Question about Akai PT4298HD Rear Projection Television
Aaki 42" red line
That info. was great and worked except for the red line I figured thats what you meant mute 1-8-3, I get 83% on perfect picture is that good enough or will 100 get rid of the line thanks again code-r-1
  • the_kane89 Jan 17, 2009
    what can i do to fix this the red line is wavy on the vertical portion of the perfect focus
    Champion:
  • 240 Answers
I only gave you the info I had on hand I dont have the tech manual, you might find one on line for proper setings in this tech mode.
Posted on Jan 13, 2009
Brown mute wire for new ken wood in 2002 rodeo, does it go with illumination wire, green/red or red/green?
Hi, i'll need a bit more info to be able to give you an opinion , am i correct in assuming the "new kenwood " is a radio/cd player ? If so do you have a car phone or a hands free kit for your mobile/cell phone ? Assuming the kenwood is a radio the mute wire has to be connected to the car phone/mobile hands free kit , this is usually described in the phone installation directions , how the mute system works is when you recieve a call the signal is sent via the phone system to the radio , which is where the mute wire comes into use .If you have either of the phone set ups i've described post back with there details , make , model etc ,if you do not have this type of system and are using an ear piece then the mute funtion can't be used , i hope this is of some help to you
Apr 06, 2015 | 2002 Isuzu Rodeo
Black and white picture with red lines vibrating with sound.
More info would be nice. Are you using HDMI or Component cables. If it is component cables (red, blue, green for video white and red for audio) Check your red and blue connection. Green alone will give you a black and white picture.
If you are using an HDMI cable, replace the cable to see if this changes anything or if you have another tv swap cables to see if problem stays with tv or moves to another tv.
Feb 08, 2013 | Hitachi 46F500 46" Rear Projection...
Canon powershot a470 vertical lines, white picture, blurred
The image sensor is defective. There is no quick fix other than replacing the image sensor.
May 13, 2017 | Canon PowerShot A470 Digital Camera
Flickers after 5min of use. Perfect sound, turns on fine and excellent picture quality when in blue screen menu mode. Why?
This intermittent problem is very difficult to rectify. Just contact the authorised service center for Hitachi at your town. The work is really a skilled one, that a user cannot do it with ease.
Jul 13, 2012 | Hitachi 42PD6600 42 in. HD-Ready Plasma...
Picture is perfect except for the 3" wide black
poor contact in the vedio connector , open the cover and rmove it , clean the connector and reinstall again
Nov 06, 2010 | Panasonic Viera TH-42PZ80U Plasma TV
Hi - my machine works perfect except that it has
I posted this same solution for another inquiry but I will state it again in case you can't find it. I tried everything as well to try and get my machine (only used twice) to **** up the dirty water and I couldnt' fix the problem - there was no suction at all. Then I discovered there is a tiny (about 1 inch square) red plastic filter that is in the removable section that has the round dial to switch from floor to tool. As I said, it is a small red plastic square and there is a little door on it. If you flip it open (It actually looks like it can be removed) you will probably find a bunch of hair or carpet fluff. Mine was completely blocked. Remove the stuff and your machine should now **** up the water perfectly. I hope this helps - it took me a long time to figure this thing out!
Sep 06, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Green & Blue Ghosting Convergance problem
Odds are real good that the cooling fluid in the green and blue picture tube assemblies has become contaminated. You can tell by looking down into the lenses with a flash light. Funny thing is the red never gets contaminated because whatever organism is causing the problem can't survive in red light. BTW this may still not solve all of your convergence problems but when the colors are so badly diffused the convergence sensors for flash focus can't lock onto the beam landing.
Jun 01, 2009 | Samsung HCL473W 47" Rear Projection...
How do i realine the bulb in my samsung rear projection tv
use you're remote to enter code mute 183 while tv is on then press 7 for red 8 for green and 9 for blue control. arrows or knobbie will move cursor. if you still can not control the red you will need to change the red convergence ic...press perfect focus to save changes if pf is not on remote maybe on tv if neither you will need to get a remote that has it to save info.
Jan 27, 2009 | Samsung HCM4215W 42" Rear Projection...
Red line running through tv screen when tv is on
The individual dots (pixels) that make up the picture are controlled by vertical and horizontal drivers that are rapidly switched off and on. They are arranged as columns and rows with these further controlled in time in a synchronized fashion. The line is being caused by a driver that is failing.
Depending on the degree of integration, these final integrated circuits may be part of the display and not individually replaceable by hand. You may only have the option of replacing the screen with the failed part.
It will be necessary to contact Sanyo (who may not have manufactured the set) to find whether the repair is cost effective.
Sep 27, 2008 | Sanyo DP42746 42 in. Plasma Television
Perfect Focus Not Working- Picture is Blurred
· Samsung parts for convergance problem
· http://www.partstore.com/Part/Samsung/Samsung/BP9500142E/New.aspx
Nov 11, 2007 | Samsung HCN4226W 42" Rear Projection...
Akai PT4298HD Rear Projection Television Logo
48 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
