Question about Team Up International Team Up Tony Stewart 1:32 Scale Remote Control Car
Need replacement parts for team up international 1/6 nascar
Plastic drive differential gear
After placing my driveshaft my speedometer is not working HELP PLEASE
It isn't usually necessary to disturb either the speedo drive gear or driven gear when replacing a driveshaft so I am wondering if your car is an exotic or unusual model.
I seem to remember seeing one model where the speedo drive gear was a plastic ring-gear that was very exposed with the driveshaft removed and easily displaced from the side of the final drive differential by the careless refitting of the shaft.
If you remove the driven gear you should be able to see or feel the drive gear and ensure it is in line, still firmly attached and rotates when the road wheel is turned.
If all is ok there then the trouble is with the driven parts whether mechanical or electronic.
Feb 06, 2015 | Cars & Trucks
Is timing set dot to dot on 1954 , 6-cylinder engine
what motor are you working on? lots of chevy 6's out there.
Dec 31, 2014 | Team International Rien's Stock Car...
Cant log in TO SUN DREAM TEAM tried on google and google chrome help please
well i would go to NASCAR.com, and look there first , under your team driver's name should have all the cars, and other pieces to buy
hope this helps
Aug 12, 2013 | Team International Mark Martin #6 Soaring...
REMOVEING DIFFERENTIAL ON A 1999 300M FRONT WHEEL DRIVE
The diff is part of the trans axle automatic transmission assembly and is not a separate part that can be removed.
Oct 10, 2012 | Cars & Trucks
Hawk talon v3 - bottom rotor won't spin
I just got one for Christmas too. Had it flying for 10 seconds, and lost control. I have to work on my piloting skills! After that initial crash, I prepared for another take off and realized my lower rotor was not spinning. It turns out that the tiny vertical gear that powers the lower rotor gear fell off its axle. The axle is connected to the sensor that receives the signal from the throttle. Luckily, I found that tiny gear sitting inside the head of my helicopter. After spending 2 hours trying to place it back on the axle, I got it running again. The rotor was spinning again, but it wouldn't take off. I did some troubleshooting, adjusting the trim multiple times. Then the gear fell off again. I found it and noticed that I had damaged the plastic teeth from using my tweezers to reinstall it. You can go to Team-RC.com to buy a complete gear system for $6.95. You won't need to replace all of the gears, just the one that fell off, and it's always a good idea to have spare parts just in case.
Happy flying
P.
Dec 28, 2010 | Team International Hawk Talon V3 RC Indoor...
Gear needed
Call 1-800-524-0799 at Royal for parts assistance.
Jun 03, 2010 | Royal 15MX Shredder
My Hamilton Beach Food processor model # 702-1 has a BROKEN plastic gear that attaches to the motor drive shaft (it threads onto the shaft). It meshes with another plastic gear that turns the spindle that...
my suggestion is that watever spare part u replace, get it replaced by the original manufacturer to avoid future problems. take it to the shop you have bought it from, ask them where u can get one. they may help u better with contacting the manufacturer. i know its time consuming! good luck!!
Oct 14, 2009 | Food Processors
Needs more power for a 98 toyota tacoma 4 cylendar
If ur talking 50 mph in just first gear etc,Go see Don Gartlet or a Nascar Team
Oct 02, 2009 | 1998 Toyota Tacoma
The odometer crapped out on me again. I got about 5K miles on the replacement and now... plastic gears that run it can't take the wear I guess, suggestions?
I had a 1994 Crown Vic and 165000 miles on it and never a problem with speedo. You need to replace the cable and the gear next time. I guess you know to get the correct transmission plastic gear for your size differential.
If the part keeps getting chewed up the drive gear in the trans must be chipped.
Aug 13, 2009 | 1993 Mercury Grand Marquis
I have a TroyBilt electric chain saw and need geardrive
Your manual downloads from MTDProducts.com. This is the parts outlet for MTD. Troy-built is listed here:
http://www.buymtdonline.com/webapp/wcs/stores/servlet/Home_BuyMTDOnline_10101_19502_-1
I clicked"
PARTS CATALOG "Troy-Bilt" enter
FIND YOUR PART "OPTION 1:" click the wrench
Model Name/Number: I entered "tb4516" and your parts list appears.
Your manual lists this phone number 1 (800) 520-5520. Please try them if the above isn't satisfactory.
GL
Lou
Jun 03, 2009 | Desa International 100089 06 Electric...
Team Up International Team Up Tony Stewart 1:32 Scale Remote Control Car Logo
206 people viewed this question
Top Team Up International Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Team Up International Toy Expert? Answer questions, earn points and help others
