Question about Garden
315.10700 2.5 A variable switch control 61029-000
Any idea to fix with one speed lever
  • 1,271 Answers
Can you supply any other information regarding this switch ?
regards
Posted on Dec 09, 2012
  • 5 more comments
  • francois clermont Dec 09, 2012
    it is sabre saw variable speed switch number from craftsman is 61029-000 it is discontinued
  • Robin Hill
    Robin Hill Dec 09, 2012
    is it like thishttp://www.amazon.com/dp/B009YES94W/ref=...
    switch was made by ECC mexico 8052 125V 4.5 A
  • Robin Hill
    but is it for the right saw ? the link above ?
  • francois clermont Dec 11, 2012
    correct craftsman number for switch is : 610929-000
  • francois clermont Dec 12, 2012
    i finally found something at store.eurtonelectric.com/switches it is what i need but the price at 12.50 and the location in California do not justify
  • Robin Hill
    Robin Hill Dec 13, 2012
    okay well i searched everywhere , that sort of saw has two sides by unscrew one side will expose the switch and related wiring
How do I fix a B&D jigsaw--variable speed control wheel turns but no variaton in speed?
The problem is the control wheel, the only solution is to replace it. You can try spraying switch cleaner into it, might just help
Aug 16, 2015 | Cars & Trucks
What is the difference between a variable and non-variable speed sewing machine foot control?
variable foot control==the farther you push it...the faster the machine goes....
non variable....only has stop...and run....
Jun 05, 2015 | Sewing Machines
What is the definition for controlled variable?
You have either constants or variables. Constants are things that does not change. Time is a constant - you can't move forward or backward in time.
Variables are parameters that change. Some variables are fixed, others can be controlled.
A controlled variable is a variable that can be changed at will or according to circumstance.
For example, if you have a radio with a fixed coil / tuning capacitor which can receive only one station, the variable (radio stations) cannot be controlled, it is fixed, therefore a fixed variable. A normal radio can be tuned to different stations, therefore a controlled variable.
The engine on a car has a controlled variable speed. A normal light bulb is controlled by a fixed voltage, until you build in a dimmer switch, which now makes the voltage variable, and controlled.
Nov 07, 2014 | Cars & Trucks
Variable speed not working
The variable speed function is controlled by the switch. If you only have off and full on, the only fix is to replace the switch (Bosch Part Number 2607202013).
Mar 14, 2012 | Bosch 23618 18V Cordless Impactor...
Gr450 grinder variable speed has stopped woking, grinder goes to full speed when turned on with no affect from variable speed
i woulkd take switch off and rewire it. It is not a very difficult thing to do. As you take it apart just pay atention to where the speed control wires are running from and go from there. If it still dosent work than the switch is burnt out
Apr 17, 2011 | Delta GR450 ShopMaster 8'' Variable Speed...
I was making a standard cake with my kitchenaid and in the middle of creaming butter and sugar together, it stopped working. Turned it off, switched plugs, let it cool down, etc - it won't turn on now and...
either the electrical motor brushes are worn down on the motors commutator and can no longer contact the motors commutator bands,or if its a newer style mixer the triac that controls the speeds on the unit could have opened up and can no longer supply variable or even high speeds
Aug 01, 2010 | KitchenAid Food Mixers
I need to replace the transmission drive belt and need instructions
There's actually a Troy-Bilt Pony riding lawn mower as well.  If yours is like ours, a model 13AN77TG766 [URL:http://manuals.mtdproducts.com/mtd/DocGetter?doc=769-02243a.pdf], it doesn't actually have gears but rather a variable-speed pulley.  The lever on the dashboard actually controls how high the brake pedal will go, while the brake pedal controls the position of the variable-speed pulley, which controls the effective gearing ratio.  That's how it can go at any speed with the engine still going at the same rate and without having to disengage a clutch.
So perhaps your mower is engaging the parking brake too early (page 17 of our manual).  The other thing I can think of is grass in the variable-speed pulley.  To check that, remove the spark plug and the battery (7/16-inch socket).  Then move the shift lever through its full range and check the shaft of the variable-speed pulley (part 63 on page 34) for debris, both above and below the loose plate thingy.  (You should be able to turn it quite easily if you put the forward/reverse lever in neutral.)
Hope that helps!
Jun 01, 2009 | Troy-Bilt Pony Garden Tiller
Cordless Dremel variable speed stuck on maximum
Hi, There are several dealers in London who can help you solve your problem. The following link is has a list of those dealers with addresses and phone numbers:
http://www.dremeleurope.com/dremel/dealerlocator/index.cfm?lang=en-GB
Good Luck to you, this should Fixya!
Mar 02, 2009 | Dremel 8000 01 Cordless Rotary Tool Kit...
I installed 2 industrial ceiling fans with 5 speed controls but my customer want the fans to rotate slower than the lowest setting. Could I install an ordinary lighting dimmer switch either before the...
A regular dimmer switch will not do what you want.  A variable speed switch similar to a dimmer but made specifically to control motor loads may do what you want.  I think it would have to be installed after the 5-speed controller because the reduced voltage may cause problems for that controller.  Maybe you should just replace the controller with a the variable speed switch.
Feb 22, 2009 | Westinghouse 78127 Industrial Ceiling Fan
Dremel Scroll Station 1800
You need to replace the variable speed control switch. Other than that, your not doing anything wrong. Have fun
Feb 04, 2008 | Dremel 1800-01 Scroll Station 18" Variable...
Garden Logo
159 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
