Question about Crosley CR74 Turntable
What is the replacement needle for crosley cr74
  • Crosley Master
  • 6,694 Answers
Here i have added two links which will take you to the needle for Croslye CR 74. There you can also fined the code for the item
LP Gear stylus for Crosley
LP Gear 78 RPM stylus for Crosley
Posted on Dec 11, 2012
I replaced my needle on my Crosley CR249. Now, there is a lot of static. Any idea what to check next!
The diamond tip on the needle is most probably been damaged. Check the tip for any significant visual issues with a magnifying glass.
Nov 11, 2016 | Crosley Audio Players & Recorders
HELP: Stopped spinning
It's likely the belt has slipped of and probably needs replacing. You can do this yourself. It will be found under the turntable matt. The trick though is fitting it back on. But you might find the instructions on-line (enter the model number into google search). Some people have even put YouTube video's on how to replace the belt on popular turntables.
Jun 11, 2014 | Crosley CR74 Turntable
I got a crosley recently and it has been working great up until now. Whenever I play a song on the record everything works great it is just the sound. its horrible. I think it has something to do with the...
The Needle may need replacing, if after replacing the needle and you have the same problem, it could be a connection from the needle pick up to the recever.
Feb 09, 2014 | Crosley CR249TA Turntable
Replacement stylus
It is difficult working upside down to replace a stylus. if you have a small mirror handy, such as a makeup mirror, place it under the cartridge and shine a bright light on the underpart of the cartridge. You may reveal what is preventing the new stylus from seating.
Dec 13, 2013 | Crosley CR248 Turntable
Transformer TM-48F-038 specs
Transforners are safety parts and should only be replaced by those authorised by the maker. If you need to replace it contact Crosley as to where you can get one.
Jan 12, 2013 | Crosley CR74 Turntable
Im looking at 2 wires with 2pin looking things pluged in them and i need a needle .but wanting to know if i need a complete cartage and a needle or just the replacement needle ,,, and if i need the cartage...
Hi, Unless there has been some kind of damage done to the cartridge iy is only the stylus that you need to replace. I have them in stock. cheers john. Styluscity@gmail.com
Jul 29, 2011 | Crosley CR74 Turntable
CR74-S ..THE CD PLAYER HAS NEVER WORKED..IT WILL NOT PLAY..IT LOADS THE CD AND THEN QUITS SPINNING
Unfortunately it is the laser pickup that is the problem, if it has not worked from day one it was flawed from manufacture, and if you happen to have warranty left I suggest you use it now, simply because to replace the assembly would not be cost effective.
Feb 19, 2011 | Crosley CR74 Turntable
Haven't used the turntable in years. Went to use it today and the turntable doesn't begin turning when the arm is lifted. Everything else works. Thanks, Al
If this is a belt driven turntable, then you have to replace the belt, as this units gets old the belts loosen up as well.
Aug 20, 2010 | Crosley CR74 Turntable
The channels are reversed. The red lead is the left channel whereas it should be the right. The leads to the cartridge match their color codes with the marking on the cartridge. The wires in the headshell...
If it a PROPER head-shell the leads DO come off the pins at the rear of the cartridge.
Also if you are using EXTERNAL speaker it may be that the speaker leads are incorrectly wired to the speakers and that would simply be a matter of swapping the external speaker outputs over.
Apr 05, 2010 | Crosley CR74 Turntable
Crosley CR74 Turntable Logo
457 people viewed this question
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
