Red light blinks an odd pattern
One long blink then a couple real fast blinks
  • 8,617 Answers
Thats most likely a error code. But I will need the model number of the set and the exact number of blinks such as 1 blink then 6 fast etc. Also does it repeat the sequence ?
Posted on Dec 09, 2012
  • 103 Answers
SOURCE: Monitor shutting off with blinking standby light.
Very expensive to fix.You hve a bad ysus board.Nec will re-build theboards as a set 1000.00 plus
Posted on Mar 22, 2007
  • 17 Answers
SOURCE: Akai plasma tv 5 blinking red lights PDP4298ED
Have you guys checked out my solution in the troubleshooting and support for this same Akai model?
Posted on May 08, 2008
  • 5 Answers
SOURCE: 42PF9630A 42
ssb:pnx2015 stby &control
b4e
7j00-5\pnx2015
STBY CPU
1LA0\16MB
X840GA
Posted on Jun 18, 2008
SOURCE: Red blinking light on a Magnavox Plasma TV
Here is the solution. For less that 100$ your Magnavox Plasma TV. Model # 50MF2310/37 will be running like a champ.
Issue:
Magnavox Plasma TV. Model # 50MF2310/37 screen has no picture. There is no sound, TV comes on and then after a few seconds clicks and screen remains blank.
Cause:
On the main power circuit board to Capacitors are prone to failure from over load. The caps are 3300uf 10v 105+c capacitors located to the left of the AC power input.
Service:
Magnavox will refer you to a service center. They will advise $$$ for an inspection. They will also want to charge upwards of 500$ to replace the entire board.
Solution:
1. Unplug your TV
2. Disconnect all connections from your TV
3. With assistance lay your TV on its face on a non-scratching service
4. Remove the back panel screws.
5. Lift back panel off
6. The central board is your main power board.
7. Remove all wire harnesses from the main board.
8. Remove all screws that are holding the main board in place.
9. Lift the main board out and carefully place it into a non electromagnetic pouch.
10. Take the board to a Circuit Board repair shop.
11. Have them replace the the above mentioned Caps.
12. Re-install the board in your TV.
NOTE: Replace the caps with 3300uf 16v 105+ high temp caps(preferrably Japanese caps)
This fix cost me 80$ and my time to search for other who had the same issue. Try searching for Magnavox Plasma TV. Model # 50MF2310/37 bad circuit board or Magnavox Plasma TV bad capacitors or Magnavox Plasma TV bad ciruit board.
Hope this all help, Magnavox is should take ownership for this problem and recall any tv's that have these caps in them. The worst part about this is that teh **** from the repair center that was paid 100$ to check the TV, stripped out the screw holes and damaged the case for the TV.
Portland Laptop Repair was awesome. They repaired the board and it looked like new. Check them out at http://www.laptopportland.com/
Jeff G
Portland, OR
Posted on Apr 28, 2009
tvservice306
  • 458 Answers
SOURCE: Panasonic TH-50PZ80U tv, error- 2 blinks
1. Reseating the connector P25 may solve the problem. If it does not.
2. Unplug the unit andd disconnect the connectors A5, A6, and A7. Apply power to the TV. If a White screen comes up and all voltages check normal, replace the P board.
3. If the TV stays on after isolating the SC board, then replace the SC board and the D board; it is likely that the fuse on the D board is blown.
Posted on Dec 06, 2009
Sony mo # KDS-60A2000 red light blinking no pattern to blinking
Lamp is bad. Even if its new. Unless you bought a real lamp using a Philips bulb, this is likely the issue.
Sep 13, 2016 | Sony Televison & Video
Turnsignals normal with headlights off.But , blink real fast when headlights on
Check you running light bulb.. some of those have two elements in them and one side could be blow inside the single bulb. The blinking is how the car tells you that you have a bad bulb, or maybe a short. Mostly likely it just a bulb.
Sep 11, 2015 | Cars & Trucks
Tv problems
Check the error code...you can get a list of them from www.TvRepairKits.com - look on their tips page. If its a 2-2 error code or if its flashing a 2-2 blink pattern then your convergence has gone out in most cases. If it just blinks constantly - with no real pattern - then its likely the well known blinking light of death issue - bad capacitors. You can get fixes for both at the above site.
Mar 08, 2012 | Mitsubishi Televison & Video
I have a blinker problem. When my high beams come on when it turns dark and I use my left blinker it blinks real fast and it makes all my blinkers blink real fast.
Bad ground, or check all your bulbs. Usually its a ground in the back of the truck under where the spare is. If its not the ground check the bulbs. Please rate Thank you
Sep 13, 2010 | 1999 GMC Sonoma
My PS3 has red blicking light need to know how to fix...
could be like the xbox light of DOOM! call the company or dealer
Aug 23, 2009 | Video Game Consoles & Games
Blinking light in unusual pattern and ticking/clicking sound
TH eclikcing sounds like the heads are uffering from STICKTION give the drive a gentle but sharp jolt with the palm of your hane and see what happens
Aug 09, 2009 | SimpleTech (sti-u2f36/250) 250 GB Hard...
Won't start up - red light blinks very fast
blinking light means faulty hardware - get a refund or call a helpline
May 22, 2009 | Computers & Internet
Sony kv35s26 TV: no picture, audio works, stanby light blinks.
First a couple of questions:
1) Does the standby light blink continuously or is there a repeating pattern?
2) If there is a pattern, can you please post the blink count?
With the above information, I should be able to provide you with a couple of possibilities as well as a few tests to perform. Please update this and we'll continue to try and resolve this.
Thanks,
Dan
Jan 19, 2009 | Sony KV-32FS13 TV
Power LED blinks red
it is a bad fan. it also could be a power supply. Quite often the real problem is dirt clogging up the fan(s) to the point that they need to be replaced. Operation of the set in a dirty environment is not a good idea
Feb 26, 2008 | Sony KDS-60A2000 60" HDTV
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
Electro Med Services...
