Question about Maytag Centennial 3.2 cu. ft. SuperSize Plus Top Load Washer
My maytag centennial washer has been making a weird noise during agitation and today it stopped agitating at all. Need assistance please.
  • 1 more comment
  • angeeb008
    angeeb008 Dec 10, 2012
    The only number I could find is W10251338
  • angeeb008
    for any solution please email me at angeeb008@yahoo.com
  • Anonymous Mar 29, 2014
    Top Expert:
  • Maytag Master
  • 9,472 Answers
What is the complete model number of the unit?
Posted on Dec 09, 2012
4 Suggested Answers
Master_Tech
  • 770 Answers
SOURCE: maytag mav8600aww grinding when agitate
post your email i will send you the service manual
Posted on Jan 27, 2008
  • 76 Answers
SOURCE: Grinding sound during agitation cycle on my Maytag Performa
Its probably you stator plate and rotor. But you need special tools for this repair. There a spring that is under 200 pounds of pressure and if you take the screws off that hold the plate its going to fly into you face if your dont use the special tools to depress the spring. Is it more of a clanking kinda of noise? DOes it olnly happen with heavy loads? Try this out. Fill the washer with water only. and get it into a wash cycle with water only. If there is no noise then put in like a load of towels. A heavy load. Now if you hear the noise now then its for sure you stator plate and rotor..hope this helps, but like i said you need those special tools to do this repair or injury can result from the spring part.
Posted on Jul 27, 2009
dwrooker
  • 6 Answers
SOURCE: maytag PAV2300AWW Washer makes grinding sound when agitating
Sounds like it is the bearing on the water pump. Take off back plate and replace and remove 3 screws and two hoses (the one hose is a waste line so make sure you have a bucket to empty our waste water) after removing these remove belt on bottom of pump.
Posted on Oct 06, 2009
Maytag centennial washer will not agitate
If it is belt driven the belt might be broken. It is underneath the washer
Apr 03, 2014 | Maytag Centennial Top Load Washer
Centennial series stops agitatimg
Usually a top loader will not agitate until the fill sensor is satisfied. If the water has shut off, and is up at the desired level, the fill sensor has done part of it's job. Check the connections there, and at the timer. It may just be a loose connection.
Nov 29, 2013 | Maytag Centennial Series MVWC200XW
1 yr machine. Won't spin but has burning smell
The reason to this problem can be due to the
brake rotor.It need's to be replaced.
Sep 01, 2009 | Maytag Centennial MVWC500V Washer
Making an awful ratcheting noise during aggitation and spin cycles
Under the agitator there is a rachet mechanism that works the agitator. If it is stripped, it will skip until the next good tooth.. when it fails entirely the agitater will stop going back and forth. Its nylon and age along with overloading hastens its dearg.. If you can get the parts you can replace it yourself without difficulty. There is a single bolt in the center of the agitator top . Remove and loft agiyator straight up.
Jun 03, 2009 | Maytag Legacy Series Top Load Washer
Maytag Atlantis 6451 noise when on and agitator doesn't work.
it does sound like a bad motor.
they are rather expensive on that machine,
you would be looking at 300 or so
May 28, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Maytag top load performa, put clothes in , fill up and now the agitator is noisey, looked under washer belt appears to be loose 2-3 inches in play, should I replace belt,or something else to repair noise...
thats normal tension on the belt if the agitator is making noise the cams within the agitator are worn (loud clicking or popping noise during wash) the agitator will need to be replaced
Dec 15, 2008 | Maytag HAV2558 Top Load Washer
Agitator fall off and knocking noise during spin cycle
there should be a rubber washer with the bolt. if it is missing the bolt may back of during agitation. also the threads on the transimision may be stripped. Some Green lock tight found in most hard ware stores should help. the knocking noise is probably due the agitator coming loose.
Sep 16, 2007 | Maytag PAV2300 Top Load Washer
Maytag Centennial 3.2 cu. ft. SuperSize Plus Top Load Washer Logo
1,251 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
