Question about Drills
Milwaukee 18v Drill - Brake not working any more..
Had this drill for just under a year now and had no problems at all prior to this.. Yesterday the electric brake stopped working on my combi drill so it spins after I have released the trigger which as you can imagine can be extremely frustrating! Anyone had this happen to them and know of a way to solve it? Thanks in advance
    Champion:
  • 304 Answers
Two options the brushes are worn or sticking in their holders or the switch is faulty. Switch can be expensive. If it's under a year contact milwaukee and get it fixed under warranty. It might need the upgraded switch.
Posted on Dec 17, 2012
Drill is noisy in operation - sounds like bearings - its a bosch combi boxer drill (350-2)
Bosch did not make a 'combi boxer' or a model #350-2
Unfortunately, you probably have a cheap Japanese drill sold as a Bosch with a fake Bosch label, we see plenty of them come through.
Mar 08, 2015 | Bosch Drills
My 18v combi drill just stopped working light works so battery charged
This could be a trigger (contacts) problem or motor brushes are worn. Try to rotate the drill chuck by hand about 1/4 turn, then try the trigger. If the drill starts to move then it most likely will be worn brushes.
Mar 08, 2014 | Saws
I have an 18v Milwaukee drill. Can I use a 28v charger to charge the 18v battery
Generally, When your have the 18V milwaukee drill, you had better to use the same voltage battery charger to charge the battery. it will be more safe.
John.
http://www.anybatteries.com.au/battery-model.php/Power-Tools-Battery_milwaukee.html
Mar 19, 2013 | Drills
My drill slips under high torque
check clutch adjust,put it in drilling mode
check if speed selector is in right position
after that if it slip aggain,you need a gearbox
Nov 04, 2012 | Milwaukee Tool Milwaukee 18V 1/2 In Hammer...
Milwaukee 18V Hammer drill shuts off while drilling
Brushes to the motor could be the cause or heat sensor in the battery pack it switches off or even bad connections on motor check the spades connections could be loose
May 13, 2017 | Milwaukee Tool Milwaukee 18V 1/2 In Hammer...
2005 impala rear (passenger side) blinker and brake light wont work... the parking lights work fine. I changed the turn signal light figured that was the problem since the front passanger blinker works...
Any idea's ? Yes , learn how these system's work ! Looking at wiring diagram's to see what all is involved in the electrical circuit's for the brake & turn signal lamps . Plus learning how to test electrical circuit's with a DVOM - digital volt ohm meter .
Electric Testing Techniques You Need to Know
Testing is how to find this problem , not going by someone guessing who has not even looked at the vehicle ! Free wiring diagram's here http://www.bbbind.com/free_tsb.html Enter vehicle info. year , make , model an engine size . Under system click on lighting ,then under subsystem click on stop lamp or turn signals . Take your DVOM an at the rear right stop lamp bulb test for B+ voltage , check ground side . See which side of the circuit has the problem . Mastering Voltage Drop Testing with Pete Meier and Jerry Truglia
Dec 16, 2017 | Cars & Trucks
Hi, I need the motor cooling fan for my 18v 1/2 " hammer drill...Cat No. is...2602-20 Thanks Lori
ereplacementparts.com
http://www.ereplacementparts.com/
They seem to have any tool replacement part that is available anywhere..
heatman101
Feb 12, 2011 | Milwaukee Tool Milwaukee 18V 1/2 In Hammer...
Drills Logo
338 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
