Question about Frigidaire GLTF2940ES Front Load Washer
I changedthe controle board!but now when I start the washerthe water doesn t run. i pressed the press start and cancelknop simultaneously and it shows E5e which meansthat there is a communicationprob
When pressing start twice ,the light kees blinking,so no water is filling the tub
  • Ivan Kelly
    Ivan Kelly Dec 11, 2012
    The expert advised me to change the pressure relay .As I said the machine was working,but didn t drainthe water .I was advised by tyour expert to change the board because the errorecode was E23.I check the pummp afterwards and it was pluged with a piece of cloth.I clearedit and thought everything was all right.When I started the washeragain the startlight kept blinkig.I checked the errorcode and now it shows me E5e .which means communication problems.I checked the wires and everything looks o.k.The expert recommended me to change thepressurerelay .I thing by the time I will fix the problem I ll be spending the amount of a new machine.I cant believe that the pluged pump could destroy everything in the washer .I would like to get an answer to this and if someone can help me fix this problem. Thank you.
  • Official Brand Answer
  • 4,342 Answers
Hello Ivan Kelly - Typically error code E5E indicates that there is a communication problem. Base on the intensity of the issue, I suggest contacting a professional technician to accurately repair the unit. Technician will need to check the wiring between the main control board and the speed control board. If the wiring is bad, it has to be corrected. However if the wiring is good the main control board will need to be replace or if the problem is not corrected, the speed control board will need replacing.
Posted on Dec 12, 2012
Hi I have LG Fuzzy logic WF-T6060NT top load water level all LED flushing simultaneously after pressing start button. Pls help confirm if the cause of this probelen is a defective control board.
Try unplugging it, waiting a few minutes, and then plugging it back in.
It may well reset the controller, and make the lighst quit flashing..
Jul 26, 2014 | LG Washing Machines
2nd Wii remote not recognised when reconnecting to add player 2 on Donkey Kong. Player 2 LED comes on when resync completes but goes off when game starts.
You said when if the game starts the controller goes off.try holding the sync button on the wii console for 15-20 seconds then resync all controllers.If it doesn't work try this:Start the donkey kong game then press the home button then go to the wii remote settings it has an icon of a remote then after you enter it find the reconnect then press 1-2 simultaneously to select who is the first player.If it doesn't work try resynchronizing it as the first controller.Hope this helps.
Apr 15, 2011 | Video Game Consoles & Games
I have accidentally locked my microwave oven (profile performance convection oven). I was cleaning the front. Can you tell me what to do?
Got you covered. Here you go:
Microwave - Explanation of the Child Lock Out Feature
Many microwave control panels can be locked to prevent accidental use or access by children.
There are two different ways to lock the control panel:
1. Press and hold the CLEAR/OFF pad for 3 seconds. The display will show "LOCK" and then revert to the time of day.
A small "L" will appear in the corner of the display as a reminder that the control panel is locked. If anyone tries to use the microwave, the display will show "LOCK".
2. On some models, press and hold the 5 and 7 pads simultaneously for 3 seconds.
To unlock the control: Repeat the procedure which was used to lock the control. (Press and hold the CLEAR/OFF pad for about 3 seconds or hold the 5 and 7 pad simultaneously for 3 seconds.)
That info is from GE
Hope that does the trick.
Regards, Farmerbear at FixYa.com
Sep 13, 2010 | General Electric Microwave Oven
Washer will not fill with water after it locks
Hi brittruiz07, I’m an owner like you and will try to help.
Is your machine type a FAV6800AW or FAV9800AW? I need to know the model number this is important.
With this condition I assume both lid locks retract allowing you to open the lid and no water flows into the wash tub and you take no error codes to the display is this correct?
The Lid is Locked LED lit and if the water valves are not not signaled on at the start of the wash cycle this issue could be related could be related to a Control Board issue. I don't want to say failure just yet. Let's see if the Control Board will let you get into Service Mode. With no error codes to start the troubleshooting process with we need to enter Service Mode and vview machine Error Code History.
To enter Service Mode press and hold simultaneously the Enviro Plus and Spin Only keys for three seconds or until the control beeps and the display reads “00”.
