Question about kawasaki Full Suspension Mountain Bike Men
Kawasaki KFX450R, will not start just clicks rapidly.
My 2008 kawasaki KFX450R will not start. When i try to start it it just makes a clicking noise rapidly. Is this the solenoid, and if so what do i need to do to fix it? Thank's for your help.
  • 32 Answers
SOURCE: need a kawasaki zxi 1100 owners manual
Most of the time you can look up the owners manual on websites as long as you can find the kawasaki website you should be good, i had the same problem with a dirt bitke and i found there website and found the owners manual and downloaded the owners manual and printed it out. Hope i was of some help to you.
Posted on Aug 03, 2009
SOURCE: i need part no for engine assy. Kawasaki Mule
back fire through carb when you let off gas have to run with choke on
Posted on Aug 06, 2009
  • 29 Answers
SOURCE: i falled in water with my kawasaki.the bike was in
Kick it over??!! ZX9 read the question!
Posted on Aug 11, 2009
  • 9 Answers
SOURCE: i have an old kawasaki snowmobile and i need to
honda
Posted on Dec 22, 2009
SOURCE: tried to pop start in 3rd gear kfx450r atv engine will not turn
I have a 2008 kawaski KFX 450r. Been having issues with it starting. I will ride the bike a 2 o 3 days, then it wont start. Thinking it may be the stator? Battery has been tested, and is good. Battery is always kept on a trickle charger when bike is stored for long periods of time. The starter makes a loud grinding sound as well. Also thinking it could be the starter. Before I spend hundreds on parts, is there any advice?
Posted on Mar 17, 2010
CF moto v5 250cc is making clicking noise when try to start. Bike was serviced yesterday and this morning it is not starting.
If there is a series of rapid clicks check your starter solenoid, although a single click can be a low battery.
Nov 30, 2015 | Motorcycles
How can I get a wiring diagram for a Kawasaki KFX 450R?
get-wiring-diagram-kawasaki-kfx-450r-vkeb3uajg4eweh5dognnetyc-2-0.png here is one or you can go to kfx450hq.com good luck with your project.
Jul 22, 2014 | K and N Kawasaki Kfx450 Kfx450r K and n...
1998 kawasaki VN1500 Vulcan Classic Motorcycles
try cleaning the start button inside the housing as weather gets in and could be a dirty contact ! check the earth contacts around the engine also ! are the wires to the solinoid in good condition , battery wires also ?
Apr 24, 2014 | kawasaki VN 800 Vulcan Classic Motorcycles
Kawasaki vn1500 will not start,new battery,new starter solenoid,good fuses,just click click click not start
Check your ground connection to make sure that it is clean and tight. If the connections are good, I would suspect the starter itself.
Kawasaki 450r
I had a similar problem on one of my bikes. Turned out a "Test Port" had rattled loose between the carb and the intake. I threaded a screw in the hole to prevent the leak and problem was resolved.
Apr 02, 2014 | K and N Kawasaki Kfx450 Kfx450r K and n...
STARTING PROBLEMS
sounds like loose wiring
Aug 07, 2012 | 2005 kawasaki ZZR 600
Starter
A rapid clicking noise when you turn the key would be the starter solenoid trying to engage. The most common cause of this problem is a weak battery. Make sure your battery is fully charged, then try to start it. If this works get your charging system checked out first. Get a "load test" done on the battery. It may be starting to go. Also the alternator should be putting out 14.2-14.5V when the engine is running. If it's lower, the alternator is starting to wear out and needs to be overhauled. Make sure your battery cables are tight and the terminals are free of corrosion (green gunk).
If you need to go further, you only have to follow the positive (red) cable from the battery. It will go directly to the starter solenoid, which is on top of the starter. Hope this helps.
Nov 29, 2011 | 1997 Pontiac Bonneville
Kawasaki ZZR 600 clutch noise
Hi, Tompolv6 I would love to help you with your engine or chassis noise but I just loaned my brand new pair of listening ears to your local dealer's chief technician so he could take your bike for a test ride and give you his professional opinion and estimate about your noise and repair cost. If you are a little short on "DRACHMA" and a Dealership is not on your list of fun places to visit then perhaps the list below will help soothe your worried mind so you can make an informed decision.
1. Bearings---SCREECH
2. Belts---CHIRP
3. Brake Rotors---BUZZ
4. Chains---RATTLE
5. Clutches---CHATTER
6. Cylinders---PING
7. Fairing Panels---WHISTLE
8. Fronk Forks---Plunk
9. Gears---WHINE
10. Head Gasket---HISS
11. Hydraulic Lifters---TAP
12. Pistons---SLAP
13. Rear Shocks---SQUEAK
14. Shifting Trans---CLUNK
15. Solid Lifters---TICK
16. Starters---CLICK
17. Connecting Rods Go---KNOCK-KNOCK---who's there, it's me "*****"
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
03 zzr600 Loud clunking noise at idle
zzr600 clutch noise
Kawasaki ZZR 600 Complete Service Repair Manual Download Manuals Technical $10
OEM Parts for Kawasaki
2006 Kawasaki ZZR600 Owner Manual
May 25, 2017 | kawasaki ZZR 600 Motorcycles
2000 Kawasaki Vulcan VN 2000 lifter noise
Hi, Yellowstonem you may have a contaminated lifter that needs to be disassembled and cleaned or replaced for more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
yr 2005 VN2000 Engine Noise
Vulcan 2000 valve train noise
Kawasaki VULCAN 2000 Service Manual
2004 Kawasaki Vulcan 2000 Owner Manual
Oct 26, 2017 | 2000 kawasaki VN 2000
kawasaki Full Suspension Mountain Bike Men Logo
132 people viewed this question
Top kawasaki Sport & Outdoor - Others Experts
Wayne McNeil
Phillip Edwin
Level 1 Expert
Are you a kawasaki Sport and Outdoor - Other Expert? Answer questions, earn points and help others
