Question about LG F-185 CD Shelf System
What is the equivalent str for dmo465r
The alternate of str dmo465r
    New Friend:
Alternatives: FSDM0565R or FSDM0465RB
Posted on Aug 03, 2017
Sony str gx5es
There is no equivalents to this STR. The original number should be replaced.
Jan 13, 2014 | Toshiba Televison & Video
Sony TV has a power supply problem both ics irf1b7n50a in the power supply section are all shorting which number could I use as an equivalent. is there a way I could use a power modular with two power id's
Hi Saidi
Have you checked all the other components used in the main power supply regulator section circuit, before replacing a new STR? You should do it. There should be a reason for the failure to STR. You should find it, and rectify it, before replacing an other STR. Check all the small components, resistors, zener diodes, small value ceramic capacitors etc: Make sure all of it are OK. Especially give a keen attention to zener diodes used; if any. It will be best to replace these diodes, even if you do not find any fault with it with multimeter test.For more information go to http://electronicshelponline.blogspot.com/
Power supply schematics to some popular brand TVs are given. Pull up older posts. Good Luck.
Nov 26, 2013 | Televison & Video
UNIT BURN STR POSITION NO.9501 & CP 9506 PLS GIVEN PART NO.? OR SUBSTITUTE/EQUIVALENT
Hi mohdkhurshid,
Please indicate the brand and model no of your unit then repost your problem so that the expert will give you proper solution regarding on your problem.
Jdvillanueva
Mar 09, 2011 | Televison & Video
How do u reset soney reciver str-dg510 i have no sound
What preceded this? Was it working and then stopped or did it never work?
http://www.retrevo.com/support/Sony-STR-DG510-Receivers-manual/id/2526ci754/t/2/
Page 26...
Press I/O to turn off the receiver
Hold down I/O for 5 seconds (("PUSH" and "ENTER" apear on the display alternately)
Press MEMORY/ENTER. After "CLEARING" apperas on the display for a while, "CLEARED" appears.
Jan 31, 2011 | Sony STR DG510 - AV receiver - 5.1 channel...
When airconditioner is turned on, engine will not idle up, engine shakes violently and stalls. Gas consumption is bad. Is it due to electronic fuel injection , alternator or computer box? Throttle body has...
No, I wouldn't change the alternator unless you have a battery charging problem, which I don't think you have.
I think that if it stalls there's a problem with the iacv (idle air control valve) or equivalent. Look for codes stored in the obd-II computer using an obd-II scanner to retrieve codes and meanings.
Good luck on this repair.
Jan 29, 2011 | 1997 Honda Civic
I want to plug my Dell Computer into one of the Audio Jacks. Which ones do I use??
Any available Line Level input will work but NOT Phono. Get an adapter at Radio Shack to convert the probable 3.5 mm jack on the PC to an RCA pair.
In the PC: Get into the sound controls and max out the volume. Set the speaker type to large stereo or equivalent.
Dec 30, 2010 | Sony STR-DE305 Receiver
Tv no enciande
i have a (PTV) that it,s SMPS is not working i need to two thing.
1-shematic diagram of PTV.
2-shematic of STR x6954 or equivalent that used to this model.
model:SP-43910hex
SP-43R1hex/ha3
Nov 18, 2010 | Televison & Video
Having a problem with subtitles
my problem is for PTV SP-43910HEX--the SMPS of this model is not working.
i have not shematic diagram and i need the shematic of STR x6954 or equivalent for this model.
LG F-185 CD Shelf System Logo
439 people viewed this question
Top LG Audio Players & Recorders Experts
jairo sanchez
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
