-on wires from the front of the relay.
  2. Remove the nut and disconnect the cable from the starter side of the relay.
Fig. Fig. 12: Remove the relay-to-fender apron attaching screws ...
Fig. Fig. 13: ... then remove the relay from the fender
  1. Remove the relay mounting bolts and remove the relay.
To install:
  1. Install the relay and mounting bolts. Tighten the mounting bolts until snug.
  2. Attach all wiring to the relay.
  3. If equipped, install the power distribution box cover.
  4. Connect the positive (+) cable to the battery.
  5. Connect the negative (-) cable to the battery.
Nov 11, 2009 | 1997 Ford Explorer AWD
Roof top rv air conditioner installation
Waeco manufacture a rooftop A/C with a matching inverter.you will need to ensure that you have enough battery power when staionary but your al;ternator will provide power when mobile you could also use a small generator through a battery charger to keep your batteriesd charged up but this is not neccessary unless you are stopped for a long period of time.these units are fairly easy to install and come with fitting instructions for the A/C and wiring kits for the inverter..hope this helps
Jan 11, 2009 | Dometic Rooftop RV Air Conditioner
Refrigerators Logo
65 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
