Question about Frigidaire Affinity 5.8 Cu. Ft. Super Capacity Electric Dryer
Empty the dryer does not squeak but add clothes to it starts up, Frigidaire LEQ6000ES2
There is some black, powdery greasy substance on the back near the center of dryer,
  • Official Brand Answer
  • 4,342 Answers
Hello David Strobel - Do you notice the black substance after you take the clothing out of the washer or is it after it has been in the dryer?
Posted on Dec 14, 2012
  • 686 Answers
SOURCE: irregular squeaking from stackable dryer
Post your make and model please. Sounds like the rear drum bearing is dried up
Posted on Mar 02, 2009
dragonsthatk
  • 547 Answers
SOURCE: why would clothes get caught in my dryer & start smelling burnt?
there must be problum with the felt change it
Posted on Feb 18, 2009
SOURCE: clothes dryer squeaks when running
Fixing Frigidaire model # FER641FSO, not stacking, but had similar problem. turnsout one of the coils came off. might try that...
Posted on Jun 10, 2009
  • 401 Answers
SOURCE: frigidaire dryer model # FDEB34RGS2 Squeaking
The belts rarely squeal in a dryer and don't get wet, never need cleaned. What you describe sounds like possibly worn out drum slides on the front of the drum housing. Maybe even worn out felt seals. StanStihl has a good point about the idler pulley and drum rollers might need a drop of oil on their bearings. Just a drop or two though, too much and lint can build up on them.
Posted on Jan 02, 2010
iwillfixforu
  • 619 Answers
SOURCE: squeaking when dryer runs
Yes. Replace the rear bearing cup that the drum sits down into. Do not oil. This cup takes a special grease that you can get with the cup. Also don't let anyone try to sell you the whole bearing kit. All you need is the cup and the grease.
Posted on Feb 01, 2010
Frigidaire affinity LEQ6000ES2 error code e68...dryer will not start
Good Afternoon David,
I understand that your Frigidaire Affinity dryer, model# LEQ6000ES2, is showing you an error code of E68 and will not start. I also see that you have changed the thermal limiter. Looking at what the E68 error code means, a key or button stuck, there could be something else causing the code to come up. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance, determine what is causing the E68, and repair your dryer. Hope this is helpful.
-Best Regards-
WP
Jul 04, 2014 | Frigidaire Dryers
My Frigidaire FTF530FS Front Load Washer appears to be leaking oil and it is getting on my clothes
Hello Loree Grudem - This can be the result of the shaft bearing and seal. They may have become worn and the transmission oil is creeping up to get in your water. Once this happens, it gets on your clothes to cause staining. Or possibly you have a buildup of fabric softener that comes loose and puts a greasy like substance in your water and on your clothing. Once you put your clothes in the dryer and the old fabric softener melts you will see these spots. I suggest contacting a professional to move forward accurately.
Oct 09, 2012 | Frigidaire FTF530FS Front Load Washer
Kenmore 417.90802990 squealing dryer w/ black powdery deposit..
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
May 20, 2010 | Dryers
The dryer squeaks when first started, then is
the belt that connects the motor to the drum needs replacing
Apr 28, 2010 | Frigidaire Electric Dryer
My dryer started making a squeaking sound. It's
Belt needs to be replaced,have you ever had a car drive by and heard a squealing noise? dryer belts "glaze" and squeal due to wear just like the ones in your engine
Apr 01, 2010 | Frigidaire Electric Dryer
The dryer is squealing and leaving burn marks on the clothes
Squeak is caused by a worn out roller rolling metal to metal - Most dryers have rollers, felts and drum slides to balance drum rotation:
When rollers wear off, black powder leaks to rear felts and black marks are left on clothes.
Same thing happens when drum slides wear off (black marks are left on clothes)
Aug 15, 2009 | Frigidaire Dryers
Does my belt need replaced?
If it is greasy and not oily, the belt will need to be replaced, there is slight possibility that the bearing seal under drum is leaking oil,
Jul 09, 2009 | Washing Machines
Frigidaire Affinity 5.8 Cu. Ft. Super Capacity Electric Dryer Logo
104 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
