Question about Refrigerators
My f&p Frigidaire keeps clicking every 10-15
  • zed procter Dec 29, 2012
    Start temp 24C, 5min 30C, 10min 34C, 15min 38C, 20min 43C, 25min 46C, 30min 50C, 35min 53C, 40min 56C, 50min 60C, 55min 61C, 60min 62C and 50C on the side
  • Refrigerators Master
  • 4,655 Answers
If it is clecking it will need to be tested. Feel the top of the compressor to see how hot. Can you keep hand on top of compressor? Too hot to keep hand there? What is the model number of your refrigerator? Thanks Sea Breeze
Posted on Dec 10, 2012
Testimonial: "Hi, thanks for that, temps as follows; Start temp 24C, 5min 30C, 10min 34C, 15min 38C, 20min 43C, 25min 46C, 30min 50C, 35min 53C, 40min 56C, 50min 60C, 55min 61C, 60min 62C and 50C on the side"
  • John Tripp
    John Tripp Jan 04, 2013
    Sorry I could not get back to you sooner I have been out of town for the holidays. Sounds to me you need to replace the start relay, overload and the runcapacitor if your refrigerator has one. How well is the refrigerator cooling now? JT
HVACRH20
  • 237 Answers
SOURCE: Frigidaire FRT18HB5DW2 fridge not cooling
Sounds like an air flow problem to the lower unit. Take the sheetmetal or plastic rear cover off the freezer back wall and make sure the coils are frosted up good and even but NOT a block of ice inches thick (air needs to circulate and a blocked coil won't let air move over it efficiently). Make sure the fan is running to move the air around. In the fridge area make sure the air dampers are letting the cold air from the freezer down to the fridge compartment. Depending on what you find will determine the next steps so let us know.
Posted on Dec 27, 2006
the dr
  • 447 Answers
SOURCE: Freeze OK, but fridge stop cooling
very easy solution!!!chat with me online and ill step you through it save up to $65 (my in-home rate in florida is $75!!!!!!!)
Posted on Sep 27, 2007
22yooper
  • 828 Answers
SOURCE: Electrical unit attached to compressor
Overload thermal protector is tripping out. When a mechanical refrigerator is unplugged it should remain unplugged for 5-10 minutes to allow the refrigerant pressure to equalize. If you unplug it and then plug it right back in the overload will open on and off until the pressure in the system balance to the point where the compressor will start.
This protector is a two way protector. It opens on Over current and or over temperature. If a condenser is plugged with dust , hair or what ever the fan which circulates the air for cooling the system will not move enough air to keep the compressor with-in operating temperature range. The thermal protector will open.
Posted on May 04, 2008
22yooper
  • 828 Answers
SOURCE: compressor hums and shuts off
This sounds very much like a compressor failure. unplug the refrigerator and check the condenser for cleanliness. After cleaning the condenser and allowing the compressor to cool, plug it back in and listen for the same sounds. If the compressor was overheated it should restart after it cools. If it does not restart the compressor could be seized. Check the compressor warranty against the age of the refrigerator.
Posted on May 19, 2008
heatman101
  • 43501 Answers
SOURCE: Magic Chef Fridge not cooling
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
709oy
Posted on Sep 29, 2010
E240B Fridge Freezer door open alarm goes even when door closed.
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Cause of Beeping Noise in Frigidaire Refrigerator eHow
Dec 22, 2016 | Fisher Refrigerators
Fridge keeps bleeping
Mar 19, 2016 | Refrigerators
Fridge keeps beeping, have unplugged, checked door and drawer seals and still keeps beeping
http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator. Cause of Beeping Noise in Frigidaire Refrigerator eHow
Jan 20, 2016 | GE Refrigerators
Electrolux fridge EI11bf25ls just beeping compressor not starting no power going there
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
Fridge not starting? CLICKING? FIRST ALWAYSCHECK FORpower at the outlet,checkfor 120 volts. I think God os good that's why I give free advice?
MAY HAVE A BAD START RELAY OR CAPACITOR ON THE COMPRESSOR , CAN BUY A INEXSPENSIVE 3 IN 1 HARDSTART KIT AND BY PASS THEM , NOT THAT HARD TO DO, COMES WITH INSTRUCTIONS> BY THE WAY DO U HEAR ANY CLICKING SOUNDS FROM COMPRESSOR? BUT U MAY ALSO WANT TO CHECK UR COLD CONTROL THERMOSTAT IF IT GOES BAD U MAY GET A NON START ALSO HAVE IT CHECKED FOR PROPER VOLTAGE AND OHMS RESISTANCE WHEN IN THE ON POSITION
A BAD DEFROST TIMER CAN SHUT DOWN COMPRESSOR HAVE IT CHECKED WITH MULTI METER.
to check the defrost timer, u can get by and test manually by placing a small screw driver into the tiny slot or hole underneath the timer and turn slowly clockwise till u hear 1 click. this will engage ur defrost cycle in about 15 minutes u should be able to come back and feel the heat in freezer as it melts the ice providing ur terminator is not bad?
