Question about Dryers
Long time to dry clothes, good heat, bad air flow?
Friend suggested removing back panel and vacuuming inside. is that safe practice?
    Top Expert:
  • Dryers Master
  • 14,553 Answers
He is talking about cleaning out the unit for lint that may block the unit somewhere from drum to where it vents outside---I would have a pro do this---seen ones who for 30 dollars will come and clean and clear it as well--lint can present a fire hazard and there are hundreds of fires reported each year that are caused by this---regular cleaning can prevent that and improve performance and extend the life of the dryer and your home.
Posted on Dec 10, 2012
  • 3 Answers
SOURCE: Dryer taking double the time to dry.....
I have had the same problem with my dryer for about 2 months. I bought a heater kit upgrade on eBay, http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=220334963461 , and installed it myself this past weekend. Easy to install for a do-it-yourselfer. About 6 screws to remove, lay the dryer on the back and its all right in front of you. Dryer is working like it is new again.
Posted on Feb 02, 2009
jsrock516
  • 5911 Answers
SOURCE: Dryer not drying loads properly.
You need to clean the vent ducting from the point where it leaves the dryer to where it exits your home. The reason the dryer performed better was because it was not meeting any resistance from the ducting to push air through the exhaust on the back of the dryer. You obviously have a clog, kink, excessive bend, or a run that is too long. If you haven't had your vent ducting inspected or cleaned in a while, now would be a good time. In addition, the fact that your dryer became excessively hot WITH the ducting attached adds credence to my suspicion that your ducting is clogged or obstructed in some way. Without proper air flow the dryer will actually overheat to the point of failure. Usually the Thermal Cut-Out (also known as a Thermister) will blow. This component is designed to blow like a fuse in the event of an overheat condition and must be replaced. Running your dryer in an overheat condition not only will damage the appliance, but it can become a fire hazard. I would recommend a thorough ventilation inspection and cleaning. Make sure you are using the metallic semi-rigid ducting and NOT the plastic ducting. The semi-rigid resists crushing, kinking, is heat resistant and resists intrusion by rodents. If you have questions about anything I've explained to you, please contact me and let me know. I hope this helps.
Posted on Feb 10, 2009
  • 686 Answers
SOURCE: Dryer turns, heats up but won't dry
check the outside of your house to see how strong the blowing is if it's weak then it's in the vent tube
Posted on Feb 18, 2009
  • 530 Answers
SOURCE: dryer heats, tumbles clothes, blows air out exhause vent, but wont dry clothes
what type is this electric or gas? have you removed the exsaust from the wall and ran a load like this? if you have heat and this is an electric dryer it sounds like you have a blockage in your house. if the dryer runs fine without the exsaust attached then that is your problem. let me know
Posted on Jun 02, 2009
SOURCE: clothes not getting dry
Heating element only stays hot for 30 seconds after starting dryer. Takes 2 hours to dry clothes.
Posted on Jun 27, 2009
Why would my crosley dryer get really hot but the clothes don't get dry
If the dryer is getting hot (the heater element is working) but the clothes aren't drying, it suggests that there is insufficient air flow through the dryer. Remove the exhaust tube from the back of the dryer. With the tube removed and the dryer running, check for hot air (lots of it) flowing out the exhaust vent of the dryer. If there is good air flow, check the exhaust tube for lint build-up or a clog that is blocking the air from flowing through the tube. If there is no air coming out of the exhaust vent with the exhaust tube removed and the dryer running, it suggests that the problem is with the exhaust fan inside the dryer.
Jul 08, 2014 | Crosley CDE6000 Electric Dryer
Takes long time to dry
This caused by one of two possible things. Either you have poor air flow, or a clogged vent preventing air from flowing freely and therefor making the dryer short cycle, which in turn will take you two or three times to dry yor clothes, or the heating element has gone bad, burnt in half and is making contact with the case to provide it just enough power to barely heat. The second thing is a very rare occurance. I would turn the dryer on, find out where the air vents out to, and with the dryer running, go to where it vents and check to see if there is a strong flow of air. 9 times out of 10 that is going to be your problem. Another way to check air flow is to just pull the vent off the back and let the dryer run and see if your clothes dry faster. If you do it that way and they still take a long time to dry, then you'll probably need to replace the heating element
May 16, 2012 | Kenmore Dryers
Warm but not heating up kenmore 970C87192
excellent air flow and too extensive time to clean out lint trap and all other lint stuck in the machine behind the back panel. is there a way to look at the heating element and go yep its broken? haha like burned or snapped or could it appear perfectly fine and in fact be broken?
