Question about Home
I have a sanicompact 43 and it seems to be blocked not in the wc outlet,but in the unit behind as the water level keeps rising in the wc pan when the waste water from the basin is running.Are there any suggestions on how i can unblock
  • 82 Answers
SOURCE: Much louder noise from the unit than usual
The Sanibest has a pressure sensitive switch that activates when the water pressure inside the unit gets to a particular level. It is basically a microswitch sealed in a watertight container.
If the Sanibest has got gunked up inside it is possible that the unit is not kicking in soon enough and the water is backing up into your shower.
Another possible issue is that something has got into the Sanibest that should not be there that is impeding the flow out of the unit.
For both cases I would suggest that you empty the cistern and WC bowl after running clean water through th unit for a few miunutes (makes the job a bit less horrible!).
You could also try and use SaniFlo cleaning product and hope that it clears the potential blockage http://www.sanifloproducts.co.uk/products/Saniflo-Products-Saniflo-Descaler.html
** ENSURE THAT THE VERY FIRST THING YOU DO IS TURN OFF POWER TO UNIT **
1. Turn off the electricity to the unit (should be on a fused spur)
2. Disconnect the pipes (inlet and discharge) - you may get a bit of surplus water coming out so have some sponges and a bucket ready.
3. Disconnect the wiring and take the unit out
4. I clean my Saniflo's outside with warm bleach water ..
- Wear rubber gloves to keep germs out of any cuts you may have / get on your hands
- Put the elextrical cable in a taped up plastic food bag or similar to keep dry
- undo the 'star screws'
- Flip up the plastic retaining tabs with a flat blade screwdriver and gently ease the lid up.
- I put bleach and warm water in, leave it for a while (30 mins) and then swish it around and empty out into an outside drain etc
- If you want to use an old toothbrush to get into the areas by the float switch and under the motor it does help. I also used a hosepipe in the past which did the trick.
- Also pay attention to the inlet port and the actual pipes under your sink for gunk
put it back together, aligning the seal and plastic clips should just pop on (may need a firm push). Do up star screws and you are ready to reconnect the pipes and electrics.
I use some tissue paper to check for any leaks around the pipes just to be sure!
Another point to note is that you can insert a simple non-return valve into the pipe near the shower to stop the water coming back up; however this is not addressing the root cause.
Hope this helps - if so, please leave feedback. If not let me know and I'll try and help some more!
Posted on Feb 02, 2010
  • 33 Answers
SOURCE: I am mounting my macerator behind my WC but 170mm
not recommended
Posted on May 10, 2010
duane_wong
  • 6826 Answers
SOURCE: Hi, I have a sanicompact 43.
Use 5 minute epoxy or puddy epoxy to seal the leak after drying it if there is a crack.
If the leak is at a gasket or seal, then try to tighten or remove and replace the defective part.
Posted on Oct 12, 2010
  • 115 Answers
SOURCE: The SaniPlus toilet was just
There could be a blockage somewhere in the drain pipe or inside the pump casing not allowing the waste to be pumped out. Refer to the installation manual/technical data manual and take a look at the schematic diagram for the Saniplus, It will show every component inside the pump casing, the short discharge pipe (# 7c) and long elbow (# 8) may be split open or not attached properly and waste water is just cycling inside the pump casing and not pumping out.
Posted on Jan 11, 2011
packrat1948
  • 528 Answers
SOURCE: I have a wc from
Well the rough-in of the wc is the measurement from the wall to the center of the drain opening take that measurement and go to your local plumbing warehouse and ask them to look up any and all wc with that rough-in and pick one you like. If there are non you like or there is non with that rough-in then I see no other way then to move the drain to fit the one you like.
There are some offset closet collars out there but if you are working a cement for it would be just as easy to move the drain.
