Question about Marley Heating & Cooling
Model FSsWH1502. How do I override the automatic and other settings to just turn it on/ off and set just the temp wanted?
2 Suggested Answers
  • 250 Answers
SOURCE: htx0607p heat emitter. Always heating, overrides
It sounds like the thermastat has to be replaced.
Posted on Mar 15, 2011
After turning off the unit the display is off but the unit is still running.
If it has humidity control and the cool is still on but set temp is higher than the room temp, the humidity control will override set temp. If it has no %rh control then it probably has a circuit board fault; micro relay is stuck closed and board needs to be replaced. Its probably the circuit board. On it, there is a little black box(s). About 1" X 1/2" in size. With long run times the small contacts inside will fuse/melt together.
Jun 20, 2015 | LG Electronic Window Air Conditioner
Ritetemp 8022c
no you can not , overwrite in same microcontroller
Oct 12, 2013 | Heating & Cooling
Override thermostat temperature setting on ge rak1481d
To override the temperature limits, simply remove the thermostat cover, and then carefully replace it again, making sure the pins line up correctly. That's it! You can now set the thermostat as low as 60° and turn fan to "On."
Mar 16, 2013 | GE RAK147D1
What does temporarry and hold mean on thermostat
Sounds like you have a programable thermostat. the temporary setting is when you change the temp setting to a different temp and it will stay at that setting until the next programed change. The hold setting is to hold the temp setting you have chosen for an indefinate time. It overrides your programed settings.
Jul 06, 2012 | Honeywell Programmable Thermostat Heater
I need to understand how to turn it on to VIP or override mode so it doesn't set back at the time intervals- allowing it to run without interuption
put it on a temperter set for the room it should sence the temp and shot off after room gets that temp.
Feb 05, 2011 | Heating & Cooling
How do I set the temporary or permanent override feature on the Honeywell RTH2310B model thermostat?
To set the temporary override, press arrows up or down to desired temp. This will keep temperature
at temporary setting for 2 hours then return to programming. To permanent override press MODE button until schedule period number disappears (number inside little house on stat). Then adjust temp with arrows. Press the MODE button again to cancel override and return to programmable.
Jan 25, 2011 | Honeywell Programmable Thermostat Heater
I programmed the timer as instructed but when the time to turn on came it didn't turn on. I changed the mode to "on" & it turned on but I don't think it will turn off automatically. What...
You posted under Woods outdoor 2-outlet timer 59403:
Add a comment if this is not your timer
http://waterheatertimer.org/Woods-timers-and-manuals.html
Lets run through trouble spots others have with programmable timers:
Add a comment any time and I will help.
What we know for sure:
-Battery is working because display shows.
-Manual override works, so basic electricity is OK and light is OK
-Common programming problems:
-You set current time and it shows in display > if current time is not set or does not advance with passing time, then timer does not know when to turn on-and-off. Double check display for current day, hour, and minute.
-Each event has ON time and OFF time. So you set event1 ON and then set event1 OFF. For example some people set ON time and don't realize each ON needs corresponding OFF, or can't find how to set OFF. Trick is making sure timer display matches fig3 and fig4 shown in manual. Press PROG button until display shows 1ON for event1 ON and then press PROG button until display shows 1OFF for event1 OFF.
-To review programs and double-check, press PROG button repeatedly to scroll through programming. Check for ON and OFF days, and for overlapping on-off commands.
-Event1 ON and event1 OFF should be set for same day(s). For example event1 ON is set for Tuesday but event1 OFF is set for All-days (instead of Tuesday) will conflict and timer will not function.
-Conflicts in programming will cause problems. Conflict example: Event1 says ON 7pm OFF 9pm Tues, but event2 says opposite.
-Make schedule of on-off times before programming to avoid conflicts.
Setting Mode:
MODE is manual override button: press it to set Automatic, ON-OFF override, or Random
Press MODE button until RDN displays in upper left corner, and then press MODE one more time to enter AUTOMATIC >>> you want automatic for programming functions.
Circuit analyzer: If above items check out 100%, and timer still doesn't work, plug timer to indoor plug on another circuit (not on outdoor plug). This will check if outdoor plug has electrical problem interfering with electronics inside timer. Buy cheap plug-in circuit analyzer from Home Depot electric department and double-check circuits.
59403 manual:
http://waterheatertimer.org/pdf/Woods-59403.pdf
Nov 27, 2010 | Woods Outdoor 7 Day Digital Two Outlet...
Problem is showing override in error code
OVERRIDE MEANS YOU HAVE A SET PROGRAM IN THERMOST THAT HAS A TIME SETTING   SAY AT 8 PM TO TURN ON OR UP TEMP YOU MUST REMOVE THIS SETTING IN PROGRAM OR  MAKE YOUR OWN OR JUST GET A SIMPLE T STAT THAT HAS NO PROGRAMING WHICH MAKES LIFE EASY FOR YOU. THERE MAY BE A RESET BUTTON ON BACK SIDE OF T STAT TO RETURN TO DEFAULT FACTORY SETTINGS
Apr 20, 2010 | Carrier 38CKC036 Air Conditioner
Automatic warm/cold water temperature setting does
The temperature control board is bad . Pt # 388246
Aug 17, 2009 | Kenmore 22422 Top Load Washer
Heating & Cooling Logo
26 people viewed this question
Top Marley Heating & Cooling Experts
Paul Carew
Ron Durham
Are you a Marley Heating and Cooling Expert? Answer questions, earn points and help others