This is from the Service Manual; this process starts on page 17 in the Service Manual.
In Service Mode press the Wrinkle Control key.
The display will show a “d”.
The diagnostic codes can be viewed by using the Set Delay Time arrow keys. Pressing the Set Delay Time down arrow key will cycle down the list one code at a time each time it is pushed. Please right down each code such 4, 18, 22 etc.
If there are no error codes in the Control Board memory the display will read “- -“ that’s two dashes in the display. I feel you will have many Error Codes from previous wash cycles. I just want to get a feel for the Error Code history.
Next I want you to hard reset the Control Board by pulling the disconnecting the washer power cord for ten seconds then reconnect washer power. Go back into Service Mode and make sure all Error Codes have cleared you should only see “- -“. Press the off button to back out of Service Mode.
Start a Quick Wash cycle with minimal machine settings and no clothes in the basket.
If the washer fails to start the Quick Wash cycle as you described in your initial post how long did it take for the machine to unlock the lid? Did any water flow into the tub and were there any Error Codes sent to the display? Please go back and read the error code list and let me know what error codes you see from this Quick Wash cycle attempt. I know this is painful but we need to start somewhere.
You can pump out excess water when you fail with dc/UC unbalance errors with this process from the Service Manual.
Close the lid and enter the Service Mode by pressing and holding simultaneously the Enviro Plus and Spin Only keys for three seconds or the display reads “00”
Press the Delicates key this will lock the lid.
Now press the Presoak key the drain pump will turn on.
Turn off the drain pump by hitting the off button or hit the Presoak key.
Rich
Aug 12, 2009 | Maytag Neptune FAV6800AW Top Load Washer
E1 error code
Fault is 1E- this indicates a water inlet error.
To access test mode: press and hold Normal+Eco, and press Power. Release buttons. Then press Start(display n:01).Press Start again (display shows water level frequency-not important). Press Start again-(display n:03-motor will be running). Press Start again (display n:04-drain pump will run). Press Start again (display n:05-inlet valve will come on and machine should fill with water). You have now tested major components are working-if you keep pressing start you will scroll thru and test other functions, like heater, dispensor etc, but not needed for your fault.
If Machine didn't fill with water in test mode, you probably have a faulty inlet valve (test resistence should be approx 3.7-4 k ohm).
If inlet valve has tested OK ie machine filled with water in test mode then:
Disconnect from power.
Remove side panels (need to remove top, and bottom front panel to then be able to remove sides)
- Check no water in base of machine-water in base will indicate machine has leaked and activated the safety device which shuts off inlet valve.
- If OK, you probably have a faulty flow meter(measures water intake). Located left hand side of machine, large plastic compartment, which has a sensor at the bottom with 3 wires (red,white,black) that go up to control board. Replace entire flow meter assy-relatively inexpensive part.
- If you still have problem, then control board is faulty, but in my experience it is much more likely to be flow meter
Aug 05, 2009 | LG Dishwashers
Only one of the wash cycles on my Maytag Neptune TL washer still works. Nothing happens when you press the other buttons. Most of the lights for the additional options are out too (e.g. water temperature -...
Is it a FAV6800AW or FAV9800AW machine? Sounds like it is. I believe you have a Control Board issue; the Control Board has a 5yr warranty. Do you want to DIY a fix or call in a Appliance Repair Tech? Have you reset the 120VAC power on the machine? If not give the Control Board a hard reset by pulling the washer power plug for 10 seconds or so and then re-power up the machine.
I’ll attach the Service Manual link located on this site for reference. See if you can get into Service Mode, try this.
To enter Service Mode, this from the SM.
Enter / Exit Service Mode
To enter Service Mode press the Enviro Plus and Spin Only keys simultaneously for three seconds or until the control beeps. The Console display will show “00”.
Access Board Output Test by pressing the Delicates key. The console display will show “ot”
The lid lock will lock and the Quick Wash LED will be lit. Will the machine allow you into Service Mode? If not then it’s time to replace the Control Board. Press the Off button to back out of Service Mode.
Let me know what direction you want to go. Rich
Jul 31, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Will not turn on
Did you find a solution? This just happened to me tonight...
Jul 19, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
471 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
