Question about Philips GoGear SA178 MP3 Player
It won't charge
Today, after use, it only had one bar of battery. I plug it into my computer's USB drive and it has not gotten any more battery than it had-in 3 hours time.
Help!
  • EmilyNieman Jan 14, 2009
    it is not.
    It has now been over a day and still has not charged.
    Should I bring it into the store and get my warrenty's worth?
  • EmilyNieman Jan 15, 2009
    thank you (both)!
  • 8,596 Answers
Make sure the hold/lock is not engaged.
Posted on Jan 13, 2009
  • Corey Knoettgen
    Corey Knoettgen Jan 15, 2009
    Yep - claim that warranty
Emerson emp287c-4 wont charge with usb
Having same issue, battery will not charge. Can't even use it unless its plugged into my computer the whole time. Followed the charging instructions, "turn power switch on and then use the usb cord provided to plug the device into the computer." I do so and it reads that it is charging, however the bar never goes to the green charge symbol. It said to not let it charge past 8 hours so I always unplug it before that. Even tried the recommended 3-5 hours and still I turn it on and it says right away battery low.
Dec 26, 2012 | Emerson Televison & Video
Tip
Problem charging MAGELLAN GPS.
I found there are select 120v AC adapters that will work on Magellan GPS. When a working 120v or 12v adapter to mini USB adapter is plugged into the unit, the battery bars will be 'scrolling' and therefore charging.
When your adapter, or even USB cable from your computer, is plugged into the GPS unit, and the battery goes to FULL, it is NOT CHARGING. The battery bars must be SCROLLING for the unit to charge. In this case, get a different adapter until it works.
This was tested on a Magellan 1412, and may apply to other Magellan GPS.
on Dec 28, 2008 | Magellan RoadMate 1412 Car GPS Receiver
Is there a way to charge and USB connect Casio EXILIM EX-S500 without using a USB cradle?
Yes to the first and why bother to the second.
You can charge the battery outside the camera using a BC-10L charger or equivalent. One such charger is available here.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Oct 20, 2012 | Casio Exilim EX-S500 Digital Camera
I have a Sony VAIO GRZ610, old i know. Won't power up,
If you cannot get the laptop working then try this method.
Remove the hard drive and connect it to an USB hard drive adapter and then plug this adapter into a working computer's USB port. If this computer sees this as an USB mass storage device (external hard drive) and you can open the various folders and files, then you can backup and or transfer your data to another computer. If yiu install the hard drive in an USB hard drive case then you can use this hard drive as an external USB hard drive.
Aug 29, 2012 | Sony VAIO GRZ610 Notebook
Why isnt my ipod charging?
iPod's battery doesn't charge
Several things could keep your iPod's battery from charging. The major causes are listed below in logical order. Check each one to see if it's what's keeping your battery from charging.
Low-powered USB port
iPods that connect to USB ports require a high-power USB port.
Keyboards and some USB hubs will not charge iPod. Connect iPod directly to the computer or to a USB AC power adapter. Click here for more information.
Connect directly to computer
If you connect iPod to something that connects to the computer (like a USB hub or FireWire drive), connect iPod directly to the USB or
FireWire port on the computer.
FireWire port on a Windows PC
The FireWire (IEEE 1394) ports on some Windows-compatible computers may not be powered, and consequently won't charge iPod when you plug it in. Check here to see if the FireWire port on your PC can charge iPod.
Your computer goes to sleep
Your computer can only charge iPod when it's turned on and not asleep. Make sure your computer is on and not set to go to sleep when you want to charge iPod. Tip:
Some Macintosh computers can charge iPod even though they're asleep.
If your sleeping computer doesn't charge iPod, don't worry, just wake it and let iPod charge.
hope this helps
Aug 14, 2012 | Apple iPod touch
Panasonic HM-TA1 won't power on with battery fully charged.
The battery will not charge when the device is turned on. Make sure that when you connect it to your computer via its usb that you do not turn it on otherwise it wont charge.
The annoying thing about this device is that when you connect it to your computer and turn it on, on the LCD it will say "connecting via usb" and the memory bar will show that it is fully charged, however the battery is not. This must just be a design flaw as the battery won't be charged.
Just remember to plug it in and leave it, do not turn it on!
Jan 24, 2011 | Panasonic HMTA1 Camcorder
What usb cable do i need to recharge my camera and how do i upload photos onto my computer.
The DSC-W55 doesn't charge batteries via the USB port. It comes with a separate battery charger, which plugs into a wall outlet.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Dec 11, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
My phone only works when it's plugged into the charger
New batteries are shipped partially charged. Before you start using your device, it is recommended that you charge the battery. Some batteries perform best after several full charge/discharge cycles. You can charge the battery in two ways: • Charging the device’s battery by connecting the power adapter. • Connecting your device to a PC via the provided Mini USB cable. Note: Only the AC adapter and USB cable provided with your device should be used to charge the device. Charging is indicated by a solid amber light on the left LED indicator. As the battery is being charged while the device’s power is on, a charging icon will be shown on the title bar of the Today screen. After the battery has been fully charged, the left LED becomes green and a full battery icon appears on the Today screen’s title bar. Warning! Do not remove the battery from the device while you are charging it using the AC or car adapter. As a safety precaution, the battery stops charging when it overheats. When the low-battery warning appears, do the following: • Immediately save your current data. • Synchronize with your PC or connect the power adapter to charge the battery. • Turn off your device.
Hope this helps, let me know if I can help you with anything else.
JimmyC
Jul 14, 2009 | UTStarcom Blitz Cell Phone
Battery question
Oct 08, 2008 | Magellan RoadMate 1412 Car GPS Receiver
Philips GoGear SA178 MP3 Player Logo
27 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
