Question about Home
I need replacement bottom slides
My bottom clips have broken. Where may I purchase replacement slides?
  • 843 Answers
Try re-posting your question with a bit more info, and under an appropriate category. I think this question isn't about drains, but I can't guess what you are asking about.
Posted on Dec 10, 2012
  • Daniel Dec 10, 2012
    It is for a 2010 MAAX Mod# SA9592-16 shower enclosure door.
How to remove the sliding door
Push up on the sliding cabinet door to release the bottom of the door from the track. Pull the door out and away from the bottom track and pull it down to remove it from the cabinet.-----------------------------------------------------------------------------
Renault CAN Clip Diagnostic Interface
Dec 05, 2012 | 2002 Mazda MPV
Where do I find the 4 plastic retention clips for this heatsink?
You can't just replace the clips, you will need to purchase the entire heat sink. Contact the manufacturer's parts dept for help ordering this or buy an aftermarket one on eBay.
Jun 05, 2012 | Intel Socket 775 Heat Sink and Fan up to...
Need to replace inside door handle that broke completely off. How do I replace this section?
you will need to remove the cover around the handle they are easy to brake from the inside of the outside cover ring go from the inside with a small screw driver and slide between and pry the cover up it has 4 mounting points top left top bottom right and left.
next pop off the switch from the front slide a screwdriver at the front leading edge and push it towards the back of the door panel and lift gently there is a flange on the rear of it that holds the rear of the assembly down dont pry up on the back lift the front and slide it forward unplug all the wires. remove the two screws inside the door arm rest where you pull the door shut. the cup to close the door. next you need to remove the mirror cover at the front top of the door panel slide a screwdriver pry
straight out. using a door panel clip tool. slide under the panel at the bottom rear corner to find the clip and pry the clip out of the hole. work your way around the door to each clip. sometimes you can pull the panel off with your hands but if you are not experirenced you might break some clips or the door panel be nice to it dont break things. all the way around the sides and the bottom are released then pull away from the door and hold the bottom and lift up and hit the top of the door handle with your hand so the clips will release accross the top. remove the light socket from the rear bottom of the door. place the panel somewhere so you dont scratch it up. now remove the rivet from the handle. I punch the center out then use a sharp chisel to punch it off. you may want to drill the rivet. up to you. then the handle slides forward and you have to disconnect the linkage clips from the handle. install the new handle make sure the lock rod is in the hole that slides the lock. hook up the linkages new slide back in position and rivet then reverse the prosess of removing the handle
Dec 12, 2010 | 1999 Chevrolet Suburban
Broken antenna on grundig mini 300 radio
Replacement is possible, the back of the radio needs to come off and there is a screw at the bottom of the antenna. Remove this and the old one will slide out and simple to install new one. Call Eton for replacement, can be foung with a google search....
Feb 14, 2010 | Grundig Mini 300 AM/FM/SW Radio
My keyboard on my laptop has a broken key, there are 2 clip underneath it and one of them is broken where can i buy a new one?? The key that is broken is the ALT key(bottom left hand corner)
Sure, they can be purchased for a cheap price from ebay. tell them what key for what model and they wil send you ithe key, and the two clips and anything else you will need. Type the model of your laptop, and add "keyboard replacement key". good luck
Jun 18, 2009 | Computers & Internet
The window keep sliding down. What should I check first. Do the window motor need to be replaced?
I have had two Roadmaster Wagons (we love 'em) with the same problem. The problem I found was only in a plastic clip that the actuator arms snaps into. I have not found an easy solution to replace, but it can be done. Take off the door panel and lower the window some (with help of a friend) so you can see the track at the bottom of the window. In that track there are plastic clips with a socket that a ball from the actuator arms snap into. You will probably see that one (or both of those) is broken. You need to slide out the old clip (you will need to bend out the indentation on the metal track so you can get it out) and slide in a new clip from a salvage yard. Now the hard part is pressing the ball from the actuator arm back into the socket of the new clip. I found I needed a special pair of pliers that opened wide enough without requiring the handle to open too far. After it is snapped back in, you should be ready to put the door panel back on and hit the road.
Apr 28, 2009 | Buick Roadmaster Cars & Trucks
How do you replace driver side mirror on a toyota highlander
It's easier if you buy the replacement mirror first. You'll see that the plastic mount for the mirror slides up and then clicks in. To remove the old mirror pull out at the bottom then slide down (shouldn't really need to slide down as the mount will come out when the bottom is un-clipped. To install new mirror, slide up, be sure that the mount is well into the upper tabs then push in the bottom two clips. Double check that the mirror is secure by pushing in on the top and trying to pull the mirror down.
Mar 20, 2009 | 2004 Toyota Highlander
Bottom element the clip that slide onto the spade broke off.
Since the element gets extremely hot when in operation, you need clips that are very heat resistant, which can be obtained from the Original Equipment Manufacturer. As far as the model number, it usually a plate that the on the surface that the oven door contacts. If you provide the model number, an owner's manual can be obtained.
Jan 27, 2009 | Ovens
The sliding door handles of my 1998 Toyota Sienna have both broken.
I replaced both of my sliding door handles this weekend. It was actually pretty easy. Cheapest I could find the handles was a little over $70 each. The interior panel is held on with one screw and 10 nylon clips. The one screw is in the cup holder. Put you hand in the cup holder and push out at the bottom. It pops right off exposing the one screw. I started on the clips from the top at a corner. Seemed to be the easiest place to slide a screw driver under. Once I got the screw driver in, I started working my fingers under the panel. The clips run mostly along the top and bottom about 6 inches from the edge. I made an effort to apply the force as close to the clips as I could to reduce flexing the panel. Once I got the first clip to pop out the other followed pretty easy and the panel lifted right off. Carefully peel back the plastic barrier. The exterior handle is held on with two 10mm bolts. Connecting the short cable was pretty obvious once you could see everything. Now I have to teach everyone to open the side doors very gently! Hope this helps.
Sep 21, 2008 | 1998 Toyota Sienna
Home Logo
42 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