Posted on Feb 04, 2011
How to keep water from building up in my air conditioning drain pan
this indicates that the drain is blocked by gunk either in the drain tray outlet or in the drain pipe outside
it can be washed out or blown out
it could be the outside hose because things like mud wasps find it a good place to build nests
Sep 01, 2015 | Heating & Cooling
Haier xqg65-11su Keeps filling with water
I don\'t know this particular model but on many machines there is a diaphragm switch operated by a tube.As the water level rises in the machine the water also rises in the tube and the resulting pressure in the trapped air pushes on the diaphragm.If yours is like this look for a clear plastic tube running from the front or rear of the outer drum to a circular switch about 10cm diameter towards the top of the machine.If the pipe is blocked with soap powder or scum or the pipe has rubbed allowing the trapped air to escape the machine will continue to fill.If this is not the case by removing the pipe at the bottom and blowing into it you should hear the diaphragm click on and off as you release the pressure.Also check if the point where the pipe comes out of the drum is clear by pushing a piece of wire through the outlet.Don\'t forget the usual safety measures and unplug the machine before you start.
Jun 09, 2014 | Haier xqg65-11su washer dryer combo...
I have a sanicompact 43, if the water pressure is low will this b the reason for flushing problems , please ?
Its a Cisternless ceramic toilet with built-in Macerator Pump.So the water pressure should not make much of a difference as most of the job is done by the pump
Regards.
plz. Don't forget to rate my suggestion.
Jul 13, 2011 | Elite Saniflo SaniCompact- SaniCompact One...
Water in the drip pan- what is causing it?
I assume you are talking about the indoor unit. One function of the a/c system is to dehumidify the air. Condensation forms on the cooling coil and runs to the drip pan. There should be a drain line on the drip pan that drains the pan outside. These sometimes become clogged causing the water level in the pan to rise. Try some mild drain cleaner to open the line. Hope this helps. Let me know what you find.
May 21, 2010 | Carrier 38CKC036 Air Conditioner
My Saniflo sanicompact does not flush away, when i press the flush botton it does not work, the toilet buzzes all the time. when the water gets to a level it use to pump away but has stoped doing this.
saniflo buzzing all the time means that the motor is trying to run but cannot. indicates that something is blocking the pump impeller from rotating. unit needs to be removed, cleared and tested. if fault contiues you may blow the fuse (if you are lucky) otherwise the motor will eventually burn out. get this checked soon.
Apr 12, 2010 | Saniflo Sanicompact Elite - One Piece...
Whirlpook ET21NK--Water collecting in crispers
Self-defrosting refrigerators turn themselves off to defrost once in each 24-hour cycle. There is a 'drip pan' under the refrigerator that catches water from this automatic defrost cycle. The pan is not very deep, so if the unit is leaning very much, water will run over the top of the pan. For this and other reasons, you should try to keep the unit as level as possible.
Aug 21, 2009 | Refrigerators
My whirlpool washer, model #sm8525492-a doesn't seem to be holding water. It isn't leaking water on the floor.
Make sure the drain hose outlet is higher than the water level in the tub or the water will siphon out on it's own.
Aug 16, 2009 | Washing Machines
Leaks from top
Yes it goes to the pan.. you can ues a hair dryer but do not leave it unattended.Or your drain line is clogged to the pan .
Dec 07, 2008 | Home
Hotpoint MAC-130 air conditioner dripping water
You need to blow out the drain line where it hooks up to the pan and clean out the drip pan. It doesn't matter how clean you keep the filter, that's just to keep the evaporator coils clean, which is important in itself. But algae will grow in the drip pan if it is not tilted to drain correctly and will clog up the drain line. If you put a level on the top of the unit, the bubble should JUST BARELY break the line on the OPPOSITE side from the drain outlet on the pan. Hope this helps.
Jan 25, 2008 | Heating & Cooling
Bosch Dishwasher
Turn the water of at the inlet, diconnect hose and then reconnect it, it could be an airlock
Nov 28, 2007 | Dishwashers
Home Logo
359 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
