The tonearm on my crosley turntable doesnt automatically lift up at the end of the record, what do i do?
    President:
  • 2,976 Answers
At the pivot point on the arm there is an indexing adjustment screw. With the unit running and a record on the table, put the are into the lift area on the record and turn the indexing screw until the arm lifts itself.
Posted on Dec 19, 2012
  • 104 Answers
SOURCE: Turntable tonearm returns but starts playing record over again.
http://www.vinylengine.com/library/pioneer/pl-570.shtml
on page 8 of the above service manual for your model it shows 4 electrical switches that tell the computer what 'state' the mechanism is in at any given time. Either one or more of the switches are intermittant or the mechanism has dried up grease that is slowing down the operation and basically gumming up the works. the old grease would have to be removed and replaced when it is causing binding. The switch just to the right of where is says "microswitch ksf-023" is an 'open air' type and so would be the most likely suspect. it simply needs to be cleaned with a super fine file designed only for cleaning switch contacts. THIS SERVICE SHOULD ONLY BE PERFORMED BY QUALIFIED PERSONNEL ONLY!!!!!
Posted on Feb 11, 2009
SOURCE: tonearm lifter in UP position - how to fix
I have also had this problem with the same model turntable. I opened mine up and the problem seems to have been that the grease on the arm lift and cueing lever was gumming up the linkage between the two. (I suspect that my turntable hadn't been used in some time.) I managed to free up the parts by manually working the the arm lift (pressing it down) several times. I'm not sure that I needed to open up the chasis for this fix but it did help me to see what was going on. Good luck with yours.
Tim Orange
Posted on Jul 19, 2009
Grubhead
  • 5391 Answers
SOURCE: converting a turntable from automatic to manual
I suppose the only way to do it would be to stop it functioning completely. The only way would be to dissasemble the auto function. What you would need to do is work out which parts are essential for the turntable operation and which only activate the return. So you need to whatch the mechanism working. You will need to remove the base and look at from underneath, just like going underneath a car!
I can't say for certain if you can do it, only you will be able to determine it can be removed without affecting the operation of the entire turntable.
Posted on May 25, 2010
STYLUSCITY
  • 271 Answers
SOURCE: my denon 26-f turntable stylus arm lifts about 2 minutes before end of record. how can this be adjusted on the turntable?
Hi Richard, at the base of the tonearm look for a rubber grommet. Under it you will find a screw. Adjust clockwise slightly to make the tonearm lift further along. Fine tune antil sorted. If the adjustment is not at tonearm base remove the rubber platter mat. If the platter has an access hole in it rotate platter so the hole is near the tonearm and look for scew to adjust. John styluscity.com
Posted on Nov 30, 2011
bobthebui447
  • 31 Answers
SOURCE: I have a Crosley CR49 turntable and the tonearm
that situation is possible that it is bent a little. make sure your table is level when using it and check the weight in the back to see if its too far out leaving the tone are to bounce of drift easily. you can manually put the needle down in the meantime.
Posted on Sep 22, 2012
KT 750. Why doesn't tonearm return at the end of a record?
i do not think this is an automatic turntable. Most higher end turntables are not. You will just have to pick the tonearm up and put it back. If you want an automatic one, look for an older technics automatic turntable. They work pretty good for what they are.
Apr 02, 2016 | Kenwood Audio Players & Recorders
Tonearm doesn't automatically return technics sl-d 202
Hi, at the base of the tonearm (left side) you will will find a rubber grommet or hole. Insert flat blade screw driver. Adjust until tonearm is lifting at end of record. Cheers john.
Apr 09, 2013 | Audio Players & Recorders
I have a Crosley CR49 turntable and the tonearm seems to be misaligned. I lift the cue lever and place the tonearm where I want it to land on the record, but when I lower the cue lever the tonearm moves...
Sep 22, 2012 | Audio Players & Recorders
My denon 26-f turntable stylus arm lifts about 2 minutes before end of record. how can this be adjusted on the turntable?
Nov 28, 2011 | Audio Players & Recorders
Aiwa turntable px-e860: Hi, I've inherited this timetable from a friend and it's worked fine until recently but now here's the problem: if I push start, the arm lifts up, moves to the record...
