Question about HP Pavilion dv9000z Notebook
Hp pavillion dv9000 screen has got a 2inch vertical light blue band
  • HP Master
  • 7,627 Answers
Have you updated the OS? Changed drivers? Have you tried to roll back the driver? Could be a hardware graphics/monitor issue, heat? Have you connected a external monitor, that would assist you in isolating the problem. Hard to say for sure. Take a look at this from HP support: http://h20000.www2.hp.com/bizsupport/TechSupport/SupportTaskIndex.jsp?lang=en&cc=us&taskId=110&prodSeriesId=1842187&prodTypeId=321957&supportTaskId=22862
Posted on Dec 09, 2012
SOURCE: HP Pavillion dv9000 - won't power up
I had the exact same problem so I called HP support.The instructions were- remove power cord from lap top if power cord is connected, then remove battery, connect power cord to lap top then turn on lap top by holding power button down for 30 seconds. It booted up, no problem. The proceedure is to remove static electricity.
Posted on Dec 19, 2007
oldnovii
  • 667 Answers
SOURCE: HP PAVILLION dv 9000 laptop new bios instalation instructions
Would you mind just adding a comment to this post. Please just copy the text body part of the email and paste in a comment. No need for your name or email addy or personal info. Also please tell me which operating system you are using. Thanks.
Posted on Mar 28, 2008
SOURCE: HP Pavillion dv9000 won't boot up
My 18 month old HP Pavilion dv9803nr Notebook PC will not boot up. It tries to then the light flick off and then on and tries again and again but nothing.
Posted on Oct 18, 2008
jmgldsmth
  • 2005 Answers
before you spend $200 for a new lcd screen; may I interject; Please test your computer by hooking it up to another monitor if you get the same result; place your computer in the freezer for about an hour then start it as this model of computer is famous for overheating the nvidia video chip also the tiny fluorescent tube called a cold cathode has beeb found to glow red when about to fail the cathode can be purchased onlin at: laptoppartsdirect.com or, e-bay almost always the only reason to replace you lcd is: breakage or, bad pixels.
Posted on Apr 26, 2009
  • 111 Answers
SOURCE: hp pavillion dv9000 won't boot. tries to start,
There is a Limited Enhancement Program that includes this model. If you are in the US call 1-800-474-6836. If you are outside US check the HP.com website and search for the Limited warranty enhancement Program.
This is normally a video chipset issue that is embedded in your MB. If your notebook is part of the program, hp will shoulder the repair cost for the MB replacement.
Please vote, Thanks!
Posted on Jun 27, 2009
HP Pavillion dv9000. Intermittent stops. Cannot restart, but will do so after many hours. Screen turns blue with band of torn blue that looks like shutters. System carries out repair check - once worked...
Try booting your computer in safe mode... when your machine starts press F8 and go to Windows. Run for a couple of hours and see if this problem happens.
If you have system restore running, restore back to a point when you didnt have the problem
May 17, 2010 | HP Pavilion dv9000z Notebook
I have a 2inch wide band down middle of screen on
1) Have you installed new drivers or software or drivers? If so, remove them and restart the computer.
2) Try applying pressure with your fingers on top of the screen. If the band dissapears or dimishes, you may have a broken screen and it will need to be replaced.
Mar 19, 2010 | HP Pavilion zd8000 Notebook
Hp pavillion dv9000 lcd screen changes colour when moved
The inverter is to change the volts from the laptop to the Backlight. This wont have anything to do with it.
Im more than certian it will be the LCD cable. Proberly loose or torn at where the lid closes.
Hope this helps.
James
Feb 23, 2010 | HP Computers & Internet
Blue lights come on but screen will not come on or
see care fully at ur screen with in some external light
u see somthing check ur laptop to an external monitor
if working?now ur lcd problem
Jan 27, 2010 | HP Pavilion dv9000z Notebook
You have an Intel-based laptop (sounds like it).
The failure is due to the vram on the mlb (systemboard). Good news is this is a common failure for the Intel's and is readily fixed, prob is the vram and nVidia chip need to be reflowed using a BGA machine (about the price of a Lexus).
Without a viable repair option, you'll need to replace the mlb. Part# located in the memory bay (middle cover underneath the laptop), and expect to pay upwards of $450 from HP for just the part. *** BEWARE getting this part from a 3rd-party vendor, as they may NOT have reflowed the chips and have the issue resolved
-Sy
Jun 06, 2009 | HP Pavilion dv9000z Notebook
Vertical white lines appear on screen and music will play, beeping and a "chopper" noise have also occured. Replaced motherboard in Dec 08.
To isolate the issue.please connect the notebook to external monitor with the help of VGA port.(Blue PORT) on the notebook.if it good with out any lines.you need to fix the LCD screen of the Notebook.
May 10, 2009 | HP Pavillion ZV6000 Notebook
Hp pavillion dv9000- cd/dvd rw drive not working
you have to send it back to hp to get it fixed, this is the second time mine had the same problem
May 10, 2009 | HP Pavillion DV9060US Notebook
Problem with hp laptop dv9000
boot into safe mode and dump that driver and reinstall it or update it... and i can relate to the india customer service thing (there has got to be a better way)..
Jan 08, 2009 | HP Computers & Internet
HP Pavillion DV9000
Howdy,
Like you said if you purchase it 5 month ago it should still be under the warranty. if i were you i will go that route
Dec 30, 2008 | HP Pavilion dv9000z Notebook
HP Pavilion dv9000z Notebook Logo
70 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
