Sony DVD Recorder RDR-HXD890 tries to record BBC Wales channels when I've set it to record BBC England
When I set my recorder to record BBC (channels 001, 002) it switches itself to trying to record BBC Wales channels 801, 802. As we do not receive BBC Wales it just sticks waiting for the signal to record, which doesn't come. I've tried retuning the recorder skipping the Welsh Channels, but its auto tune facitility means that they reappear again the next day (just the names, no signal) and again, it changes itself to trying to record the Welsh channels when I've set it for English.
  • 1 more comment
  • Eric Wolff Jun 16, 2013
    Did you solve your problem. Not usre its anything to do with BBC Wales, but we have the same occasional symptoms on an RDRHX510 - timer list is set for BBC1, but when the time comes it seeks channel 801, finds nothing and fails to record.
    Apologies for error in last comment: I read model number off old nmanual. It was actually on RDR-DC205 if that helps anyone's diagnosis.
  • Carol Marshall Jun 16, 2013
    Nope, it's still doing it. Did it again on Tuesday when I wanted to record BBC2. Think I'll just give up recording BBC programmes.
Obertelli
  • 3006 Answers
SOURCE: Cannot get any digital channels since local digital switch over
The official line on this is that you should try and retune again, but there are some Panasonic models with similar model numbers to yours which have been specifically identified as having incompatibility problems with the Freeview retune.
However, your model is definitely not one which appears on the problem list, so it's worth checking that your aerial wasn't misaligned or damaged during the gales last weekend. In addition the Winter Hill transmitter is currently undergoing work until December which will significantly boost the digital signal and give it HDTV capability, so your box may have have been knocked out of kilter if the current digital service was temporarily operating at restricted capacity. Digital signals are by their nature much weaker than analogue tv and if you have a marginal aerial system which has been up for many years and which feeds a number of televisions in the house then it's definitely a good idea to see about upgrading your aerial system.
The difference in actual parts costs between a top spec aerial system and a poor one are surprisingly low, it's also easily possible with careful design and installation to get a better performance with poor parts than you can get with a poorly designed and installed system using top quality parts. One thing does hold true though: a well designed and installed system using poor parts will only last a few years before needing serious attention but a proper job can last up to thirty years.
If you're sure about your aerial system and retuning does not help, then you'll need to contact Panasonic directly. The first web address below will give you their contact number along with a list of Freeview boxes with known retune issues. A second web address which I've given takes you to an excellent Sheffield based tv aerial company which has an incredibly informative website.
http://news.bbc.co.uk/1/shared/bsp/hi/pdfs/01_10_09_freeview2.pdf
http://www.aerialsandtv.com/index.html#ATVinfo
I hope that you've found my answer to be helpful and ask only that you return the favour by rating my answer.
Posted on Oct 05, 2009
  • 5 Answers
SOURCE: Cannot get freeview anymore
see the solution (which is basically power off, re-scan) at the bottom of this thread
http://www.digitalspy.co.uk/forums/showthread.php?t=911984&highlight=dmr+es20d
worked for me...apparantly a known bug with software 1.14
Posted on Mar 05, 2009
SOURCE: locked out of the menue ,Need to reset command mode
Indeed, I did the same thing.... I did find the answer in the manual!
Here's a copy of it (pg 23):
Set the command mode for the remote so it matches
the command mode for the recorder you set above.
1 Hold down ENTER
2 While holding down ENTER, enter the
command mode code number using the
number buttons.
Command Mode Code number
DVD1 number button 1
DVD2 number button 2
DVD3 number button 3
3 Hold down both the number buttons and
ENTER at the same time for more than 3
seconds.
4 Let up, press RETURN, all done!
Posted on Oct 01, 2009
SOURCE: Motorola VIP1216 DVR and Sony VRD-MC5 Connections for Recording?
I have the same problem currently. I have successfully recorded to the Sony CM5 in the past from my DVR, but no longer can. I have Comcast and wonder if they have changed the DVR firmware and blocked output. Also some broadcasts have something in the signal to stop recording. I got half of my program done, and can't record the rest on DVD. I will try to DVR local news, then record to the Sony, to see if it's a signal issue or something with the Sony. I haven't tried to record from a VCR.
Posted on Nov 14, 2009
Benimur
  • 6966 Answers
SOURCE: I recently installed a Comcast digital adapter to
Hi and welcome to FixYa
Initially, postback the model number of the Comcast digital adapter and the TV.
Offhand, if the Comcast digital adapter is connected to the Sony through a coaxial patchcord, then the Sony would really have to be set to Ch 4 (or 3). Channel selection is done on the Comcast digital adapter. It is not possible to record one channel while viewing another.
Good luck and thank you for asking FixYa
Posted on May 22, 2010
Can not record or playback on sony rdr hxd 890 Help please from a repairer. rdr hxd 890
http://www.sony.co.uk/support/en/product/RDR-HXD890/downloads/FW_DVDR_124 Make sure the ribbon cable going to the laser head from the main board is seated correctly at both ends. Use a scope to verify signals present at the input to the laser. If not then find where it stops on the main board. If it is present then replace the laser mechanism.
Jun 24, 2016 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
My Sony RDR-GX300 DVD Recorder is suddenly only recording the 1st 15 seconds from the DVR. The entire show is on the DVR. I have tried discs that I've used before successfully & new DVD's.
1) pass the Disk cleaner buy to some radio schack, and test it
2) test the cable in another device, and determine if faulty or not.
3) if not clean the terminal from DVD VS TV with c.cleaner
4) otherwise the Syscom inside and another associates circuit is faulty such like record ampl.
go to the repair shop for fix it.
God bless you
Oct 01, 2012 | Sony RDR-GX300 DVD Recorder
Sony hxd890=rec from hdd to dvd
I had the same problem but changed the recording mode to SP. I used a DVD-RW to high speed dub a two hour film and a documentary about a holiday island.
Both dubs were perfect.
Dec 23, 2008 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
Cannot remove caption
Check your menus for removal of this notice. It is there just a PIA to find it!
Sep 09, 2017 | Televison & Video
Press the info button once on the HXD890's remote control (button top right on the main circle in the middle). All should then dissappear.
Nov 25, 2008 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Sony RDR-GX300 DVD Recorder > cant progamme channels to record
is the dvr burner hooked up to cable directly or is it coming from a cable box through video cable or again from coaxle cable?
Nov 24, 2007 | Sony RDR-GX300 DVD Recorder
Open Questions:
Televison & Video Logo
174 people viewed this question
Top Televison & Video Experts
