Question about Dewalt DW715 Heavy Duty 12" Single - Bevel Compound Miter Saw
How to replace arm locking pin on a dw705 Type 4 miter saw
    Champion:
  • 304 Answers
Can't remember how much access there is at the back on that model, on some you have to take the main hinge pin out to get to it and move the top arm assembly out of the way. Not always the easiest of jobs.
Posted on Dec 14, 2012
5 Suggested Answers
rowdy45176
  • 2176 Answers
SOURCE: how do I remove 12" blade from from dw705 miter
loosen the guard screw, UNPLUG tool first, move the guard out of the way, there is a spindle lockon the backside of the gearcase push it and slowly turn the blade until it engages and then remove the bolt, it is a left hand thread. DO NOT disassemble the guard, just loosen bolt and move out away from blade also you need to have the head in the raised position.
Posted on Oct 29, 2010
rowdy45176
  • 2176 Answers
SOURCE: DEWALT DW705 MITER SAW BRAKE DOES NOT WORK
Could be worn brushes, dirty commutator or a combination of both. Unplug the tool and remove one brush at a time noting the condition and length. Use a flashlight look into brush tube and also not condition of commutator. I would blow is out with compressed air and you can try turning the brushes 180 deg and retry. That is usually the problem
Posted on Jun 27, 2009
Editor925
  • 285 Answers
SOURCE: DW705 Miter saw Spark in motor Compartment
Yes spark in motor compartment is normal. You only need to worry if you see a lot of sparks flying out of the motor compartment! Most power tools will spark inside the motor compartment (particularly if carbon brushes are used).
Bevel and miter could be off... Consult your manual for how to adjust these correctly, but usually the bevel has a 0-degree setting screw or adjustment, and the miter adjustment on the saw is usually done by altering the fence position... Again check your manual for specifics on your saw.
Posted on Mar 19, 2009
  • 384 Answers
SOURCE: the deck on my DW705 miter saw is not as smooth as
Try a little oil.
Posted on Jul 15, 2009
My Dewalt DW705 miter saw just stopped running,instantly. Have power all the way to the brushes,power through the switch when engaged. Still won't run. Any ideas?
The motor may have failed abruptly. There could be an open thermal overload if your saw is equipped with one buried in the motor windings.
Nov 28, 2016 | Saws
Where can I order a replacement trigger switch
How to Install a Switch Kit on a DeWALT DW705 Miter Saw ...
? 12:35
https://www.youtube.com/watch?v=FJ1Wo2xufzI
May 15, 2013 - Uploaded by eReplacementParts.com
Get a replacement switch kit for your DeWALT DW705 miter saw ... kit on a DeWALT DW705 miter saw which replaces thetrigger switch (part ...
Miter Saw Parts ' Tool Parts Direct
www.toolpartsdirect.com/saw/miter-saw.html
Shop the Tool Parts Direct inventory of miter saw replacement parts. A miter saw is designed to quickly make cuts at a variety of angles. Featuring a pivoting ..
Oct 23, 2015 | Saws
Dewalt DW 705 Type 1 Hard to pull down to cut material
Go to www.2helpu.com that is the dewalt site. You might have to change the link arm that moves the guard up. They get bent over time. Check other parts on the raise and lower assy for wear at the same time.
Dec 04, 2012 | Dewalt DW715 Heavy Duty 12" Single -...
Cannot get saw to lift up on toedo chop saw
If your handle has two buttons, they are usually a power swtich and safety button so the saw isn't accidently started. No, power should not matter in the function of the swing arm. Most chop saws lock down by way of a small chain from the base to the end of the handle. Most miter saws and some chop saws lock down by way of a pin located on the pivot point of the swing arm. The pin locks the swing arm down by passing through a hole in the base pivot bearing.
Aug 17, 2012 | Saws
How do I remove 12" blade from from dw705 miter
Oct 28, 2010 | Dewalt DW715 Heavy Duty 12" Single -...
Need to get owners / instruction manual for my Dewalt DW705 type 3 12" miter saw. Do you know where I can get one quickly?
Hello. DeWalt has 13 types of this saw on file. Here is the link to all:
http://servicenet.dewalt.com/Parts/Search?searchedNumber=DW705&searchType=1
Click on the "more details" arrow of the one that meets your needs, then click the PDF symbol in the top right of the "product information" tab.
If this helps, please rate a four-thumbs up. Thank You.
Sep 12, 2010 | Hitachi C10FCE2 10" Compound Miter Saw
I borrowed a chop saw and it is in lock position, how do i release it
on the back of the saw where the arm goes up and down there is a pin that pushes in it will only stick out about a 1/2 inch.
Feb 23, 2010 | Hitachi C10FSB 10" Sliding Dual Compound...
HOW TO RELEASE DELTA MITER 250 SAW
All miter saws I've dealt with, there is some sort of peg located on the back arm close to the hinge. However, the arm is spring loaded so you may need to press down on the front of the miter saw to relieve pressure on the pin (peg) to allow you to pull the pin out and release the saw arm. I hope this is the answer you are looking for.
Dec 27, 2009 | Delta Cycle Rothko Rolling Bicycle Stand
Dewalt DW715 Heavy Duty 12"  Single - Bevel Compound Miter Saw Logo
161 people viewed this question
Top Dewalt Saws Experts
Parson's Repair...
Parson's Repair...
JOHN LAPIER
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
