Berr flash crc (be1) error - Computers & Internet
  • Computers & ... Master
  • 27,725 Answers
If you want to know what this is the error code is related to
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured or click start type in event viewer press ENTER you might be able work your way through the problem
Hope it helps.
Posted on Dec 10, 2012
How do I clear error BEi or BE1 on dual view dstv decoder.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/..
Aug 17, 2016 | Televison & Video
Error code BE1 comes up at spin time & it stops. Common cause?
8e1 Front mems sensor error locates on main board check at main board fir loose harness. Probably a bad sensor or harness get both the sensor itself is under too near front right
Apr 09, 2016 | Samsung WA456DRHDWR: 4.5 cu. ft. King-Size...
Set-top box has encountered an error BE1
If you use a cable box, then either the cable box is putting out a signal that the set cannot understand or the set has a problem with one of the boards in it.
Nov 18, 2013 | Samsung Audio Players & Recorders
Berr flash crc (be1) error icord
These codes are meant for factory repair techs.
Feb 02, 2013 | Humax Televison & Video
Error 0175: Bad CRC1, stop post task
ERROR
0175: BAD CRC1, STOP POST TASK.
Firstly, this error is generated due to a couple of different reasons. First, there may actually be a problem with the power circuitry and the CRC function is actually doing it's job reporting the error. There are several tests you can perform to tell if this is the case with your system.
Secondly, this bad CRC error can be generated by sudden power loss to the system, especially if the system loses power during boot up or POST process. Both mean that there could be a problem with the motherboard and it needs replacing.
Try the steps below to determine what is wrong.
1) Start the system and watch the status lights in the LCD hinge or near the power button. They should flash once (some models twice) before the system shows a display. If they flash 3 times or more, you have a power problem.
2) Start the system and allow it to reach the CRC "stop post task" error message. Let it sit at this error for several hours. The system should sit at this error for ever or until user intervention occurs.
3) Some things to watch for while the system is sitting at the CRC error and running for several hours would be: Screen going black, System rebooting, System powering off, ect.. ect.. ANY activity by the system is a warning that power problems exist in the system.
4) Try restarting the system several times consecutively, shut the system down by holding the power button for 5 seconds, then restart keeping an eye on the status lights for any additional flickers.
All the above tests should be done with AC power applied and battery installed. Also ALL drives installed.
Regards.
Jan 19, 2011 | IBM ThinkPad T23 2647 Notebook
After shutting down the computer a few times when transfer file from PC to CAXE3702T0, all of a sudden, blue screen and when the Window 7 boot up again, it said the CAXE3702T0 has CRC problem. I tried...
CRC or Cyclic Redundancy Check is a process that helps in identifying any errors that might occur during the data transmission process. Data is usually transmitted in small blocks, and a CRC value is assigned to each block and transmitted along with it. This CRC value is verified at the destination to ensure that it matches the CRC value transmitted from the source. A CRC error occurs when the two values (source and destination) do not match and the test fails. The main benefit of CRC is that it helps you ensure that data you have received or downloaded is not damaged or corrupt.
Causes of CRC Errors
CRC errors can occur due to many different types of problems. Some of these problems are:
  1. Damage to file during the transmission process.
  2. A problem occurred when the file was being sent.
  3. Problems with the device that is accessing or opening the file.
  4. Problems with the file itself.
Jan 14, 2011 | Cavalry Storage (CAXE3702T0) USB Hard...
DMA driver error CRC error G sonyDVD RW AD 72605
Resolving CRC Errors
Let's now have a look at the methods you can use to resolve some of the common CRC errors on your Windows system.
Fixing Transmission Problems with Network and Modem
You may encounter CRC errors while trying to transmit files over a network or a modem connection if there are problems with the connection you are using or there are data collisions occurring during the transmission due to heavy traffic.
Additionally, you may receive CRC errors if you are not transmitting your file in a format that is compatible with the protocol being used for transmission. For instance, if you are sending a text file through an FTP or Telnet session, it must be sent in Text mode or as an ASCII file. Non-text files, however, must be transmitted as binary files.
To resolve these problems, you can try the following:
  • Ensure that there are no problems with your network or modem connection.
  • Try to retransmit the file.
  • Try sending the file using some other method or connection.
  • Ensure that the file was sent using the correct format.
Dec 06, 2010 | Sony (CRX320AE/U) CD-RW/DVD-ROM (Combo)...
CRC Problem
Chances are since the system CRC1'd it has a very old BIOS revision. From version 1.10 on, the CRC issue has been fixed. So, get the latest BIOS from IBM, T21 BIOS: ftp://ftp.software.ibm.com/pc/pccbbs/mobiles/spsdkz34.exe and flash the BIOS. Reboot the system and verify the updated BIOS. Now power down the system, desolder the known good EEPROM and resolder the CRC1 EEPROM. Boot the machine and hit ESC when the splash screen comes up and watch the post screen. The new BIOS should have recalculated the EEPROM checksum and written the changes to it. You'll know if it worked because the CRC1 error will be gone.
Jan 03, 2009 | IBM (09N5424) Motherboard
GoGear 4GB SA3345
i have the same problem but am taking it further check out this link http://www.berr.gov.uk/consumers/fact-sheets/page38311.html
Jul 02, 2008 | Philips GoGear Flash MP3 Player
CRC error??
"In simple terms, a CRC (cyclic redundancy checks) is bit of mathematics used to ensure that your data is OK when being transfered. It's a checking procedure that quickly identifies when data has been damaged. If you get this message, it means that the file being read by your PC or software is corrupted."
so, yes, the CRC error is most likly the problem.
May 07, 2008 | Computers & Internet
Computers & Internet Logo
198 people viewed this question
David Payne
David Payne
