Question about Kitchen Ranges
Samsung range element only works on High at all times.
One of my dual burners on my Samsung Range only works on High setting. When I turn the control switch down to its lowest setting or anywhere in between the element is still Red Hot.
    Top Expert:
  • Kitchen Ranges Master
  • 9,472 Answers
What is the complete model number of the unit?
Posted on Dec 10, 2012
4 Suggested Answers
  • 58 Answers
SOURCE: GE Spectra Profile - dual burner only has one temperature - HIGH!
you need a new switch that is in the control panel
Posted on Mar 12, 2008
thaurfen
  • 623 Answers
SOURCE: replacing a radiant element on
try this site for manual
http://kitchen.manualsonline.com/
Posted on Aug 19, 2008
SOURCE: Dual element burner on glasstop range...inner element stays on
It is the burner control (behind the knob). The triac in the control has failed. $50 item, 10 minute change. Just make note which wire goes to which terminal.
I doubt that it is the control board, as the board has little to do with the stove top, but rather controls the display and the oven temperature/feedback monitoring.
Hope this helps.
Posted on Feb 26, 2009
Ceramic stove top large element on high and won't shut off until turned all the way off
The range surface burner control switch, that the knob is attached to, needs to be replaced. The link is an example, as I don't know the model. They are mostly similar between manufacturers.
Range Surface Element Infinite Switch Part Number 3148952 SAME DAY SHIP...
Feb 03, 2016 | Frigidaire Kitchen Ranges
ONE DOUBLE BURNER ONLY WORKS ON HIGH NO MATTER WHERE I SET IT
Hello Miguel;
My name is Peter. I am a retired field service appliance technician.
There are two electrical components that will cause this problem. The most probable cause is the burner element. Each of your burner elements have a independent temperature sensor. The sensor controls the burner element temperature.
Substitution Part Number: 4453909 Cost: $85.00
This surface element (part number 4453909) is for electric ranges, including Whirlpool electric range model GJC3034RB00.
Unplug the range or shut off the house circuit breakers to disconnect electrical power to the range before replacing the surface element. Wear gloves to protect your hands when replacing surface element on your electric range.
This is a manufacturer substitution. Part may differ in appearance but is a functional equivalent to priorparts including 9759351.
OR:
PART NUMBER: 8523698 Cost: $71.00
The other less likely electrical component is Surface Element Control Switch. Each burner has a independent control switch.
Cost: $46.00
To check the switch: Remove the switch 2 contacts on the left. With a multi-meter, set the meter to the lowest Ohms (Omega Symbol). Put one meter lead on one switch contact and the other meter lead on the other contact. If the switch is good you meter will read "0" Ohms.
Jan 18, 2015 | Whirlpool GR673LXSS - Stainless Steel...
Most smooth top elements only work on high
this is a voltage distribution issue
you would be better served to replace the
ERC
Electronic Range Control
Sep 29, 2009 | Kitchen Ranges
Dual element burner not working
You have to use a voltmeter and test the voltage where the wires connect to the element. If you have voltage (probably 240volts) then the switch is good.
You then remove the element, and check it with an ohm meter to verify that the element is open.
Sounds like the switch to me, but you have to check it
May 01, 2009 | KitchenAid KESC307 Electric Kitchen Range
Hope this helps.
Jan 14, 2009 | Frigidaire FEF366DC Electric Kitchen Range
ERD36 Oven over heats
If the oven stays off when turned off then it is definitely a controller board problem. - that would mean the element is coming on and there is no control - changed the controller
Regards
Sep 11, 2008 | Dacor Epicure ERD30 Dual Fuel (Electric...
Replacing a radiant element on a maytag glass top range I'm having strange problems with the two right elements of my MER5770 The front larger dual element will only operate at high heat. When turning on...
If the burner is scorched or pitted, go ahead and replace it. New burners can cost anywhere from $10 to $40. Otherwise, check the burner's electrical connections to make sure there is solid contact. Jiggle the burner in its socket. If it is loose, then remove the burner—most just pull out of the electrical socket, although some are mounted with a screw. (Always unplug the range before removing a burner.) Slightly spread the two terminals apart for a tighter connection. If it still doesn't work, then replace the faulty burner with a functioning burner of the same size. If that burner works, then replace the bad burner with a new one. If it doesn't, then inspect the electrical socket for damage. If it's charred, replace the socket. To do so, remove the screws that secure the socket to the range and then unscrew the range wires. Attach the wire connections of the new socket to the range wires and reassemble the burner.
Aug 19, 2008 | Kitchen Ranges
yea sounds like an issue for sure, nut not with the element but hte switches instead, theres a short in one or the other( most likely the dual switch) i wouls reccomend replacing both the switches, the elemenst should be fine.
May 24, 2008 | Maytag MER5770 Electric Kitchen Range
Large Dual Element Is Not Working
Check the center ring. If it is open replace it.
Dec 21, 2007 | Maytag MER5765RAS Stainless Steel Electric...
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