Another way to test it is with a multi meter. Remove timer it from fridge and you will see 4 prongs numbered 2,1,4,3 in that order. Place ur meter prong on prong 1 & 3 (if your fridge has a capacitor wired in series with the windings, then u check for micro fares rather than OHMS) If u cannot confirm this test, still try the next.
Take ur meter prong and connect to prong 1 & 4, it should read resistance or ohms ( closed) now remove prongs and place on prong 1 & 2, this should now read infinity or open (no ohms) now take a small screwdriver place it in the tiny hole or slot under the timer. Turn it clockwise slowly till u hear 1 click. Now ur 1& 2 should read closed ( showing ohms or resistance) now place meter prongs on 1 & 4 and you it should now show open ( or no resistance - no ohms) this is how u know ur timer is good, Remember when testing for ohms ADJUST meter to use a high ohms rating in the thousands as the resistance is very high in OHMS. And adjusting to low ohms rating may give a false reading or not show the proper resistance..
AT TIMES YOU MAY HEAR THE COMPRESSOR CLICK OFF AND ON OVER AND OVER. Signs of a bad start relay or capacitor. Check with an OHMS meter for continuity (ohms) and voltage, capacitor can be checked for Microfares. ( if in series with the windings)
To check ur compressor with multi meter:
Disconnect and remove the relay and capacitor from compressor, somes located next to compressor in a casing.
You wills see 3 prongs coming out of compressor. 1 goes to ur start winding, 1 goes to ur run winding and the center goes to ur ground or COM
Place ur meter connector or prong on the start prong and the other on the ground (center prong) take note of the reading in OHMS for example 5 ohms.
Next place meter prong on run prong and the center ground prong agin. Take note of the reading in OHMS. Example 4 ohms
Next place meter prong on the start prong and the other on the run prong, now take note of the reading example 9 ohms. Now match the total of this ohms test with the total of ur two separate test. 9 ohms, if they match ur ok give or take 5 percent plus or minus. One more test to make to test of there is a short in compressor attach meter prong to ground prong and rub the other end of meter prong to metal ( scrape the metal clean of paint and test on metal surface not painted surface. If it shows continuity or ohms , u have a short in ur compressor. It should show infinity
God is so good: so this is why I give free advice so please thank him not me.
May 14, 2015 | Electrolux Refrigerators
Got fridge freezer but no instructions. Alarm keeps going off. Front panel contriols
Fridge keeps beeping: The following is for Frigidaire models but others can be addressed similarly.
Apr 10, 2015 | Refrigerators
Fridge light comes on & sound but not cold
The freezer fan motor may be bad. The main back panel in the freezer can be removed to check it out. Spin the motor wiht your finger to see if it tries to run. If it does then it is shot.
Go here for:
Whirlpool Refrigerator Parts
RepairClinic.com
appliance parts, help & more
Sep 21, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
My fridge keeps making a ticking noise, sort of
The evaporator fan, inside the freezer will sometimes come in contact with ice and make this noise.
If the overload on the compressor is tripping it will make a clicking sound.
Mar 04, 2009 | Frigidaire Gallery Series® GLHT186H Top...
Fridge and Freezer working intermittently; not getting cold and making a vibrating sound
Dave, what you are hearing is the overload kicking out on the compressor. It's one of two things, either the compressor is failing or PTC (overload, relay) is going bad. I haven't seen too many PTC's fail on Frigidaire, but I have seen a lot of compressors failing. Your refrigerator will have a 5 year warranty, parts and labor if the compressor is at fault. You would have to do some tests on the compressor to determine which one is at fault. If you have a clamp on ammeter you can see how many amps the compressor is drawing during start and run. The compressor should have a label on it with the amperage information. You could just replace the PTC, part number 218721119 and see if the problem goes away but you could be throwing away money here if the compressor is the problem. With out being there, my guess would be the compressor itself. Catriver...post back.
Dec 08, 2006 | Frigidaire FRS23R4C Side by Side...
Refrigerators Logo
117 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
