Question about Sony FD Trinitron WEGA KV-32HS510 32" TV
Sound cuts in and out of my sony trinitron how can i fix this myself
  • daniel gomez Dec 12, 2012
    it does it with dvdand game consoles
    Top Expert:
  • Sony Master
  • 14,553 Answers
The first thing to know is does it do this when a dvd connected to one of the video inputs is used?
What else is connected to the set and where is signal from?
Posted on Dec 10, 2012
  • 579 Answers
SOURCE: blank screen on sony trinitron tv
The problem with this model is the large parts due to poor wave soldering. Locate the transistor Q605. Using a small wattage soldering iron melt the solder and add a little solder to all the large parts in the area. Small wattage = 15 to 30 watt. Stay away from the surface mounts they are not the problem. I resoldered the following: D647
Q605 C690 D645 D620 R691 Q691
These parts are located on the main board, the one the power cord connects to. Carefully press the clip on the left side of the board (as you look at it from the rear of the tv) carefully pull the main board back and out of the rails. You will find the parts on the right side of the main board about 2 inches over 2 inches down.
Posted on Dec 31, 2007
  • 5 Answers
SOURCE: picture on my sony 29" cuts out after a few minutes
I once had this problem.I unplugged it for a few minutes then plugged it in it worked , but then i took it to repair it and everything was fine
Posted on May 18, 2009
Karthik316
  • 187 Answers
SOURCE: Sony Trinitron TV - Keeps Blinking
Try this link
http://www.agoraquest.com/searchbb.php?addterms=all&forum=all&sortby=p.post_time&submit=1&term=trinitron%20blinking%20picture
pls rate my suggestion....
Posted on Jun 23, 2009
  • 4234 Answers
SOURCE: picture goes black on and off but sound still on
This could be a sign that the picture tube is starting to fail. To prove this try the following: Please note that there are potentially dangerous high voltages present inside the set, so be careful.
Unplug the set and remove the back. Locate the flyback transformer (lower right when facing the back of the set and has a lare red wire coming out the top.) There should be 2 controls on that part. One should be labeled screen the other focus. Turn the screen control slightly clockwise. Turn on the set. If the blanking stops, then this will "fix" the problem for a short period. This is not a final fix, but a short tern remedy to give you time to locate a replacement set.
If the above does not resolve the problem, please update this and we'll investigate further.
Thanks,
Dan
Posted on Nov 03, 2009
gopakumarg43
  • 75462 Answers
SOURCE: I just tried to turn my sony 32" trinitron and it
Hello
I thinks that you have a concept of soldering and have the knowledge in following the printed circuit board tracks.
Seven blinks in Sony sets denotes a high voltage shutdown. When the high voltage at the final anode of the picture tube exceeds 33KVDC, the unit goes to shut down, and the system control Ic detects it and gives you this seven blinks as indication. Mainly this fault must be due to increase in the main DC supply line on the circuit board. Usually Sony 32" sets are working at 135VDC, as supply voltage to its LOT [Line Output Tranformer]. You first do one thing. Isolate the supply to LOT by making a break in the print very close to LOT so that we can resolder it later. Load a 100W bulb in seris with the supply point and negative rail in the circuit, and switch on the TV. The bulb will glow, and measure the voltage across it. It should be around or lower than the above said voltage. If it is more than normal, check the main power regulator section. Normally Sony sets have STR regulated power supply system. If any of its solder joints goes loose contacted, this fault [over voltage] may occur. Check for all solder joints for any loose contact. Loose contact in printed circuit boards are very difficult to locate. We in service field, resolder all the suspected point bt applying a little more solder. In most cases this may be the reson for seven blinks. If it does not helps, change the STR with same type and number. STRs are very accurate constant voltage regulators, and will be no adjustement presets there to adjust.
After resoldering the suspected points, switch on the set again and measure the voltage across the bulb. If you see it is normal as said above, reconnect the breaked point.
Before doing all of the above, first adjust the screen control of the TV to a lower value by rotating the screen control to counterclockwise, and see whether the screen comes and stay steady or not. If Screen Control Potmeter is defective, this fault may occur.
These are the main reasons for seven blinks on Sony TVs. Ok.
Wish you sucess.
Posted on Oct 30, 2010
Sony Trinitron KV-36FS210 will not cut on.
It sounds that the IIC bus line have some short circuited components. Actually troubleshooting to this fault is a skilled one. Its main system control IC section circuit will have the fault. If you wish to get more details about the blinking codes for Sony TVs, check this link. Pull up older posts there. Blinking codes to many model Sony TVs and other brand TVs are given in detail.
Mar 11, 2013 | Televison & Video
My sony trinitron 32' image flashes off and on but sound is ok and i am not getting a blinking red light error code.Can i fix myself or for cheap?
if you have a soldering iron, just re soldered cold soldered joints at the pin of the components at the main board which may get loose contact.
Jul 22, 2012 | Sony KV-32FS13 TV
Sony trinitron 36" has 7 red blinks wont turn on
I HAVE A SONY TRINITRON KV-36HS510. IM HAVING A PROBLEM,ITS NOT SHOWING A PIC, AND BLINKING 7 TIMES THEN PAUSE FOR A COUPLE OF SECONDS THEN IT WILL BLINK 7 MORE TIMES,I CAN HEAR AUDIO BUT CANNOT SEE PIC. COULD YOU PLEASE HELP ME OUT ,I'VE TRIED CUTTING THE TV OFF FOR ABOUT 6 HOURS AND CUTTING IT BACK ON,SAME RESULTS, THANKS
Jan 02, 2011 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Picture on my sony 29" cuts out after a few minutes
May 18, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony Fd Trinitron KV-32FX68E, stanby led blinks twice
odds are power supply module 150 200 repair
Dec 01, 2008 | Televison & Video
Sony kv27 s42 trinitron color tv
your tv has a problem inside..the supply that is going to the tube was been cut out... only the servicemen can do fixing your tv... there is a deefective parts...
Sep 18, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Sony trinitron TV KV-27TS27 screen remains dark
how do i adjust the brightness if i dont have the controler?
Jul 24, 2008 | Sony FD Trinitron WEGA KV-27FS200 27" TV
Sony KV Trinitron WEGA 36" TV won't turn on
My 36 wega did the same thing last week it must be contagious. Blinks 7 times mostly but sometimes 6 if hit power switch again. The problem is the D-boards shorted Flyback high voltage transformer but the ones Sony is selling $130 do not hold up and seem to burn out in a few days, yes twice bitten. Finally they send me new D-board can't wait to see if this fixes it once and for all. The board costs around $200 but is worth it to get it running again.
May 02, 2008 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Sony FD Trinitron WEGA KV-32HS510 32" TV Logo
41 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
