Most likely 240volts as most 120 volt dryers are already wired,depending on if its a 3 or 4 wire system depending on local electrical codes,but if its a 3 wire cord,take the RED to terminal L1 and Black to L2 terminal on the dryer terminal board HINT:(the RED and Black can go on either L1 or L2 they are interchangable) ,then the White wire to the N neutral terminal on the dryer terminal board usuall between the L1 and L2 terminal,if theres a Green Wire on the cord this is safety ground and can be attached to any metallic part on the dryer,if its a gray flat cord the 2 outside wires are L1 and L2 the center is Neutral,
so its:
RED=L1 or L2
BLACK=L1 or L2
WHITE=N or Neutral
GREEN=Safety Ground the metal dryer frame
is it 240 volt or 110 volt supply
