Question about Toshiba 50HP66 50 in. Plasma Television
I have sound, but no picture. It just blinks, with a faded back ground
It work fine last night. Just turned it on this morning. When I try and use the remote for the tv, to see menu, I can bearlt see it, because of the blinking
  • martinkjol
    martinkjol Dec 10, 2012
    Thank you, but that didn't help
    Top Expert:
  • Toshiba Master
  • 14,553 Answers
Try to unplug set and or a box if used from power for a while, plug both back and see if a reboot that will happen helps or not.
Posted on Dec 10, 2012
  • 52 Answers
SOURCE: Red Blinking Light
These types of problems are allways hard to diagnose.. If you were to power on the set and preform tests, you would think that everything was fine until the moment it shuts off.
Look on the main power board and see if you cant find the thyristor (thermal switch), those are the things that when heated will cause the set to power off for safety reasons.. They are normally placed where ever a large heatsink is. That may give you a location as to the problem and you can put a meter around its 2 pins with the set off and unplugged a couple of min after failure, if its short (0 ohms) thats not the problem, if its open, it triggered the event.
Second, you can run the set for a while and check the voltages and Ve, Va, VCC, Vsetup etc and compair to the markings on the plasma PDP sticker. If you see one is falling down over time (volts will be lost as heat) then you can isolate that portion of the supply.
Third and allways the best way to go about these problems is buy a thermal gun and moniter various spots for heat.
Its just vary hard to say, resistance could be off somewhere, diodes could be overheating as well as fets and caps. Thats why a good thermal gun can point you to exactly where the problem is.
Hope this info helps, but I would suspect the problem is on the main power supply itself and not the y sus and z sus boards side boards.
Posted on Aug 26, 2008
dsacco86
  • 1077 Answers
SOURCE: The picture blinks on for just a second, then goes
The most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Posted on Jun 28, 2009
  • 308 Answers
SOURCE: I have a Toshiba 32av500u HD LCD TV.NO picture
Its a backlight problem. Common with this model. Under warranty? If not, then its a service shop repair.
Posted on Mar 26, 2010
  • 144 Answers
SOURCE: RED LIGHT KEEPS BLINKING..WAS LIKE A POWER SURGE
Surge protectors aren't perfect... If the surge was big enough and long enough then it can cause problems. Most manufacturers have on-board protection as well. That's not perfect either. Often the surge does nothing more than confuse the microprocessor (computer) that controls all aspects of your television. The fact that the red light is blinking means that your set is trying to protect itself. This can happen for one of two reasons. Something in the set has failed. Usually the power supply inside the set possibly also a trouble in the scan section of your set. These are normally a shop repair. The other thing is when the microprocessor is confused it will do nothing further until it's reset. To reset the processor simply unplug the set from the wall and wait 10 minutes. Plug it back in and if it works then happy viewing. If it doesn't then you will need a repair.
If is a failure caused by a failure in the grid that delivers power to your set then you are usually able to file a claim for the repairs. Contact your local power company. explain what happened. If it's their fault then usually they will pay for a repair. I know the PG&E does.
Zashiban
Posted on Jun 23, 2010
budmrtn
  • 11361 Answers
SOURCE: i have a toshiba 37 wlt 58 lcd tv . i watched the
Sections of the power supply may have gone out, or it detects short circuits in the backlight inverter board or in the power supply itself.
Those are the two areas you need to check. Look fo bad caps with leaking/bulging top fist in the power supply.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Posted on Aug 13, 2010
Samsung Plasma PN59D8000FF no picture no sound
Generally if the power lamp is on but the set is dead its the power board, you could remove the back if your comfortable doing so and check the voltages going from the power board and see if any are missing or incorrect...good luck!
Nov 25, 2017 | Samsung Televison & Video
My sony trinitron is blinking red and won't turn on
THIS IS NORMALY CAPACITORS IN THE POWER SUPPLY THAT NEED REPLACING
Jun 25, 2013 | Sony FD Trinitron WEGA KV-34HS510 34" TV
Cant get the power to turn on,worked fine last night, it got unplugged, this morning plugged in, won't turn on and the power button just flashse
Flashing is either an error code or the set trying to boot up--some of the Mitsubishi sets if power removed will blink for a minute and then stop--then the set can be turned on.
a model number?
Apr 28, 2012 | Mitsubishi Televison & Video
Maganavox flat screen tv no pic, red light blink codes...
Those blinks are fault codes. To know more visit the site linked here. http://electronicshelponline.blogspot.com/
Mar 25, 2017 | Televison & Video
Worked fine lastnight but this morning when I tried to turn it on there was no picture, but there is sound
TRY UNPLUGGING IT FOR FIFTEEN MINUTES THEN REPLUG IT IN,KNOW IT SOUNDS STUPID BUT WORKS SOMETIMES
May 21, 2009 | RCA L42WD250 42 in. LCD HDTV
Sound but no picture
check with a flashlight against the screen for picture, if present backlight inverter has failed.
Dec 07, 2008 | iLO 3200 32 in. LCD Television
Power button is green - no blinks / no picture / no sound
Unplug it from the wall, wait 2 minutes and plug it back in. if problem still exists, its probably the main pcb.
Jun 19, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
Toshiba 50HP66 50 in. Plasma Television Logo
48 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