Hi, I;m not familiar with that exact model however the problem you are describing is commonly caused by the automatic operation at some point not being allowed to complete its full operation. Ie the tonearm has been returned manually to its rest position before reaching the end of the record. Try this. With the player not powered up lift the tonearm across to the record run off groove and sit it there. You may feel some resistance which is normal as the mech has to eswt itself. Now turn on the power and turntable. The arm should automatically return from there to its rest. Try auto operation after that. Let me know how you go. Cheers John. styluscity@gmail.com
Oct 10, 2011 | Aiwa PX-E860 Turntable
Have a cr2405b. the tonearm lifts up before last song is over. can tonearm be adjueted?
on the underside of the unit there is a screw that allows for swing of the arm. adjusting it takes some time since you dont want to over adjust it to allow the needle to slide over to the label area of the record. once you have the unit so you can see this adjusting screw, do the adjustments in small increments until the desired swing is achieved
May 14, 2011 | Crosley CR248 Turntable
Turntable stops before the end of a 45. Works fine for Albums. I found 1 solution but that says to take the player apart.
Just had this occur to me and after a couple seconds figured it out. Tonearm returns once it hits a certain height on the tonearm guide (the bit that goes up and down when you raise or lower the tonearm cue lever.) If you manually hold down the guide, the tonearm will continue to play the 7" until the end. You don't have to push down hard, just a nice gentle [pressure while the record plays should do it. It solved the problem for me.
Apr 23, 2011 | Crosley 0187SST Turntable
I have a Crosley CR248 cd record player/recorder stopped working
If nothing lights up and the whole unit is dead, you may have a blown fuse, a bad power supply, or an electrical outlet that is not giving you power. (Don't laugh, it has happened to all of us... the "broken" thing wasn't plugged in or the outlet it was plugged into was off for some reason). Anyway, if the thing lights up and everything else in the system works except the turntable going 'round, perhaps there is a slipped or broken belt. Most late-model Crosley turntables have been belt drive, so the first thing to look at if everything else works is to press the buttons to start the record playing and then turn the record gently around with your finger on the label, making the whole platter turn clockwise when looking down at the record. Mechanically, the tonearm should cue up and pivot in to the record and it should gently drop onto the record. If you cue the tonearm up and move it in to the end of the last song on the LP and let it back down and turn the record again, it should follow the record's grooves into the center of the record and then lift and "park" the tonearm after everything is done. During the time the needle is on the record and you are turning the record, you should hear the record playing (it will sound bad, because you won't be turning at the right speed!), but that should indicate that the turntable is working mechanically and electrically.
If everything works like I mentioned except the record player won't make the record turn, the next step is to see why it isn't turning. you'll need to lift the plastic platter off the turntable. Most of these have a snap ring (usually a simple spring wire ring that doesn't go all the way around the center spindle. It may have an E-ring instead. Use a small screwdriver to pop this off and be sure to catch it, it might try to pop off the turntable and fly across the room! Lift the platter and you'll probably find a broken belt underneath. You'll have to replace that to make the records spin again. The hardest part is to locate a replacement belt! If nobody near you stocks belts (lol) then online outfits like LPGear.com can be a source. After you replace the belt and put the platter back on the player, remember to replace the snap ring. You might want to lubricate the platter's bearing with an appropriate lubricant, but that is your call as to whether that will be necessary. This is likely a styrene or simple thermoplastic plastic bearing, so be real careful what you use for a lubricant! if you're not sure, don't use anything! Like I said, it's not a difficult repair, it's just hard to find the part these days! Good Luck!
Jul 24, 2010 | Crosley CR248 Turntable
Can't play records on my crosley cr66 turntable
You have to lift the tonearm up, and move it to the right slightly. This starts the turntable moving.
May 27, 2009 | Crosley Arlington Stack-O-Matic CR66 Shelf...
Getting the turnable to come on
some platters will not begin to spin until the tonearm is lifted up from the rest and over to where the record is, then it starts spinning.
alternately the belt may have come off.
http://www.archive.org/details/Turntable_Belt_Installation
will provide general info on how to put it back on.
Jan 11, 2009 | Crosley CR248 Turntable
110 people viewed this question
 Grubhead
Grubhead
