Question about Toys
Need usb cable for blue hat toy company mp3 player 2008. can I use any cable that will fit?
I bought my MP3 player at Goodwill for 2.99. I had no idea if it worked or not. I was quite surprised when it did once I put in fresh batteries. I have no USB cable for it nor do I have instructions. Will a generic cable work and does anyone have a site for the instructions on use?
  • 3 Answers
SOURCE: Blue Hat Toy company mp3 player cannot download new songs
My daughter got one for xmas and it was easy to add songs. She loves it and her older brother wants one too.
I wish we adults could get a big one(like the old jam boxes).....cause it allows listening without headphones.
Besides being able to only select or listen to the songs sequentially, the only other drawback of the radio, that I see, is that the storage space(memory) for songs is internal 256k. It would be better to have had a slot for SD or mini SD chips.
GUEST and GPAANGEL:
Sounds like you are using the wrong type of files. If you bought the songs from itunes, you'll have to find something that converts those files to standard *.mp3 format or windows media player format.
When buying songs online, I also purchase my songs as *.mp3 format. Itunes will convert the files when added to the itune library.
The blue hat mp3 player acts like a disk only and will allow you to copy the files to it. It will not convert them.
MELANIEBECK:
You are probably putting too many songs on it. Did any work for you? Remember they have to be *.mp3 files.
What I did was... after connecting to computer. I located the drive assigned to it and right-clicked on it to see its properties. Then I knew how much free space it had(with the factory songs already on it). I had to select a subset of the songs my daughter likes and forego any that were too big.
I also copied the factory songs to my computer in case the radio goes bad, we'll still have the songs.
NOTE to all: To be able to add more than 125 songs you can probably get away with converting your music to 96 bit rate. Since the unit is so small and not very loud, you don't necessarily need the best quality of music. I noticed the factory songs are at 160 bit rate. I have most of my older music at 128 (which is suppose to be the minimum quality = to CD quality). Anything above 128 is better for higher quality sound systems. I do have my new songs stored at 196 bit rate.
When converting my kids CDs, I will convert them to 196 and store on a hard drive(as a back up to the CD). For this new mp3 player, I plan on putting music at 96 bit rate. This will allow for more music to fit on it.
Good luck.
Posted on Jan 09, 2009
SOURCE: Blue Hat toy company mp3 player won't turn on
This solution may not make you any happier, but I had the same problem. The issue is that the batteries are not sending power to the player. Before reading any further, check that the batteries are installed correctly. Anywhere there's a spring in the battery box, the negative end of the battery should be touching the spring (negative is the flat end of the battery, not the end with the bump).
If that doesn't help, what I did was to take apart the toy. Yes, this voids warranties, but I'm not willing to spend time chasing down this company for warranty service when I didn't keep my receipt. The small rubber circles on the back of the player cover the screw holes. Just get something under them and pry up until you have uncovered all 9 screws. Carefully open the case. Inspect the wires that go from the battery case to the circuit board, and from the circuit board to the on/off switch. One of these wires has probably come off because it was badly soldered. Either that, or a wire was pinched until it broke inside the insulation. You can usually see where a wire was pinched. Have someone who knows how to solder replace the suspect wires. Once I did this, my player started working again, and now I know the solder joints will all hold for the life of the device!
*WARNING! Only disconnect and reconnect one wire at a time. If you get wires reversed, not only can you break the device, but the wires the company originally used are too thin and can overheat and melt, potentially causing a fire. This is also a reason to be sure the batteries are removed when soldering...
Posted on Feb 25, 2009
SOURCE: teach & talk activity laptop by Blue hat Toy Company
I sent an email to carrie@merchsource.com which is customer service for Blue Hat Toy Company. She emailed me a PDF file manual for the Teach and Talk Laptop. Without the manual you would never be able to get the game functions figured out.....
If you need the manual I would be happy to forward the pdf file to you.
Becky
Becky_Minardi@hotmail.com
Posted on Mar 13, 2009
SOURCE: Blue Hat Toy Company ATM - help! No setup instructions!
ok i hit the rest button on the back of the machine and it erased all my memory off of it so i had to reprogram it .If u put 1234 in as a pin # it will open then press balance and hit enter and u can change your pin # there .
Posted on Oct 27, 2009
SOURCE: Discovery Kids digital mp3 boombox does not work
I have solved the issue, well I should say my 2 year old daughter solved it. When you turn it on and the screen remains blank, you have to hold in the green music note button for a couple seconds. Simply pressing and releasing the button does not work, you have to hold it in. I had 2 separate players with this issue and it has resolved it for both.
Posted on Jan 17, 2010
Where can I get a usb cable for audiodream mp3
To get the usb cable for your MP3 you need to cantact packard bell on link below.
http://packardbell.co.uk/company/contact.html
Good Luck and please rate 4 thumbs for the free answer
Mar 30, 2010 | Packard Bell AudioDream MP3 Player
Downloading music from itunes to Little Tunes MP3 Music Boom Box
delete all the existing songs inside your MP3 player and check by installing all the songs freshly
Mar 15, 2010 | Apple 13-inch MacBook - Intel 2.0GHz Intel...
Need a drawing of the wires inside the Blue Hat Toy Co MP3 player
Try the red on top and black on bottom if that don't work switch them around
Jun 03, 2009 | Sharper Image Blue Hat Toy Company Kids...
Can't erase songs from Blue Hat MP3 &they play shuffled
type the song first letter and u can see title and select the song and go for option and delete it
Feb 24, 2009 | Sharper Image Blue Hat Toy Company Kids...
Feb 06, 2009 | Sharper Image Blue Hat Toy Company Kids...
Blue Hat Company Mp3's volume dosen't work
You may try resoldering all of the connections on the volume knob circuit board. If one of the potentiometer (volume control) connections has broken free of the board, it may not be noticeable, but may hold the component off the board just enough to cause the problem you're having. If that doesn't help, the problem is most likely in the potentiometer itself, and you won't be able to replace it easily.
(If you are going to replace the whole player, I've heard that the sweetpea 3 is a better device. My Blue Hat is still working after making some repairs, so I haven't tried the Sweetpea yet...)
Jan 09, 2009 | Sharper Image Blue Hat Toy Company Kids...
the player users the older mp3 format - go look in file view at the extension.  the files you want to add you need to have in that same format.  I *think* (not 100% positive, I didn't do the upload) if you just rename the mp4 to mp3s that they will then play fine
Jan 07, 2009 | Audio Players & Recorders
If you are using a Mac, move to trash moves the mp3 files to the trash folder on the player. I could not "see" the trash folder on the player until I plugged it into a PC and looked at the MP3 Player in Windows Explorer. On the Mac the folder didn't even show when using ls in the terminal window. If you delete the Trashes folder it will free up memory on the MP3 Player
Jan 03, 2009 | Sharper Image Blue Hat Toy Company Kids...
Toys Logo
35 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
