Question about Epson Stylus Photo® RX620 InkJet Printer
No shadow density in photograph printing
I use an Epson RX620 with Epson inks and photo paper and print from Photoshop.  When not printing photos the printer is used with refilled cartridges for my daughter's homework, etc.  When I print photos, I swap out to the Epson ink and the prints were beautiful.  After a 6 week hiatus from printing, I changed the cartridges to Epson inks and the prints lacked density.  They looked washed out, lacking black at least and possibly more.  The printer profile is SPRX620 (paper surface), PS manages color, rendering is Perceptual. Color Management is turned off on the printer and it's set to Best Photo. Any Clues?
  • 232 Answers
If you haven't been printing for 6 weeks, your print head is clogged, which is why the print quality is poor. Turn your printer on. On your computer, go to START, then SETTINGS, find PRINTERS AND FAXES and click on that. A window will open and you should see your printer. Right click on it, then click on PROPERTIES. A window will open, with several tabs. The one you need is MAINTENANCE. Open the tab and click on CLEAN PRINT HEAD. I think there are 2 options, cleaning and deep cleaning. Click on deep cleaning. You should hear the printer rumbling, then, when it finishes, it should print a page with 4 colors: black, cyan, magenta and yellow. If the colors come out right, you're done. If not, repeat the cleaning until you get a satisfying result. Just bear in mind that cleaning the print head uses a lot of your ink, so I suggest you put the refilled cartridges when performing this operation.
Also, to avoid getting in this situation again, I suggest that you print one page, at least once in 10 days. That way, your print head should always work fine.
If you found my answer helpful, please vote, it really means a lot to me to know weather I am helping someone or not.
Posted on Apr 14, 2010
Why won't my Epson Printer XP405 print a photo on Epson Glossy Photo paper
Your printer may need you to replace the "matt black ink" with "gloss black ink".
May 19, 2015 | Epson Office Equipment & Supplies
It won't print after installation of new ink jet
Here's a link to the Epson printer troubleshooting guide...if this helps; please indicate so.
Nov 10, 2009 | Epson Stylus Photo RX620 All-In-One InkJet...
Jammed paper has been removed but it wont print .Paper comes through with nothing printed. The ink is ok
your printer sensor is having problem, it will be better if you take it to some professional
Nov 06, 2009 | Epson RX620 All-In-One InkJet Photo...
Rx 620 slow to print
Epson's RX620 scans and prints photos at high quality. Text, however, was slow to print and not that good.
it_portal_pic_41791_t.jpg Epson's multifunction devices fall into two categories: general-purpose models that are designed for home or small office use, and photo-oriented devices such as this, aimed more at the enthusiastic amateur snapper.
Because it's a photography-centred device, the RX620 uses dye inks. On photo paper, these produce more vibrant colours than pigment-based inks, and a true gloss finish, but on plain paper produce inferior, less vivid results.
The Stylus Photo RX620 is quite large, and looks dated - but it's not short of modern photo-printing features. Its built-in memory card reader is compatible with seven commonly used digital memory formats, including xD and SmartMedia. Photographers using film will appreciate the scanner, with its high optical resolution and transparency backlight.
On plain paper the RX620's text printing showed bandingand rough outlines on default settings. Our five-page black-and-white text document took two and a half minutes to print. Increasing quality settings made it even slower.
We tried realigning the print heads to improve print quality. The RX620's manual process involves choosing the best-aligned examples from four rows of 15 patterns. This takes good eyesight, and it can be hard to choose between similar-looking options. We needn't have bothered - text remained unchanged.
Photo printing was far better. The RX620 produced some of the best prints we've seen from a multifunction device, but only at its highest quality - and slow - setting. Our A4 test picture took 15 minutes 12 seconds to appear.
The RX620's scanner is excellent, previewing an A4 sheet in six seconds and scanning a 6x4in photo at 600 dots per inch (dpi) in just 14.5 seconds. Negative scan times were reasonable, with a single frame scanned at 2,400dpi in 1 minute 40 seconds.
The RX620 can perform many advanced functions without being attached to a computer, and its colour screen has a clear menu system. Prints can be made directly from memory cards, photo prints or even film. There are four document copying settings, but results using the default Text quality are adequate for most office purposes.
The RX620 isn't a brilliant multifunction device. It does many things well, but its printer is too slow, and simply not good enough on plain paper.
Please rate my solution after reading it. Thank you
Feb 27, 2009 | Epson RX620 All-In-One InkJet Photo...
Epson R2880 trying to change matt black to photo black
There are many solutions posted already - what I do is in photoshop i start to print - even though I cant select the paper I want because the wrong ink is recorded - and I click print preview... then click print. The epson drivers tries to print, THEN detects the NEW ink and sends me back to selecting the paper with the new ink properly sensed. I hope this helps.
Feb 01, 2009 | Epson R2880 InkJet Photo Printer
Color from monitor to printer isn't the same.
Go to your printer properties and play around with the options you are given. You may find an option for paper quality: photo paper, print quality in which you can choose from the options from economical to best printing to photo printing. This may solve the highlights and shadows if your printer is set to print regular business copies.
Dec 31, 2008 | HP Photosmart C5180 All-In-One InkJet...
My photo prints have lines across them?!
the glossy paper you are using (hp) is smearing the ink... there is now ink on the feed rollers and you need to get in there and clean it all up with alcohol...also run epson matt paper for a few prints to get the color to lay down ..good luck
Oct 08, 2008 | Epson RX620 All-In-One InkJet Photo...
Card making
This machine will only print certain sizes as borderless. A5 is not one of them. You can use the following media with this feature: Matte Paper - Heavyweight: A4, Letter Premium Glossy Photo Paper:A4, Letter, 5 x 7", 10 x 15 cm/4 x 6", 8 x 10" Photo Paper:A4 Premium Semigloss Photo Paper:A4, Letter, 10 x 15 cm/4 x 6" Glossy Photo Paper:Letter, 10 x 15 cm/4 x 6" As you can see A5 is not in the list, therefor you will not be able to print A5 borderless via the normal means.
Aug 21, 2007 | Epson RX620 All-In-One InkJet Photo...
Use an good photo editor to adjust before printing
Jul 23, 2007 | Epson Stylus CX6600 All-In-One InkJet...
Epson Stylus Photo® RX620 InkJet Printer Logo
101 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