My Amana electric dryer, Model # NED4500VQ0 is not heating clothes enough to dry a load in one cycle. I changed the thermostat already. The back glows orange and is heating. I figure it has to be the...
Not sure about the hh limit or the element, but make absolute certain that there is good flow of air. Check to see if the vent is clogged. Remove the hose from the back of the dryer and see if air is flowing very hard. Use a vacuum cleaner or a wire or something if it is clogged. Similarly, check the hose itself. If the hose collapses when you attach a vacuum to it, it is clogged. Dryers require heat AND air flow to dry properly. :)
Mar 22, 2012 | Amana Dryers
Clothes not drying. need 2+ cycles to get clothes dry
Mar 30, 2010 | KitchenAid KEHS01P Electric Dryer
Taking long time to dry the clothes
Due to a dryer either heats or no heat , I would suggest pulling the dryer out and removing the vent hose . Dry a load of clothes to see if they dry normally . If they do , this verifys that the vent hose is either kinked ( restricting air flow ) , or , if the vent runs UP inside the wall , there is a restriction between the inside vent hose to the outside vent . May have to go into the attic to clean .
Jan 28, 2010 | Maytag Neptune MDG5500AW Gas Dryer
The dryer doesnt get hot enough to dry clothes
Pull the dryer out and remove the lint hose . Turn on the dryer and feel if there is good air flow and if you feel heat . If there is good air flow and heat , dry a load of clothes , to see if they dry normally .
If there is not good air flow , then the blower wheel is probably stripped and needs to be replaced . If there is good air flow and heat , then the problem is in the vent ducting , between the dryer and to where it vents to the outside . Dryer could be pushed back too far , causing the hose to " kink " , restricting the air flow to the outside .
Remember , a dryer either heats or doesn't heat . If no heat , then a dryer problem exists . If heat , but dryer does not dry , then a vent problem is the cause ( except for maytag , which the blower wheel sometimes strips out ) .
Nov 08, 2009 | Maytag PYE2300AY Electric Dryer
Our model medt5870tw0 maytag dryer does not dry properly
First , remove the vent hose from the dryer to see if good air flow is coming out the dryer vent . If not , could have a bad blower wheel . If so , then check the vent hose AND vent to outside to see if blocked . A dryer will either heat or not heat . Since your dryer heats , try drying a load without the vent hose connected to the dryer and see if it heats fine (telling you , a vent problem is apparent . Sometimes a dryer is pushed too far back , kinking the vent hose also .
Aug 09, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Kenmore electric dryer 110.60712990 Series 70 heats but does not dry the clothes. A friend with a meter came over and said that there is 9.8 ohms resistance on the heating element. Is this within normal...
Your heating element is good. It should read between 9 to 13 ohms. If the heating circuits are working, then you don't have a problem with the heating circuits. The numbe ron cause of drye heat related problems, or longer dry times, is poorly installed, or clogged ventilation. A simple test to try is to remove the exhaust vent hose from the back of the dryer and attempt to dry a load of clothes as you normally would. The air escaping the exhaust should be forceful and warm (about 140 degrees).
If the air flow is normal, and your clothes dry normally, the problem is with your exhaust ducting from the point where it leaves your dryer to where it exits your home. I would recommend you inspect the entire length of your exhaust ventliation to make sure it is free of kinks or clogs if this is the case.
If the air flow is weak, then the problem is INTERNAL to the dryer. The most common source of the problem is a clog in the blower fan housing preventing air to flow properly. Remove the blower fan housing cover and clean as necessary. Make sure the blower fan can turn unobstructed.
Let me know if you still have problems. I hope this helps you.
Jun 25, 2009 | Kenmore 63942 Dryer
Dryers Logo
32 people viewed this question
Top Dryers Experts
