Question about Sewing Machines
My white 1510 sewing machine needle will only go half way down and will not even reach the plate
We have reset the timing as the original problem was with the bobbin thread not catching. I have cleaned and oiled the machince,. I have tried different types of threads. The needle will only go about half way down then refuses to continue. It is just STUCK
  • Sewing Machines Master
  • 1,564 Answers
Are you sure you have it timed correctly? Is it stuck or is it really just hitting something?
Posted on Dec 10, 2012
  • 192 Answers
SOURCE: Bottom thread will not catch
Unplug the machine and remove the needle plate so that the bobbin case if fully exposed. Lift out the bobbin case and the cup that it sets in will be visible. Locate the "hook" on this cup. It is a finger with a sharp point at the upper edge of the cup. The hook is what grabs the thread from the needle while sewing.
  • Thread the needle.
  • Turn the handwheel by hand.
  • Watch the hook as it approaches the needle from right to left.
If the hook passes by the needle AFTER the eye of the needle is above it, you timing has slipped and the machine must be taken in for repair.
If the hook catches the thread from the needle, put everything back together and try threading again.
Posted on Nov 14, 2007
  • 255 Answers
SOURCE: Feed Dogs, Thread Tangle
Hi Jeanette! You have a Singer Featherweight--the best sewing machine ever made! (Mine dates from 1950/51 and I wouldn't trade it for the world.) These beautiful, sturdy machines were designed to be easily repairable at home, but you'll need a copy of the Service Manual (get the Instruction manual too, if you don't have one.) Go to www.singer-featherweight.com and check out what they have available.
I had a similar problem (needle thread not catching the bobbin thread) and the problem was that I hadn't put the needle in correctly (flat side to the left). Also, I will occasionally get thread wrapped around the bobbin housing--sewing along just great and then everything comes to a screeching halt. I'm not sure why that happens, but I'm getting pretty good at taking the bobbin housing apart. The manual is pretty clear on how to do it. You can contact me direct at robbie1949@comcast.net for more information.
Thanks!
Robbie
Posted on Jan 10, 2008
SOURCE: the bobbin thread on sewing machine will not catch
how do you retime
Posted on Aug 13, 2008
  • 4 Answers
SOURCE: singer quantum sewing machine won't pick up bobbin thread
Try changing your needle
Posted on Dec 13, 2008
louislevel_2
  • 374 Answers
SOURCE: need sewing machince help????
hi;
breaking thread and thread below not hook up by upper thrread, this is due on not properly set up of thread tension,first check bobbins windin35caecd.jpgg see figure.the threads should
be counter clockwise.
the theading on upper set up should prorerly inserted follow figures.7dabcae.jpg
the dial set up tension should start at #3 to # 5
the stitch tension should be set to # 8 to # 12
use trial run for fabrics,diffferent set up in every fabric tru to study before sewing in other fabrics.have a nice day don't forget to rate me.thank s a lot
Posted on May 17, 2009
I have a Janome sewing machine. There is a problem when i try to draw up the bottom thread from the bobbin. The needle doesnt go through the hole to catch the thread at the bottom
Please elaborate. Is the needle hitting the needle plate so it cannot reach the bobbin thread, or is the needle simply not moving down into the lower position?
May 21, 2017 | Janome Sewing Machines
Dropping feed dogs
Manual seems to imply that you have to cover the needle plate with a "darning plate," which just build up the area around the feed dogs so they don't reach the fabric--pretty inelegant, plus I wonder if you can even find the darning plate anymore. Let me know if you figure out anything else!
Jul 17, 2012 | White Sewing 1418 Mechanical Sewing...
Am considering buying a used Singer Featherweight 132q. Have been trying to find any problems that this model may have but have not been able to find anything, Please help.
I've been sewing for over 30 years,, my suggestion is,, let them sew on the machine so you can watch,, & even ask to sew yourself,,, let them show you what the machine can do.. they should be willing to demonstrate the stitches & anything else the machine can do.. ask questions like has the machine got any problems,, has it been resently been serviced,, does it have a operation manual with it,, has it been well taken care of? are there any scratches on it? are there any burrs around the needle plate,, use your fingers to rub over the needle plate to see if it's smooth or not,, even check the small area in the needle plate where the needle goes down to meet the bobbin... have they ever broke a needle sewing? that can cause the machine to go out of time..
good luck
Feb 11, 2012 | Singer Sewing Machines
I have a Confidence 7470 purchased in May 2009. I was sewing tulle today and the thread kept snapping while sewing. I assumed it was catching in the tulle. The last time it snapped, the thread jammed in...
