Smart indicator is not working
I re installed windows and my smart indicators are not working...
  • 7,627 Answers
Need more info? In what, what OS? Upgrade?
Posted on Dec 09, 2012
Can't find install code for philips magnavox smart series plus
Universal remote codes for Philips Magnavox TV are: 0062 0204 0207 0183 0226 0288
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand
Sep 27, 2012 | Philips Smart Plus TP3285C 32" TV
Just installed a GA-PP67A-UD4-B3 mother board because the GA-P67A-UD4 board was dfective. I am running Windows 7, 64 bit. The new MB was a replacement provided by the manufacturer. Now, the Realtek...
Please enter into the BIOS settings and verify if under Integrated Peripherals the setting for Onboard H/W LAN is Enable. As additional step select SMART LAN and see if it will detect you cable lenght and Etehrnet speed. If Smart Lan do not detect anything or you have a bad onboard LAN or the cable, hub, router has a problem.
If SMART LAN will successfully report back some information it means that the issue must be with Windows 7. If it's the case i suggest to completely remove the network card, reboot and re-install the drivers.
Please let me know if you need additional help.
Mar 19, 2011 | Intel Motherboard
My pc would not boot to windows and it indicates error message and also indicates floppy bad and hardware conflict
try changing disc but before booting from cd go to bios settings set boot divice priority 1st boot device to cd rom and second boot device harddisk ok and then go to advance option and enebale S.M.A.R.T option this will solve the problem
and if u have installed windows before and now its not working then take xp cd boot from xp cd then wait dor some time it to load the need files then it will sow u two options 1> if u want to install windiwos xp then press anter 2nd option is if u want to repair then press r you have to press r after pressing r it will take u to dos mode then select the drive on which u have install the operating system for exemple c: then type command chkdsk /r or / f then hit enter
one more thin itis showing u hardware conflit error then remove the device u have recently installed to ur pc this mabe because u have unlike devise on ur system
Mar 16, 2011 | Computers & Internet
Unable to install hp deskjet d2400 series driver
I have a 2400 series HP printer that keeps indicating error and I have no disc. I want to install this and I am not computer smart, how can I do this. Thanks, pegbar12@hotmail.com
Mar 18, 2009 | Office Equipment & Supplies
I cannot scan to windows xp from epson rx425 all in one printer
First switch off printer & uninstall everything including the printer drivers. Download the latest software from Epson Support site & reinstall. Link:
http://esupport.epson-europe.com/SupportHome.aspx?lng=en-GB&data=nKGrQtfEm6mIr17BBoUTdZr5V9BVmX64
Jan 28, 2009 | Epson Stylus RX425 Multifunction...
Bex Bissell Pro Heat 7920-E
Remove the cap for the flow indicator, then there 6 screws to remove to take off the top, before removing the top, turn the smart mix valve to about the half way point so the piston won't fall off. When you are ready to re-install the top cover, just before pushing it all of the way down, turn the smart mix valve to the water only setting, then push it into place, re-install the screws and the flow indicator parts.
May 27, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
Removing the top of the 7901-1 Bissell Proheat
Unscrew the cap for the flow indicator, remove the 6 screws, the top will come off. When you put the top back on, make sure the piston is hooked on the smart mix knob(underneath the top cover) set the smart mix valve in the wtaer only setting, then put the top back on. Turn the smart mix valve to make sure it is turning like it should, then re-install the 6 screws and the flow indicator parts. (don't over tighten the screws)
May 16, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
SMART KIT DRUM CARTRIDGE
Call 1-800-821-2797. Thats a machine software issue..
Here is the note on it.
Problem:
The DRUM and TONER cartridges are not installed correctly. Web page indicates replace %0 empty cartridges. The Machine doesn't copy. Cause:
Firmware and work-process problem. . Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix. Don t worry about cartridges. They are safe. Upgrade firmware. The message goes away and machine copies
Mar 07, 2008 | Xerox WorkCentre 4150 All-In-One Laser...
Computers & Internet Logo
11 people viewed this question
David Payne
David Payne
