Question about Sta Rite STA-RITE IGNITION CONTROL MODULE - 42001-0052S
89 cougar 3'.8 car stalls. no spark. starts again after 10 to 20 minutes
Car stalls sporadically while driving, after driving for awhle it dies and wont start, but does start again after 10 or 15 minutes, I've replaced the ignition control module. Didn't work. Still does same thing. It seems to be happening more frequently
  • 1 more comment
  • Chet Wilson
    Chet Wilson Dec 18, 2012
    I've since replaced the electronic ignition under the steering column and also the E E C relay
  • Chet Wilson
    anybody out there with any suggestions??
  • Thomas Hinrichsen Jan 14, 2013
    also check your ignition coil
    New Friend:
    Problem Solver:
  • 11 Answers
It sounds like your crank sensor or cam sensor are failing. When either of those two sensors overheat they will shut down the engine until they cool down
Posted on Jan 14, 2013
2 Suggested Answers
SOURCE: cant locate ignition module
I think its on right front side fender.
Posted on Nov 28, 2011
Car stalls, starts up then stalls again, starts up and stalls again
This could have several problems. #1 Fuel pressure due freezing water in fuel lines add thermal aid or rubbing alcohol . If you have access to a pressure gauge there is a service fitting on fuel rail that you can test pressure while driving and see if the pressure is gone when car dies this could lead to fuel pump electrical or more restricted lines. #2 intermittent sensor failure Mopar uses 2 sensors to control spark and fuel lose one could lose spark lose the other lose injection with a scanner they call it C/C sync ok (cam/crank) if no then check for each parameters for display.# 3 relay controls ASD and FUEL pump for voltage drops.
Apr 18, 2014 | 1997 Dodge Stratus
I have a 1999 mercury cougar v6 and it just started stalling not to long ago. When it stalls it lasts only about 6 seconds then its ready to go, but when it stalls the car gets really quiet like it has...
give the car a good tune up once you give it a tune up buy a gas treatment this you pour in the gas tank when finish take the car for a drive.
Dec 15, 2017 | 1999 Mercury Cougar
Sputters after driving a few minutes, tries to stall out.
1st move is to ck the fuel PSI & emissions. Possible cooling system cause.Scan computer & check sensor readings & the emissions readings are the first moves. Check spark plugs, ignition spark etc. Good luck
Mar 25, 2017 | 1999 Volkswagen Cabrio
Where is ignition control module on 89 cougar 3.8
pasenger side in front of front brace, behind the passenger headlight, mounted to bottom radiator support.
Dec 06, 2012 | Sta Rite STA-RITE IGNITION CONTROL MODULE...
Alternator
Try checking you belt tension. That happened to me once while I was driving. Turned out to be a broken fan belt.
Feb 27, 2012 | 2001 Mercury Cougar
Car will crank but not start after running for a few minutes and dying. then no spark to the coils when checked for spark. let sit for several hours will start and run again for a few minutes.
Thanks for choosing FixYa and welcome to the site. Have you tried to get any codes off your computer yet? There are many things that can cause this. Is the check engine light on Ron?
Apr 18, 2011 | 1995 Mercury Cougar
Car stalling out and bot starting after being driven for awhile.
mcdevito75 Here, It"s possible the ignition Module is going bad, no way to test and if so, one day the car will not start at all.----------It can also be a vapor loc, wher the fuel is evaporating before it reaches the cylinders. Best Bet, have your local shop check both these items.
Jan 01, 2010 | 2000 Dodge Stratus
98 Accent stalling
When it dies..check for spark. You could have a component in the ignition system failing when the car gets warm.
If you don't have spark then you might need a new ignition module. The distributor cap and rotor should be checked for traces of carbon. This would be evidence of a leaking cap.
If you get check engine codes then you do have some sensors going out of range or failing all together. P0446 is an evap code right?
Make sure your fuel cap isnt plugged up and all your evap lines are ok.
Dec 09, 2009 | 1999 Hyundai Accent
Sta Rite STA-RITE IGNITION CONTROL MODULE - 42001-0052S Logo
51 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
Oloyede Monsuru
john h
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
