Question about Welding Tools
Parts for a seelye 100 amp mig welder si-1800
CarlGehrke
  • 169 Answers
SOURCE: electrical problem with mig welder
Call Lincoln Electric (the manufacturer) at 216-481-8100 and ask them to email you one.
please rate my answer,
Carl
Posted on Dec 03, 2008
  • 3 Answers
SOURCE: mig welder tripping power supply
the breaker could be bad. try to change the breaker
Posted on Jan 16, 2009
luxur4
  • 92 Answers
SOURCE: need wiring schematic for miller 140 wire feed welder
No problem,email, write or phone for this information, Miller personel are very obliging as are most Welding manufacturers.
Posted on Jan 23, 2009
  • 19 Answers
SOURCE: Clarke MIG welder parts??
what model is your clarke? i have a 125en which is the exact same welder as a craftsman, you could probably get a new feed motor or other parts for the welder itself from sears, the gun is a tweco style gun same as lincolns, so if you need tips or anything you can get those just about anywhere welder stuff is sold. i hope i helped.
Posted on Apr 22, 2009
SOURCE: lincoln mig welder 180, 230 volt 20 Amp Input.
Inspector is correct! In wall or conduit wiring awg will always be greater than "open air" wiring. IE: the size of wire coming from your pole ... it's smaller than from your service riser into your meter. Code allows the cord to heat up... open air will cool it down.
Posted on Dec 13, 2009
Cebora mini mig on trigger no wire feed ,power on?
Cebora mini mig on trigger no wire feed ,power on? - Fixya
www.fixya.com/.../t25810314-cebora_mini_mig_trigger_no_wire_feed
3 hours ago - Question about MIG Welders ... Weld corp mig 100 turn machine on andwire keeps feeding without ... Welder running but wont feed wire etc.
Aug 05, 2015 | Welding Tools
How do I troubleshoot a chicago mig-100 welder fuse keeps you
Looking at a owners manual with a parts list and schematic, there is no fuse in your welder. There is a thermal overload switch that senses overheating and shuts your welder down. If it is stressed to its limit it will not function any longer. Try going to the place of purchase and see if they can supply you with a thermal switch.
Mar 02, 2015 | Welding Tools
My SIP ideal 240v mig welder keeps tripping garage and/or house power, what's wrong?
welder drawing high current.sounds like a earth problem with the house or the unit.
Aug 14, 2014 | Welding Tools
Seelye welder doesnt seem to be putting out enough amps.
Hi:
Always the same problem with seelye's. Check your ground cable and if doubts of being well tight the terminals and the ground clamp, change them.
This will take care of the problem.
Mar 19, 2011 | Welding Tools
Kende 150R gas/nogas mig welder
Hi I have the same welder with the same problem, I've striped it down and found that there are a few teeth missing on the gears that run the wire feed,
Had no luck finding any replacement parts though
Sep 05, 2010 | Troy MIG100 90-Amp. Wire Feed Welder
Hobart 140 voltage drop when welding in all setting using 30 wire and uni mix gas will start out welding good then will not ?????
Check your input line voltage. 115 volt Mig welders / plasma cutters need stable voltage / current. Test to see if the voltage drops to below 100 volts when welding. If so, find a more stable power supply.
Mar 05, 2010 | Hobart Welders 500505 Handler 140 MIG &...
My 210 took a spill. Looking for new face plate, cables, & knobs. Where can I find them?
Hobart are very obliging, contact them and request a parts list for your set, or any Hobart welding suppliers.
Nov 15, 2009 | Hobart Welders IronMan 210 MIG 500304A...
Welder probems
a mig welding unit of 100 amps is very low, you will require a small wire size, plus the contact tip, liner to suit, expect to get a maximum amperage of 70- 80 amps max, if the unit is Aluminium wound transformer then expect 6 months use, and the ampage will drop ,then its scrap, depending on the weather conditions that the unit is kept, will depend on the live of the unit.
Dec 30, 2008 | Welding Tools
Mig welder tripping power supply
Dec 09, 2008 | Troy MIG100 90-Amp. Wire Feed Welder
Welding Tools Logo
48 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
