Question about Union Pegasus F1228100PBV Series 5000 Shower Only Faucet, Polished Brass
I can't get hot water from the pegasus shower valve
I installed a new pegasus shower valve. I know there is hot water to the shower but I can't get it when the valve is turned to hot
  • ShortySrm Mar 16, 2009
    Hot water pressure at the Faucet is just a trickle.
    Tried the Following
    1.) turned the Cold water off at the faucet Set screw, to see actually how much hot water was making it to the faucet. Still just a trickle
    2.) Removed the stopper and spring from the hot side of the faucet and still just a trickle
    3.) Turned off the Hot water supply line. Removed the set screw assembly and attached a 3/8 adapter and a hose and turned on the hot water. Plenty of Hot water pressure through the hose.
    Something is wrong with the shower valve? what else can I do?
    4.) I think I've ruled out everything that I have Control over.
  • 334 Answers
The antiscald device needs to be adjusted. It's behind the escucheon and determines the amount of hot water flow.
Posted on Jan 13, 2009
How do I adjust water temperature on a Pegasus shower head?
Adjustment is usually on the valve assembly. Take off the big round trim ring and you will find the adjustment on the valve assembly or in the valve stem.
Oct 19, 2014 | Pegasus F1226700RBP 1100 Series Single...
Glacier bay faucet manual
Contact glacier bay to get a replacement control/handle assembly. Usually their customer service department is good at replacing the parts under warranty
You should have individual cold & hot water supply shut-offs in your basement for your tub/shower; if not, now's the time to install them.
If I could be of further assistance, please don't hesitate to ask.
Jul 28, 2014 | Pegasus 873-0127H2 Lyndhurst Single Handle...
New Pegasus shower valve that does not get hot water
single water handles are often put back in 180 degrees off, remove the shaft and turn it over
Aug 02, 2010 | Union Pegasus F1228100PBV Series 5000...
I cannot get the water hot enough and maitain the water pressure. The groved thing in center (after removing all hardware and sace plate) is missing the red/blue clips. I am a complete novice and don't...
pegasus is a home depot product u need to adjust ur anti scald setting the valve is shipped in cold position it should have a red and blue plastic clips that go over the grooved thing call pegasus customer service at 1888 328-2383 they should be able to assist u with ur problem if u need parts or how to adjust the anti scald system
Jan 03, 2010 | Union Pegasus F1228100PBV Series 5000...
Have a pegasus shower single valve ..cannot determine how to adjust the hot water to increase it. Have hot water in bathroom sink.... renting this place...owner has no clue. removed handle and all that is...
when it is sold the anti-scold is set at cold to protect the buyer -the piece with the groves on it is the stem their should be two plastic clips a red and blue that slid over it these clips are the adjustment -also give pegasus a call they have an 800 number to assist u or home depot the carry the brand
Nov 09, 2009 | Union Pegasus F1228100PBV Series 5000...
Single handle shower valve.. can't get any hot
factory set is usally cold for safety. remove handle, then remove cover. you will see the mechanism, bunch of plastic teeth, set it up in the middle, then try it, repeat process till you get desired temp
Aug 01, 2009 | Home
Why is it that when I turn on the water on my Pegasus K800 tub and shower faucet, water comes out of the spout and the shower head. It is brand new
Your diverter valve probably has a loose washer or seat. It could be defective, but try to tighten the washer and seat first.
Regards, --W/D--
Jul 20, 2009 | Pegasus Technologies Home
No water pressure on Pegasus kitchen single handle faucet
Those new faucets generally have a lower water pressure due to legislation passed in 2007 that reduced that maximum allowable gpm (gallons per minute). I hate to tell anyone this but there is little if anything you can do. First of all, make sure the shut-off valves are open completely. I know that sounds elementary but I've seen it a bunch of times.
Also check to see if the aerator is blocked with a bit of debris.....unlikely if the flow is uniform but still an easy fix.
Hope I didn't break your spirit too much....
Apr 28, 2009 | Pegasus Technologies Pegasus F1225100BN...
Water in shower not very hot
It could be possible you require more water volume, so take off both panels on youur water heater and check what temp. they are at.
I know I discovered the hard way there are 2 heaters and 1 of mine was low,good luke.
Mar 25, 2009 | Pegasus Technologies Home
Union Pegasus F1228100PBV Series 5000 Shower Only Faucet, Polished Brass Logo
2,969 people viewed this question
Top Union Home Experts
john h
Tom Chichester
Are you an Union Home Expert? Answer questions, earn points and help others
