Question about HP Compaq Presario C500t Notebook
My Compaq Presario C500T laptop won't start. I don't think it's the battery because there is still an orange light flashing when I try to turn it on and the battery is in. Although I am thinking that mabe there is very little power, but not enough to start up the computer. But I'm not sure, I don't want to buy a battery and then it still doesn't start. I don't know that much about computers, that's why I'm asking, can someone help me with this problem. Thanks.
  • 3 more comments
  • njoldja81 Jan 16, 2009
    It doesn't work when I plug it into the wall, with or without the battery.
    The charger has been plugged in for days
    The symbol that flashes the brightest orange is a lightning bolt, and it flashes only when the battery is in and I press the power button. If it's plugged in without the battery there is no lights at all when you press the power button.
  • kay09 Mar 18, 2009
    When my computer is plugged in and or unplugged I press the power button the lightening symbol flashes no flashes when the battery is off and the power charge is plugged
  • Stephen May 11, 2010
    Does it work when you plug it into the wall?
    Sergeant:
  • 366 Answers
If blinking battery is not charged.
use AC charger to run and keep it plugged to recharge your battery (till green solid light)
Posted on Jan 13, 2009
Compaq Presario V5000 does not come on
The solution to your problem lies in one of the following three areas:
1.) Your charger is faulty and is therefore not able to pass power to your laptops battery.
2.) The charging connector on the laptop has come loose from the contacts. Therefore a bad connection.
3.) Your battery is faulty.
I think possibility 2 is the most likely, although you will have to test possibility 3 by removing the battery and plugging in your charger and seeing if the laptop powers on.If it does power on then that rules out possibility 1 and 2 leaving a faulty battery.
http://www.chargerbuy.com/replacement-compaq-presario-v5000-ac-adapter-65w-18-5v-3-5a.html
Nov 20, 2012 | Compaq Computers & Internet
I am opening my pc and after 2 second it went off i have a blinking light like a orange flash light
I imagine the orange flashing light is over the battery? The compaq laptops have a little blue light that will typically light up when it's plugged into the wall. If it is plugged in ensure that the little blue light is on. If it isnt you may have a n issue with your power supply unit, or there may be an issue with the port where the plug is plugged in. Thus causing the battery to be dead and the computer not power on. If you have any other compaq computers you can also try plugging in that power adapter, or try picking up a universal or another hp/compaq charger from somewhere such as best buy to test it out.
Mar 07, 2011 | HP Compaq Presario C500t Notebook
My Compaq presario c500 won't turn on!
Sorry to say but your power chip has failed. M/board replacement required
Jul 29, 2009 | HP Compaq Presario C500t Notebook
My compaq presario c500 doesn't respond to the start button
try to turn on the laptop without the battery and only the power cord plug in.
if your laptop works with this you need new battery or update bios ( there might be fix for battery monitor)
if not, call service support, might be motherboard issue
let me know an update
Apr 03, 2009 | HP Compaq Presario C500t Notebook
Presario C500 Wont turn on
sounds like the d/c adapter was either installed backward or the wrong part was installed, also check the connector on the new power cord to the laptop, you may have gotton an incorrect power cord. because what you describe is the internal power system is shorting out. take battery out and check it with a volt meter , if the is no volts/or negative volts on the battery ,it has gotten internaly reversed , and needs replacement.
Mar 25, 2009 | HP Compaq Presario C500t Notebook
My Compaq Presario C500T lap top won't start
Generally speaking, an orange power light indicates problems with the power. You also described to a "T" how a bad battery behaves. To test this theory, take out the battery and plug in the laptop. It should power up and run. If so, it's time to invest in a new battery.
To be doubly sure, if you have anyone with the same laptop as yourself, plug in their battery to your laptop. It should work if their battery is good.
Thanks for using fixya.com. Please rate this tip accordingly if it provides the information you needed.
Jan 13, 2009 | HP Compaq Presario C500t Notebook
Flashing lightning bolt on Compaq C300
This sounds like a battery problem. The best way to test this is to remove the battery and then power the laptop up with just the power cord plugged in but no battery. If the computer boots then the battery is bad you will need a replacement. Also try letting the battery charge for a day. Be sure that the charging light is coming on when you have it plugged in.
Dec 09, 2008 | Compaq Presario Notebook
Compaq c500 laptop
Sounds like a similiar problem I just resolved. Try to replace the power button board and this should help...Joe
Sep 10, 2008 | HP Compaq Presario C500t Notebook
Power button has light turning on and off with no other signals !!
try,,holding the delete key down as it is starting up,,,will the computer boot into Bios?
do you see any information on the screen when you start the computer at all?
Aug 19, 2008 | HP Compaq Presario C500t Notebook
Computers & Internet Logo
332 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
