I got a model 27F485 from a bar that closed. Great picture but after a couple minute a black box appears at the bottom of the screen. Looks almost like a PIP but nothing in it. How do I get rid of
Problem with JVC TV Model AF27485 I got a model 27F485 from a bar that closed. Great picture but after a couple minute a black box appears at the bottom of the screen. Looks almost like a PIP but nothing in it. How do I get rid of it?s
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
Look in the set menu under closed captions, there will likely be a setting there for "TEXT" IF FOUND SWITCH IT TO OFF.
This is a feature a lot of sets had for books etc viewed but was never really used---the result a black box on the screen.
Posted on Dec 10, 2012
techman
  • 3130 Answers
SOURCE: Screen split with black bar through center, top of picture shows in bottom
It sounds as you desribe, the vertical output IC and or the b+ feed capacitor off the Hi voltage transformer feeding the vert. IC its required voltage. Not a really hard job to replace, but not for a handi person to do. This should be left to the professional, as there are no user serviceable parts inside this set and with the HI voltage and the safety issues its best to call somesone to assist you with this repair. Good Luck
Posted on Jun 14, 2006
TVtechmaniac
  • 140 Answers
SOURCE: Black box in middle of screen
You have CC (closed captioning) turned on and it is set to text mode.....Go to the menu on the remote use the right arrow and hilight "C.CAPT",use the down arrow to highlight "C.CAPT",use the right arrow and highlight "off" then exit button on remote.
Posted on Sep 16, 2007
  • 1694 Answers
SOURCE: Don't have a remote and can't get black square off (PIP?)
Black box is called a text box--part of and activated by the
Closed Caption part of menu. You should be able to de-activate
using buttons on front of set......T.
Posted on Oct 29, 2007
  • 110 Answers
SOURCE: Sony Trinitron TV with PIP
What;s the model number of the TV?
Posted on Jan 18, 2008
speekergeek
  • 11 Answers
SOURCE: I have a JVC model
It is probably the closed captions on text mode.
look on the remote for a CC button or use the user menu to disengage the closed caption.
Mike
Posted on Jul 12, 2009
19 inch curtis mathis tv
This is the closed captioning, even though it may not contain writing in the block. If you can access the main menu then you can try and turn the CC to off. Otherwise you are stuck with it.
Please rate this answer if it helped.
Feb 12, 2009 | Curtis-Mathis CM19011 TV
Black Bars each side of my new monitor wide screen
Right Click on an open spot on your desktop.
If your Operating System is Windows XP, choose Properties from the menu box that pops up when you right click.
A new window will open up. Click the Settings tab at the top right.
On this menu you should see a slider bar near the bottom left under "Screen Resolution". Left Click and hold the mouse button on the grey button and move it on the slider bar over to the right one spot. Then click the Apply button on the bottom right of the box. The screen may flicker for a second and your desktop will change size. If the screen covers the whole monitor and the black bars are gone, that may be the correct resolution. Click OK on the box that has a timer and is asking if you want to keep the screen that size. If the screen does not look correct, click No and you may need to slide the button one more spot over and try the next resolution and Apply until it looks correct.
Under the slider bar as you move it over a line at a time will be 2 numbers like this 1024 X 800, and when you move the bar over the numbers will change. I believe the optimal resolution setting numbers for the 20" monitor you have should be 1680 X 1050 for the widescreen. You may want to try that setting. If it looks too small, try sliding the bar to the left and try each resolution setting.
Here's a screetshot of what the Box with the slider bar looks like: http://technophobik.co.uk/vxp_control_panel/f007_settings.asp
If you have Windows Vista, (it is similiar to XP):
Click the Start Button and click Control Panel in the Start Menu
Click Appearance and Personalization in the new window that opens up.
Click Personalization, then click Display Settings at the bottom
A new box will pop up with the grey button on a slider bar near the bottom left under "Resolution" Slide the button to the right to the next line one spot over on the slider bar and then click the Apply button. The screen may flicker and change the size of your desktop. Click OK if the screen looks correct or click No if it doesn't look correct and try sliding the button over one more line.
Jan 21, 2009 | HP W2007 LCD Monitor
Used TV; new to me
type in PT-47WX51 manual in your search bar and there is an online manual from fixya. It will take you through setting up your tv.
Nov 06, 2008 | Panasonic PT-47WX51 47" Rear Projection...
Black box covering one-half of TV screen
Try turning off the text box function of the closed captioning.
Aug 02, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Black square box appearing on screen
I HAVE THE SAME PROBLEM WITH MY SANYO TV THE CABLE GUY TOLD ME HE HAD AN OLDER SANYO TV TO THAT DID THE SAME THING AND HE TOLD ME WHEN THE BOX APPEARS JUST HIT THE VOL + OR - BUTTON AND IT WORKS ALTHOUGH ITS A PAIN IN THE YOU KNOW WHAT WONDER WALMART HAD A BIG SALE ON MY TV.
TAMMY
Mar 04, 2008 | iLO V27DMBX Television
Jvc flat screen television model AV32F713 Black box on screen.
On the reomte control (bottom) left of the sleep button is a cc button, push that until "OFF" appears on the screen. The close caption box should disappear. It worked for me, finally.
Nov 29, 2007 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Black bar on screen
The text mode in the closed caption is turned on.Turn off the closed caption. I don't have the schematic in front of me, so, I will wing it. There may be a button on the remote that says CC, if so then use that button to turn it off, if not then go to the service menu and you may have to search a bit. Either way it's an easy fix and you can do it yourself. If you can't find it, then, reply and I will give better instructions when I get into my shop next week.
Sep 10, 2007 | Samsung TX-R2735 27" TV
Black bars in the picture
For Models: CC4352, CC4362, CC4393. Your camcorder has a wide format recording mode that lets you make recordings compatible with the 16x9 format. When 16x9 is activated, the camcorder records black bars at the top and bottom of the picture to produce the wide-screen (movie) effect. This is also known as "letterbox" recording. Do not use this mode unless you have a compatible 16x9 TV. When played on a regular TV, black bars appear on the screen. If the 16x9 feature is activated on your camcorder and you want to turn it off, press REC/PAUSE to pause recording, and repeatedly press DIGITAL EFFECTS until no digital effects display appears.
Sep 06, 2005 | RCA CC-432 Camcorder
Televison & Video Logo
55 people viewed this question
Top Televison & Video Experts
Electro Med Services...
