Question about Dryers
Kenmore gas dryer not getting hot enough to dry
    Top Expert:
  • Dryers Master
  • 14,553 Answers
If inside of drum gets hot suspect first somewhere between it and the place where it vents outside a blockage---Lint can do this and be hard to find and also represents a fire hazard, each year there are hundreds of fires caused by lint buildup that catches fire
Posted on Dec 10, 2012
Vish2
  • 74 Answers
SOURCE: Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
Either the heater element is breaking or is loose and getting only 110V instead of 240V.  First I would check the wall outlet with a voltmeter for 240V between Line1 and Line2.  Also check the connections and continuity for the heater element.
Posted on Oct 11, 2007
maklean
  • 1665 Answers
http://www.repairclinic.com/0088_8_1.asp
Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.
Type in model No at search tab to find parts availability
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
Posted on Jul 15, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: Kenmore gas dryer not getting hot enough
Have you checked the lint trap and also the vent hose? If you have yet to do that try it. Also make sure that the vent line is not crushed. It needs to be wide open
Posted on Feb 10, 2009
SOURCE: samsung dryer is not drying and its new
It ended up being a easy fix. Our old dryer was working fine and had been ran an hour before I hooked up the new Samsung dryer. Therefore I assumed when the new dryer did not work there had to be something wrong with it. There ended up being nothing wrong with it and it was my dryer vent. It was barley plugged which caused it to not heat up properly. I was told that the new dryers have a lot more sensors on them and its very sensitive about needing a clean vent to vent out the heat. My vent was not very dirty, but it had just enough build up of lent in it, it caused the dryer to not vent properly and it would keep shutting the flame off. Blew it out with my leaf blower and now it heats up and dry quick. I hope this helps
Posted on Feb 15, 2009
  • 10 Answers
The vent may be stopped up, or the vent hose crimped so the air cannot escape, you can check the air flow at the vent on the outside of the house while the dryer is running.
try cleaning the vent and the lint screen with a vacuum cleaner, you may need to replace the vent hose, this should solve the problem
Posted on Jun 02, 2009
My kenmore gas dryer works for 5 minutes then control panel flashs and won't heat th cloths
GOD IS GOOD !!!!
Gas Dryer no heat: or shuts down soon after heating CHECK:
Thermal Fuse
If the air flow in the dryer is restricted, the temperature in the heating chamber can get hot enough to blow the thermal fuse. If the fuse blows, it cuts power to the coils that control the gas valve. The fuse is usually mounted to the exhaust duct just inside the back panel. You can check its continuity with an ohmmeter. If, after disconnecting the fuse, you get any reading other than 0 when you touch the leads of the meter to its terminals, it has blown. There's no way to restore it -- you'll have to install a replacement.
Igniter and Gas Valve Coils
TEST with a multi meter: The igniter is an electric conductor that works like the element in an electric heater, glowing hot enough to ignite gas when you turn on the dryer. This conductor can burn out, and when it does, it may glow, but it won't get hot enough to ignite the gas. At times it may give a reading of continuity yet fail mechanically and not get hot enough to ignite flame though it gets hot and glows and even may show Ohms or continuity ( close circuit) ?
Occasionally, the Gas safety valve and the electric coils that control the gas valve are defective -- they can wear out when the dryer gets old. When this happens, the igniter glows, but gas never enters the heating chamber or does not stay consistant.
Performing a continuity test on either part will help you determine whether or not you need to replace it. But the coils should also be tested for amount of resistance as well as Ohms. As they may be showing ohms yet not putting out enough resistance to keep proper gas pressure flowing. Most coils should show at least 1300 ohms ( GIVE OR TAKE 150 OHMS). Anything significantly less Thus u get an ignition but then it soon goes back out. The flame does not stay lit.
Air Flow and Heat
The motor that drives the tumbler also drives a fan that circulates air through the heating chamber and the tumbler and expels it through the vent. If the air can't circulate, perhaps because of lint blockage, the heating chamber overheats, which prompts the cycling thermostat to turn off the gas. The thermostat resets when the chamber cools, but the chamber heats up quickly and the thermostat again shuts off the gas. The result is that the temperature in the tumbler doesn't stay hot, and your clothes take longer to dry, if they get dry at all.
Warning
There's a big difference between a dryer that doesn't heat up at all and one that just doesn't get hot enough to dry your clothes. In the first instance, the problem is usually a defective part, and things should be back to normal after you replace it. In the second instance, the problem is caused by restricted air flow, and you need to clear the lint filter and vents and take steps to prevent lint build-up. If you don't, you'll use more energy for drying than you need and the dryer may continue to malfunction. Worse, you may have a dryer fire.
Sep 21, 2014 | Kenmore Sears Kenmore Clothes Dryer Flame...
Kenmore advantage gas dryer
Thermal Fuse
Air Flow and Heat
Warning
Aug 10, 2014 | Kenmore Dryers
Why dose my Kenmore elite dryer come on and then goes right back off and say f2
Dryer runs then shuts down wont start up for an hour:
Bad motor windings
IS IT GAS? IF SO Gas Dryer no heat: or shuts down soon after heating CHECK:
Thermal Fuse
Air Flow and Heat
Warning
Jul 21, 2014 | Kenmore Dryers
Kenmore Elite HE4 Gas Dryer Shuts off prematurely in the Auto Dry cycle and the Timed dry cycle
Thermal Fuse
Air Flow and Heat
Warning
Jul 19, 2014 | Kenmore Dryers
Kenmore gas dryer series 500 won't heat
Thermal Fuse
Air Flow and Heat
Warning
Jul 04, 2014 | Kenmore Elite HE4 Electric Dryer
How do i fix my kenmore gas dryer model 87673100, will not heat up
Thermal Fuse
Air Flow and Heat
Warning
Jun 14, 2014 | Kenmore 63942 Dryer
My Kenmore elite gas dryer sometimes starts and sometimes doesnt ?
Thermal Fuse
Air Flow and Heat
Warning
Jun 02, 2014 | Kenmore 74892 Gas Dryer
Kenmore Series 70 Gas Dryer not getting hot enough
The first thought I have is about the gas supply. If you had natural gas at the old house and now have propane or visa versa you need to change the orifices in the dryer as gas flow is different. Also, if the gas line some how got a kink in it when the dryer was being installed that too would restrict the flow of gas.
Jul 06, 2009 | Dryers
Gas ignites but goes out after 15 or 20 seconds
Hello gdurawa
Welcome to Fixya
My name is Huum,
You said, upon starting my Kenmore gas dryer the igniter glows and the gas ignites, but the gas goes out after 15 or 20 seconds - clothes don't dry.
This means either the igniter is bad and not getting hot enough to make the gas continue to release completely and stay open, so it shut off.
or you have a bad gas module.
Or a bad gas valve without enough pressure.
Needs to be diagnosed hands on at your location .
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Jan 22, 2009 | Kenmore 63942 Dryer
Dryers Logo
37 people viewed this question
Top Dryers Experts
