Question about Nikon S8100 Digital Camera
Reset nikon coolpix s8100 to factory settings
  • 10 Answers
SOURCE: how to reset to the factory settings?
turn camera on, turn upper dial to setup, have the display on, use the up/down arrows on the back of the camera to click to RESET ALL, use the side arrow to to click to the reset box, either NO or RESET.
Posted on Jan 30, 2009
  • 11967 Answers
SOURCE: Nikon Coolpix p80 blacked out, rounded corners
Have you attached some sort of lens shade to the front of the lens? The vibration might have something to do with the shake reduction system but I can't be sure. It certainly shouldn't vibrate heavily. You might get a better answer if you e-mail the tech guys at the support section of the Nikon website.
Posted on Feb 19, 2010
eagle338
  • 4889 Answers
SOURCE: Just bought a Nikon Coolpix S8100. After
You will need to install a codec pack on your computer to resolve this problem. Download and install the codec pack from the link below and see if it resolves the issue.
http://www.free-codecs.com/download/k_lite_mega_codec_pack.htm
Posted on Dec 10, 2010
  • 102366 Answers
SOURCE: How can I stamp date
Press the MENU button. Select Setup (the wrench icon). Select "Date Imprint".
Posted on Feb 24, 2011
  • 214 Answers
SOURCE: nikon coolpix s70 has blurry pictures even after
Hi you have lens unit defective. Even if you didn't damaged and dropped, its appearance problem is the lens unit, you can bring to your local repair shop. It is quite easy problem. some point they could save part, but time is money. they would want to change the part. your part from nikon usa is very expensive, but from ebay it is very cheap. It is used but it would be reliable in most case. http://cgi.ebay.com/Camera-LENS-ZOOM-UNIT-Nikon-Coolpix-S70-BLACK-/180672085419?pt=Digital_Camera_Accessories&hash=item2a10e53dab#ht_500wt_1156 If you buy and bring it with camera to your local repair shop, they would charge less labor then you bring camera only. repair shop would consider that you know what it is going on. Thanks and kindly! ( labor they would charge around $25 to 75 depend on what they want to charge)
Posted on Jun 02, 2011
My Nikon coolpix s8100 camera will not keep the sd card inside. It is not locking the card when I try to insert it.
Have you tried inserting it in the opposite direction, if the flash card's label faces left, turn it to face the right as it's designed to be inserted only one way. If this does not work, shine a flashlight into the cavity as a foreign object may have fallen inside.
Dec 22, 2013 | Nikon Coolpix S8100 Digital Camera
Nikon coolpix S8100 won't power on even with new battery.
10 replace batteries or recharged very well the batteries.
2) clean very well the contacts batteries from oxide, dust, dirty. or corrosion
3) batteries loaded in WRON direction
4) batteries is NOT the right type
5) poor contact between battery and cover , clean and adjust it .
6) Memory card slot/battery covert is open
God bless you
Jul 31, 2012 | Nikon Coolpix S8100 Gold Digital Camera...
Nikon Coolpix S8100 battery won't charge
I have had mine for over 3 years and this just started happening. I bought a new battery and it seemed to fix the problem for about a week but is doing it again. It seems like it won't fully charge now like it formerly did!
Apr 24, 2012 | Nikon Coolpix S8100 Black Digital...
Nikon Coolpix S8100 and when I turn it on it says Mode Dial is not in proper position
Return the camera right away, it is clear this is a manufacture defect, nothing more can be done.
Mar 22, 2012 | Nikon S8100 Digital Camera
How do I fix my Nikon COOLPIX S8100 flash
Check the camers's flash setting, make sure the flash has not been turned off.
Also check the batteries, make sure they are fully charged, a low charged battery will not charge up the flash capacitors.
Nov 17, 2011 | Cameras
Nikon coolpix s8100 will not turn on. i have only used the camera a few times, and it was recently charged. is there a manual reset button? or do i need to send the camera back to nikon?
If it won't turn on, you're not going to be able to reset it.
Other than sending it back, the only suggestion I can make is do you have or can you borrow a spare battery. If so, try that. It could just be a failed battery.
Aug 26, 2011 | Nikon COOLPIX S8000 Digital Camera
How can I stamp date on pictures using Nikon CoolPix S8100 camera
Dec 10, 2010 | Nikon S8100 Digital Camera
Nikon S8100 Digital Camera Logo
94 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
