Sea Foam is NOT a gas Stabilizer. Your carburetor jet needs to be cleaned.
MAny Carbs are set up tis way, not sure about your CC snowblower. The jet in the Carb is gummed up. Take that 1/2" bolt off the bottom of the Bowl..That IS the Jet. Many times the Bowl will just hold in place with the Bolt out.. make sure the three holes are clear. 2 are close to the head of this bolt and you should have a 3rd real small hole where the threads end. Screw it back in...see what happens
SOURCE: cub cadet 18m, one year old won't start
try cleaning the air filter and make sure no grass is stuck under the guards (build up) do this while not running of course lol
