Question about Sharp R-1480 Microwave Oven
Sharp Carousel 1000 Watt
I was cleaning the microwave with a clean bowl of water after 6:00 the microwave just stop working! I have un-plugged and let the unit cool off. I plugged the unit in and no lights no displays NOTHING
    President:
  • 2,992 Answers
There are a fuse and a couple of other devices which could go bad and kill power to the rest of the oven. Once any of these protective devices goes bad, until it's replaced the oven will be dead.
One of these is a thermal fuse which opens if the magnetron tube (the part that generates the microwave) overheats. It's possible this is the culprit since you say the oven cut off after several minutes of operation. I don't know how old your oven is or how much you've used it, but as the magnetron ages it gets hotter as it operates (working harder), and this could cause that fuse to go.
Someone with an ohmmeter and some experience with testing electrical parts could determine which of the parts is causing the trouble. Replacements are available from appliance parts stores and online vendors. But working on a microwave can be dangerous, so you might want to get an estimate from a service shop if have the least doubts about trying self-repair.
Posted on Jan 25, 2009
Hurricane irma, have electric, sharp carousel microwave willnot program any ideas
Un plug for a few minutes, plug back in, set the clock ( time of day) try again.
Sep 28, 2017 | Sharp Microwave Ovens
How do i remove the display on a sharp carousel microwave in order to get roaches out?
Take of the main cover and turn upside down and give it a good shake to clean out.
Jan 09, 2015 | Sharp Carousel R530EST Microwave Oven
Sharp carousel microwave
Sometimes, bits of food get behind the microwave generator mica cover and cause this EXACT problem they short out the microwave energy and spark. . It is NOT broken but DONT let this happen for more than a few seconds. !!!! You will see the Mica (looks like plastic) cover from inside the oven and will be on one of the sides.It looks oblong normally, It is actually transparent to Microwaves and is how they get from the generator in to the oven. Give it a real good clean around the edges or better still take it out to clean. and it should be fine
Aug 25, 2014 | Sharp Carousel R530EST Microwave Oven
How do I set this microwave to defrost a whole frozen chicken - 4.5 lbs?
I wouldn't. Let it defrost i the fridge or if you are in a hurry, cold running water in a bowl in the sink. Microwave ovens cause warm spots and a health hazzard
Mar 08, 2011 | Sharp Carousel R530EST Microwave Oven
I have a Sharp Carousel over the range microwave model R -1601. I cleaned it and now it sparks when we try to use it. What can I do to fix this problem?
The cleaning operation may have spread metal particles or other conductive materials on the walls/floor of the cooking cavity. Try wiping the entire cavity with a damp, clean cloth, then heat a cup of water for a test. Hope this helps!
May 24, 2010 | Microwave Ovens
Roller Stay for Sharp Carousel microwave oven
u can try www.partstore.com
but the tray roller is pretty much univeraql if you have problems finding it for that model alost any sharp tray roller will fit the unti
i just grabbed one out of the dump for my personal un it and it works fine
Oct 09, 2009 | Sharp KB6024MK 1000 Watts Microwave Oven
Sharp Carousel Model R-1440 won't shut off
Take it immediately to a local Microwave repair shop...looks like one of the circuits may have gone...otherwise switch off from mains
Sep 28, 2009 | Sharp R-1480 Microwave Oven
Sharp R-1480 Microwave Oven Logo
122 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
