Question about Motorola Convertacom Amplifier 800mhz Model Ntn1325b
I need a manual for a motorola amplifier NTN1325B
    Prodigy:
    An expert who has answered 500 questions.
  • 607 Answers
Hi Mike,
Your post has come up on the 2-way radio forum, you need to post on the Home Entertainment forum.
Cheers,
Peter
Posted on Mar 07, 2013
An Instruction Manual is required
Hi, All you need to do is google "manual for"+brand+model number ie: manual for Samsung TV LE32R53B........ Look for a FREE user manual you'll find it...CHEERS..
Apr 07, 2016 | Car Audio & Video
Want to use astatic d104 mic for motorola maxtrac two way radio not a cb radio
With using a D-104 on a Maxtrac, you will probably need an audio amplifier.
Tom
Feb 13, 2014 | Radio Communications
I have a macro 2400 that needs a chip [c2527]and transistors[d6729-4][c8188-2 I want original parts the transistors in there now are not crown and sounds weak one side is crown and the blown side when it...
Your best way is google for the parts, but you need to add UP in front of the chip code (UPC2527)
and 2S in front of the transistors (2SD & 2SC), to find them.
May 04, 2011 | Crown MA 2402 Amplifier
I need to know where to get an installation book on a rockford fosgate punch 800a4 amplifier
There are several manuals for your amplifier. One for each product model year. Here are the direct download links for each year of manual. They are in PDF format. You will need adobe acrobat installed on your computer to read these files. If you do not have adobe acrobat you can download it at www.adobe.com for free.
1999 manual
1999 manual#2
2000 manual
2000 manual#2
2001 manual
Oct 15, 2010 | Rockford Fosgate Punch 800a4 Car Audio...
Hi, I have to replace all the 20 transistor of my krell kst-100 power amplifier- wich are the best choice? model and company? maybe mj21195g and 6 from onsemi?
Onsemi ( which is motorola) is a good pic for replacements If youre looking at the 21195 , then there must be a compliment to that as well? 21194 or 21196
Oct 10, 2010 | Krell KAV-300i 2-Channel Amplifier
Cannot set up Motorola Surfboard SB5120 modem
This usually means something is not correct with your incoming signal. If your cable wire into the modem is being run off an amplifier in the wall this could be effecting your service. If the signal is too strong the modem won't be able to communicate for internet.
You could check the incoming wire to see if it is running off an amplifier. If it is you would need to run a new line that is not on the amplifier. I would recommend comcast coming out to check the signal frequency and make the necessary adjustments.
May 04, 2009 | Arris SURFboard SB5120 Modem
Need user manual for setup of the amplifier.
It should say next to the speaker terminals what impedance of speaker the amplifier is rated for. You can drive any speaker within reason with just about any amplifier as long as you are not trying to attain loud levels. Here is a link to the service manual for your amplfier. It states in the schematic power ratings for 2,4, and 8 ohm speakers so you can assume that this amplifier is compatible with those impedance speakers. NAD is generally known for their beefy amplifier sections. http://www.scribd.com/doc/7234868/NAD-3020-Service-Manual
May 03, 2009 | NAD C325BEE Amplifier
Question: how do you connect to a cable box?
That Coby DVD-937 only has Digital Audio outputs rather than inputs, which is very strange and complicates our problem immensely. You will get 5-channels with DVD or radio play, but getting 5 channels for TV is not possible without additional equipment.
The manual for the Coby mentions a "Digital Decoder Amplifier," which would work. You would connect a digital audio cable from the area marked "Coaxial" on the back of the Coby to a digital audio IN on the back of an external amplifier. You would connect the speakers to this amplifier, instead of directly to the back of the Coby. Then you would need a cable or satellite box with digital audio outs (fairly common nowadays) to another digital audio IN on the back of the amplifier. The cable or sat box you may have already, but you may need to purchase such a "Digital Decoder Amplifier" or other digital amplifier with appropriate speaker wires and 2 digital audio input slots (not to mention two digital audio cables). Fairly complex. Possibly expensive.
-Tha Mp3 Doctor
Jan 31, 2009 | Coby DVD-937 5.1 Channel DVD...
Motorola gm300
If you are referring to the receive audio, possibly the reason it is soft/weak are:
1. defective internal speaker - try using an external speaker;
2. volume control - try rotating back & forth till you get satisfactory level. In some cases, you may need to clean the inside of the volume control with an electronic contact cleaner. At worst is that it has to be replaced;
3. defective amplifier - between the volume control and the speaker is the audio amplifier. This is a single op-amp IC U501 (TDA1519A); and/or
4. muting - which is a bit complicated. This is triggered either by the squelch or by the CTCSS tone decoder. You may have partial/false muting. You need to check Q501 (MMBT3904) and its associated circuitry.
Other than #1, most fix would require opening the unit and familiarity with electronic circuitry & components, use of a DVM and soldering iron. Perhaps your best bet would be to seek the services of a qualified communication technician.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Dec 08, 2007 | Motorola EM1000R Two Way Radio
Motorola Convertacom Amplifier 800mhz Model Ntn1325b Logo
55 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
bill tarkulich
Level 1 Expert
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