Sounds like your machine is off timing, When the machine is properly timed, you should see the hook passing behind the eye of the needle when the needle is on it's upward stroke. If this is not correct the machine will not pick up the bobbin thread. You may have to take it in for adjusting, unless your a bit machnical.
May 11, 2011 | SINGER 7470 Sewing Machine
Hi I am having a problem with my 7470 singer sewing machine. Even with thread in the needle and in the bobbin no stitches come on the fabric. I tried manually pulling the wheel towards me to see how...
Is your buttonhole lever down by accident? If, that isn't it, it could be your timing is off. One other thing to try, is your needle all the way up in the shaft? I hope that it is something simple, call Singer at 1-800-4singer and maybe they will have quick fix because the timing is not a do it yourself job.
Dec 30, 2010 | SINGER 7470 Sewing Machine
White 1418 sewing machine
If you have taken the hook out that is the half moon shape first of all make sure the needle is at the top of the machine, hook in, gate up and that is all there is to it.
Apr 10, 2010 | White Sewing 1418 Mechanical Sewing...
I need help in adjusting the feed dogs, they messed up when I adjusted the timing for the needle and bobbin.
When the sewing machine is properly timed, all the parts work together in a seamless flow of coordination. The needle moves from it highest point down toward the needle plate. The feed dogs reach the farthest point toward the back of the sewing machine. The feed dogs drop under the needle plate. This is just before the needle point reaches the needle plate. The needle continues to move down dragging the upper thread under the needle plate. It proceeds toward its lowest point.
The needle begins its rise back up. A loop of thread forms along the back of the needle. A special cut out on the back of the needle to accommodate this loop is called the scarf. The sewing machine hook slides behind the needle. The point of the hook slides into the thread loop and pulls the thread around the bobbin. The bobbin thread and upper thread wrap together. The needle and hook proceed through their actions under the needle plate. The feed dogs move under the needle plate from back to front.
The needle proceeds to rise again up out of the bobbin area exiting the needle plate. At the same time the feed dogs rise up out from under the needle plate. They begin to move from front to back as the needle continues to rise.
The thread from the bobbin flows through a bobbin tensioner providing resistance to the thread as it is drawn up by the upper thread knot. The upper thread is also under tension. This comes from the upper tension, thread guides, tension spring, and sewing machine take up lever.
The thread from top and bobbin grow increasingly tighter until they form a locked stitch in the middle of the fabric. This process is repeated for every stitch.
How do you adjust sewing machine timing?
The needle, hook, and feed dogs must move in harmony. If they fail to do so, the machine will not perform as expected. When the hook is just slightly out of time with the needle, you will notice skipped stitches. This may begin on only one side of the zig zag stitch or intermittently. If the timing is just a bit more out of sync, stitch formation will become impossible.
If the feed dog timing is out of sync, the fabric will not move through the machine as expected. Threads may bunch up or the fabric may just not move.
As you can see, timing is everything.
click on this link directly
http://www.fixsewingmachines.com/How-to-Adjust-Sewing-Machine-Timing.html
This will help. Thanks please keepupdated.please do rate the solution positively .thank you for using fixya
Jan 29, 2010 | Sewing Machines
My sewing machine needle is hitting the top of the needle plate
basically have to bend it carefully back by hand.... if you have a straight edge or even a small leveler (the kind with a bubble) you can check which direction it is bent and gently bend it back a little each time.
Mar 29, 2009 | Kenmore Sewing Machines
Sewing design thread breackage
Assuming that the timing, needle clearance, position finger and needle plate position are all properly set you can try the following:
1. Oil the hook (use Pfaff hook oil, it is a lighter weight than the normal white oil used on sewing machines).
2. Check the hook tip and flank for damage, buff out if possible.
3. Check the needle plate for damage and buff out.
4. Replace the needle.
This is a great machine and is worth keeping up, Pfaff doesn't make the all metal hook anymore which is a shame.
good luck!
Feb 01, 2009 | PfaFF Creative 7570
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
