Question about RCA Morelli Cinema Hdx-44 Tv Projector
No sync is what it says when i turn it on hdx44
Why am I getting no emails on my tablet
To control sync settings for the device, follow these steps:
Android 4.0 / 4.1 / 4.2
  1. From the Home screen, open the Settings menu.
  2. Under Personal, touch Accounts & sync or Accounts.
  3. To turn on or turn off Auto-sync
    • Touch the switch at the top of the screen.
      HTC Sense Samsung TouchWiz
      1. From the Home screen, tap the Menu key.
      2. Tap Settings.
      3. Tap the Connections tab.
      4. Tap Data Usage.
      5. Tap the Menu key.
      6. Check/uncheck Auto sync data.
  4. Touch an account to adjust settings, turn on, or turn off sync.
    • MobileLife Contacts
    • Google (appears if set up)
    • Microsoft Exchange ActiveSync (appears if set up)
    • Others, depending on apps installed
  5. To synchronize all accounts manually, touch Sync all.
  6. Press the Home key.
Android 2.1 / 2.2 / 2.3
  1. From the Home screen, press the Menu key.
  2. Touch Settings.
  3. Touch Accounts & sync.
  4. Under General sync settings, turn on or turn off:
    • Background data
    • Auto-sync
  5. Under Manage account, touch an account to adjust settings, turn on, or turn off sync.
    • Exchange ActiveSync (appears if set up)
    • MobileLife Contacts / T-Mobile / T-Mobile Contacts
  6. To synchronize all accounts manually, touch Sync all.
  7. Press the Home key.
Android 1.5 / 1.6
  2. Touch Settings.
  3. Touch Data synchronization.
  4. Turn on or turn off Auto-sync.
  5. Touch an account to turn on or turn off sync.
    • Gmail
    • Calendar
    • Contacts
  6. Touch Menu.
  7. To synchronize all accounts manually, touch Sync now.
  8. Press the Home key when sync completes.
Feb 19, 2015 | Samsung Galaxy Cell Phones
How do I sync my email on my galaxy s4
Have you tried swiping your finger down from top to bottom on your home screen there you see the sync icon
May 16, 2014 | Samsung GALAXY S4
Facebook keeps closing after 10 seconds
You might have turned on the sync option.
Go onto your own home page on Facebook app on your timeline hit photos scroll to the bottom and there is a sync button on the right tap that if you haven't synced your photos then it ain't that which is causing your problems but if you have synced them simply turn off the photo sync.
Oct 20, 2013 | Apple Cell Phones
The controler lights flash but wont turn on?
Have you tried syncing the Wii remote?
To sync the Wii remote, turn on your Wii.
Then open the back of the Wii remote (where you put the batteries) and press the SYNC button.
Open the SD Card Slot cover on the front of the Wii. Press the SYNC button.
The controller should turn on.
If your Wii remote still doesn't turn on, visit support.nintendo.com, or call 1-800-255-3700 for Wii assistance.
May 20, 2010 | Nintendo Wii Remote Controller
My wii remote keeps flashin but wont trun on
You have to sync the Wii remote to the console.
To sync the Wii remote, turn on your Wii. Then open the back of the remote and press the "SYNC" button. Then open the SD Card Slot cover on the front of your Wii and press the "SYNC" button. Your remote should be turned on if you do this.
If this problem still occurs even when the Wii remote is synced, your Wii remote might not be working properly. Return it for a new one.
Feb 21, 2010 | Nintendo Wii Remote Controller
I just put new batteries in my Wii controller & it won't turn on. The Wii itself is on, but the controller won't turn on. How do I sync it back?
  1. Press the Power button on the Wii console to turn it on.
  2. Open the SD Card Slot cover on the front of the Wii console. Remove the battery cover on the back of the Wii Remote you wish to sync up.
  3. Press and release the SYNC button on the inside of the SD Card compartment on the console. Press and release the SYNC button just below the batteries on the Wii Remote.
  4. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 through
Nov 30, 2009 | Nintendo Wii Console
Remotes are not working. Need help. Remotes are charged. Tried to sync several times. Unplugged console. Giving up...
You know, this really takes alot of patience. I recommend that you sync one at a time. Sync one remote, turn off the Wii (Not by unplugging it). Then turn it back on, don't turn on the one that you just used, and sync the next one, and so on. Did that help?
Jan 25, 2009 | Nintendo Wii Console
Ipaq 4700 active sync problems
i can try to help you , first are you using xp or vista ? and which version of active sync ? i found that after upgrading to active sync v4.5 my ipaq 4700 refused to sync , i have xp home , so by trial and error i learned several things , i tryed my usb cable in every usb slot i had , only to find some usb ports are more friendly to certain devices , for a lack of better terms , i deleted all partnerships in active sync , found that i needed to make sure active sync is not running on ipaq , go to settings / memory / running programs on the ipaq , stop all running programs , turn the ipaq off , then on the pc made sure firewall not locked , plug usb cable into pc , i leave mine in a port permanently , plug into the ipaq , it automatically turns the ipaq on , then i see 2 icons in pc system subtray start blinking , at that point i know sync is going to work , then active sync icon starts turning , lit up in green , and asks do you want to create a partnership , yes , follow prompts , and thats what has been working for me , now if i was to put the usb cable into a different port , no doubt it would give me grief , and the same thing with my phone and active sync , make sure active sync is not running on the device , sometimes i have to reset the unit , ipaq or phone , make sure unit is turned off them make the connection , give it a try .
Jan 02, 2009 | Computers & Internet
Wii fit wont turn on
Have you tried to Re-sync?
1. Start the game from the disc, and wait it to run.
2. Press the sync button on the wii fit balance board.
3. Press the sync button on the wii console.
Some people say that holding the wii console sync button for 7 seconds works best.
Dec 06, 2008 | Nintendo Wii Console
RCA Morelli Cinema Hdx-44 Tv Projector Logo
41 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
