Question about Frigidaire Freezers
I have a Model FFU14F5HW Frigidaire Upright Freezer that shutsdown and the controls fault or freeze.
The freezer will run normally for several days, then the door mounted controls will fault or freeze. There is still power to the door mounted electronic thermostat, but the controls will freeze and not respond. The compressor and even the interior light will power down, but the LED display to the controls are still powered. If I unplug the power connection from the wall socket and then reconnect it, the freezer will power back up and operate normally at least for several days. The controls will also operate normally after a power reset. Would you please let me know what could cause this problem and the solution?
watugot
  • 290 Answers
SOURCE: Frigidaire Upright freezer with Beeping Display
First make sure you have a good 9v battery installed. If it is ok then the problem will probably be in the display board or the wiring connectors between the boards. CE is communication error. If your model has the electronic tempature control instead of mechanical thermostat the problem could be in there. My bet is a bad connection at display board.
Posted on Sep 26, 2007
  • 150 Answers
SOURCE: Kenmore Upright Freezer Model 253.9239780 Temp alarm, Temp rising slowly
you have a refrigeration issue partner let her go 16 yrs. is good service you can replace it for 3 to 5 hundred the repair will be that IF you can find someone with the r-12. don't go for a top it off and go deal the food you lose is to expensive for that to be economical.
Posted on Apr 23, 2008
22yooper
  • 828 Answers
SOURCE: Freezer Problem
If it started to cool again the compressor was running. Check the condenser and make sure it is clean. Provide as much air movement through the garage as possible . 100 degrees is a high temperature to be operating a refrigerator in.
Posted on Jun 10, 2008
  • 1314 Answers
SOURCE: My freezer's defrost systems runs constantly
i dont think so i would look at the compressor kicking out on thermal overload or a faulty thermostat thermostats have two settings cut in cut out your cut in could be bad and not turning the compressor on till the temp reaches melting temps now if your hearing a click buzz then you need to look at the compressor and make sure the compressor fan is running but its not a defrost promblem
Posted on Sep 11, 2008
  • 3 Answers
SOURCE: Frigidaire Freeze FFU1764FW0 failed after power brown out.
Yes a power brown out can cause compressor failure. More than likely If there was a power surge it is possible that the overload on the compressor opened. This is a safty device that helps protect the compressor. It usually resets itself but in the cause of a surge it may have burnt up. problem could also be in the relay or thermostat
Posted on Feb 27, 2009
How to install door lock?
Hey Joe, thank you for your inquiry!
I see that you need assistance installing the door lock on your Frigidaire freezer, FFU14F5HW. I was able to locate the parts schematic for you and on page two it provides you a picture of the components for the door lock. I hope this information helps you with your part installation. -Matt
ftp://ftp.electrolux-na.com/ProdInfo_PDF/StCloud/5995626933.pdf
Dec 31, 2015 | Frigidaire FFU14F5HW Frost Free 13.7 Cu....
What freon to use
Hey friend, thank you for the post!
I understand that you are searching for what type of freon is used in your Frigidaire freezer, FFU14F5HW. Based off of that model the freon would be 134A. Hope this information is helpful. -Matt
Jul 23, 2014 | Frigidaire FFU14F5HW Frost Free 13.7 Cu....
Frigidaire FFU14F5HW Hi-Temp alert. Checked thermistor at front panel pins 1 to 2, reading was 162.8K ohms. Removed panel to check thermistor, then put it in a cup of ice water-now reads 32.1K ohms. P
Check the internal temp with a thermometer. Anything above -12c will give you the hi alarm. Check the condenser is clean and drier not too warm, no ice build up inside the evaporator and all fans working properly etc, before suspecting thermistors.
Apr 02, 2014 | Frigidaire FFU14F5HW 13.7 cu. ft. Frost...
Frigidaire LFFU14F5HWH Not Completely Freezing
Maybe It Needs Regasing Some Fridges Have a Swich Between The Fridge And Freezer If They Are Fan Forced That Gives Off The Same Symptom As Being Out Of Gas Or Low On Gas
Nov 06, 2013 | Frigidaire FFU14F5HW Upright Freezers
Just had a new upright Frigidaire freezer delivered two days ago. Plugged it in immediately. It did not get cold after several hours. Turned it off then back on. Unplugged it. Unplugged it for several...
Whenever you get a frig or freezer delivered it is best to wait at least 24hrs (some say 8 hrs) before you plug in. It maybe unknown to you if this was shipped to you in the laying down postion. If it was and you plugged in it will not work because laying down the oil migrated away from the compressor.
Other than that the freezer could have (possible chance but still possible) problems that are out of your control. If you brought it at a retail store you have at least 2 weeks to exchange. Do that a.s.a.p.
Dont bother trying to figure out just exchange!!!
hope this was helpful
Apr 04, 2010 | Frigidaire Freezer Refrigeration White...
Freezers Logo
85 people viewed this question
Top Frigidaire Freezers Experts
AJMAL KHAN
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
