A correctly programmed universal remote should provide the basics, including switching it from standby to on but the original remote or a dedicated remote will be needed to access the menus.
I bought a dedicated remote from a company advertising on Amazon or ebay at a surprisingly reasonable price...
Unfortunately Without the cable box you will have to screw the coax cable into the coax input on the tv or You can screw the coax cable into a vcr and then plug the Audio / Video RCA plugs from VCR out to TV RCA input (You will have to control the channels from the VCR and the volume from the TV remote)
hello! refer to your TVs owners manual. You will find codes for common set top boxes there. all the new TV remotes are universal. If you see "cable" or "cbl" button on remote, you will be able to do so. Worst case scenario: you need to buy universal remote or use your cable box's remote to control basic functions on TV. Codes for TVs are included with cable box's remote control. Or, you can call your provider and ask for "Sony Bravia"codes. If you have a satellite box, codes are supplied right inside "setup" menu of the box. Good luck, Alex.
But u still have and pay for the basic cable service wright?Yes,just used the tv remote and push the remote menu button than go into the tv menu,go into Setup enter and go down and pick CABLE not AIR.Enter for the tv do scanning for cables channels.After finish scanning u will get all the basic cable channels.
OK - please follow these instructions carefully to setup the Freeview box. If you get stuck at any point in the instructions - or anything I've said doesn't make sense or match what you can see - just post another message here and I'll deal with each problem as it arises.
1. Switch the TV and Freeview box to STANDBY. There should be a red light on the Freeview box; 2. Connect the aerial cable to the freeview box. Make sure you are connecting this to the correct socket. This should be labelled "RF IN", "IN" or "Aerial/Antenna". If you have connected to a socket marked "RF/TV OUT" or "TO TV" or something similar, it wont work; 3. Connect the SCART cable to Freeview box and the back of the TV; 4. Switch the TV on; 5. Switch the Freeview box on - you should get a green light on the front of the box;
Most TVs will automatically switch to the external input when a SCART device is switched on while the TV is already on. This is why you should switch the TV on first.
At this point you should be able to see the installation / setup screen for the Freeview box displayed on your TV. If you cannot see this:
A. Press the INPUT button once on your SAMSUNG remote control once. This is the button in the top-right corner of your remote control. B. If you still cannot see the installation / setup screen, press the MENU or SETUP button on the remote control supplied with the Freeview box.
The instructions from this point forward will be different if you had to press the MENU / SETUP button on the Freeview remote before anything appeared on the TV screen. If this Freeview box has been used before the installation screen will not appear, but you will get at on-screen menu after pressing the MENU / SETUP button. If this happens, please let me know and I will provide alternative instructions for setup.
Assuming you have been able to access the installation screen, it should be easy enough to follow the instructions on screen from this point. Use the UP / DOWN / LEFT / RIGHT arrow keys on the Freeview remote to highlight the relevant options and then press OK / SELECT to choose that option.
I don't want to make this too complicated by providing alternative instructions for every possible scenario. Please run through the instructions above and make sure you are getting an installation screen or "menu/list" displayed on the TV. If you need further instructions from there, I will provide them in another message.
If you only wish to power the TV off/on with the remote, there is an alternative. Plug the TV into the outlet on the back of the Comcast box. In the Setup Menu for the Comcast box there is an option to make the outlet switched or unswitched. Select SWITCHED then the TV will turn on/off with the Comcast box. The
LC320em9 will maintain the previously selected input.
Press and hold TV until the LCD blinks then try each code and in
between press standby, when the TV turns off that will be the right
code. May
work for you, if not post back
