Question about Sony ACID Pro 5 for PC
Problems Recording Vocals with Sony Music Studio
Everything with Sony Music Studio works fine except recording vocals.
when i record it, it shows my voice moving the bars up and down so i kno wits picking it up
But when i finish the recording i cant play it back
when i drag the actual file onto the studio it says it cannot be performed and the error is unknown.
If it's the problem that I've encountered, you probably have Kaspersky. Many people have had the same issue. I almost took the ACID program back to the store. Kaspersky is possibly scanning the file while recording and erasing the sound for some reason. Pause the protection and it should work fine. It worked for me and others. If you don't have Kaspersky, then disable your antivirus, but stay off the net while it's disabled. Hope that helps.
Posted on Feb 09, 2010
No vocals on recorded disc
You need to check your setup's recording volume and interface. You did not mention if you are trying to record from RCA or digital inputs.
It sounds like your recording level is not set up to catch all of the music. I'd love to buy a unit which cuts all of the whiney vocals from good trance music it is very hard to do with all of the layers of recording.
Feb 07, 2014 | Tascam Cd-rw900sl Cd Recorder/player
In studio recording, which instrument is usually recorded first?
usually the drums are recorded first so that the other musicians can later play with different keys and play their track along with the rhythm of the drums
Jan 29, 2013 | Audio Players & Recorders
I am trying to record in multi track mode-want to know how to record for example vocals on track one then without erasing the vocals add for example harmony or guitar so i get two things on one track. At...
How multitrack recording works is assigning each recording to a different track. A way around this is to record the vocals to track one, then your harmony to track two. Save that as a single recording, or mixdown, then open that saved mixdown to track one. You may need to be connected to a computer to do this.
I use the same technique when using Cool Edit Pro (outdated, yes, but I've been using it for 4 years, and I know most of the ins and outs), especially on the guitar tracks, where for studio sound, you've gotta use 4 total tracks. Putting two tracks together frees up your processor, and uses less in the way of effects, as well.
Hope that helps!
Feb 07, 2011 | Samson Technology Zoom H4n Handy Recorder
MY PROGRAM IS ONLY RECORDING ON ONE SIDE AND THE VOCALS ARE NOT LOUD ENOUGH
your input is only one channel you should be able to go in later and copy the left channel to the right channel or make sure if you use any convertors they are all stereo and not mono (two black bands not just one) you could have to use some effects to get the vocals up to volume or run them through a mixer or preamp first.
Aug 02, 2009 | Sony Acid Music Studio 7 Full Version for...
Recording vocals while the music tack is playing simultaniously
it's not supported on that or any earlier sony software that I know of. have you tried running the program twice (simultaniously) and playing on one while recording on the other then mixing the tracks together after??
Apr 26, 2009 | Sony Sound Forge Audio Studio 9
SOUND QUALITY GONE TOTALLY SCREWY
Go into Music Settings and see if it has been set to Karaoke. That will make the vocals low
Apr 09, 2009 | Sony Walkman Video NWZ-A816 Digital Media...
When i record my vocals its only in one channel why!
It seems that the recording input source is provided as "Line In" whereas you need to select the "Mic In".
This is because the "Line In" is a stereo input and expects input for both right and left channels whereas the "Mic In" input is a mono input which is the same as our default condensed mic device is.
By the way, you would be able to see the graphic VU meters while recording, weren't they displayed that the recording is done only for one channel ?
Always use VU meters for checking the levels for recording, they are available with almost all recording softwares.
Hope this helps.
Thanks
Mar 31, 2009 | Sony Acid Music Studio 7 Full Version for...
Recording with sony acid 6.0
my vocals are off beat when i record why is that.
Mar 29, 2009 | Sony ACID Pro 5 for PC
Not able to record vocals
Make sure everything is routed correctly in Windows. Double click the speaker icon on your taskbar, go into options, click preferences. You will have the option to view playback or recording settings and levels. Select recording and click OK. This will allow you to select which inputs are active for recording.
If it still doesn't work, make sure you have Acid configured to your sound card. I am not specifically familiar with Acid, but all audio programs need to be configured specifically to the system that they're running on.
Dec 19, 2008 | Sony ACID Pro 5 for PC
Playback is faster than recorded
close that windows
now click on it again (left click) and choose mixer
Does your mic show up there ?
Jan 11, 2008 | Creative Labs Sound Blaster Audigy LS...
Sony ACID Pro 5 for PC Logo
624 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
